Question about ViewSonic VG2021m LCD Monitor
Viewsonic VG2021m does not work. I took it apart and didn't see any bad caps. Power supply seems to work, 13.8V at O/P pin and 5V at O/P pin to second card. The light on the switch doesn't turn on and monitor remains dark. Can Power supply work and card not work?
  • Louis Ebert Jul 07, 2010
    wirlin, If dc rails are ok, then it could be that the inverter circuit which generates 600 to 1000 volts ac to power the cold cathode fluorescent lamps has failed. Do you see any "surface mount" fuses on the printed circuit board that may be "open" ?? Have you examined the all the solder connections of the driver and power transistors for the inverter circuit for "thermal fractures" that might occur over time due to "thermal cycling" of unit over it's lifetime? Are there any discolored areas of the printed circuit board (smps/inverter) to indicate thermal stress? What brand name of electrolytic filter capacitors are installed on smps? Do you know the "flashlight test" to check if data is on the lcd screen? Will known good monitor work perfectly with your pc? Yes, smps can be ok, but vga to digital lcd screen interface board have failed. 12fixlouie
  • 11,361 Answers
I just work on one of this last wek with the same symptom, it turns out to be the logic board problem, not available any where.
http://s807.photobucket.com/albums/yy352/budm/Viewsonic%20VG2021/
Posted on Jul 09, 2010
  • wirlin Jul 09, 2010
    Can I test the voltage Output to the lamps?
  • Bud Martin
    Bud Martin Jul 09, 2010
    Not unless you have High voltage AC probe that can handle at least 2000v, firing voltage for the CCFL is around 1500~1800v.
    You can force the inverter circuit to turn on by supplying 3.5~5v to the inverter ON control pin, In the LCD monitor, the 5vdc (logic) and the 12~18vdc are already applied to the inverter circuits, it just need the trun on command ffrom the logic board to turn on the inverter circuits, that is how it can go into standby or when it does not sense the video signal from PC to save power.
    I do not remember which pin that is the control pin on the logic board that feeds the inverter/power supply board.
My viewsonic vg2021m suddenly goes dark but the led indator still lit, then I open the smps and found 2 FET that drive the backlight trafo are short circuit , all caps is ok. The I exchange both fet with new ones. and now lcd monitor seems like going normal. but after 2 minutes the screen goes dark again. and I found the both FET going bad again.
Some help please.......
Posted on Jul 16, 2011
Turn on viewsonic vg2021m comes on for a second then goes blank. after turning on and off for 10 or 15 tries unit comes on then stays on
Look for bad caps with domed tops as shown here:
Replace them in a set.
If you are going to DIY and already try the monitor with another PC, and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed VIEWSONIC monitors to get some ideas what to look for: http://s807.photobucket.com/albums/yy352/budm/
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Apr 15, 2011 | ViewSonic Graphic VG2021m LCD Monitor
Two capacitors on my Viewsonic VG2021m popped so had them replaced, no others appeared even slightly dommed to signify they had blownm though the monitor still isn't working. Plug it in to the wall and...
Bad cap can look normal but can have high ESR, I always replace them in a set, and you should use LOW ESR type with 105c rating since we are dealing with switching power supply here. Look at the bottom seals also.
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Jan 05, 2011 | ViewSonic VG2021m LCD Monitor
Monitor keeps blacking out
Look for bad caps first, if it is not bad caps, then you will need diagram to do in-depth troubleshooting.
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed VIEWSONIC monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Basic LCD monitor troubleshooting guide:
Oct 27, 2010 | ViewSonic Graphic VG2021m LCD Monitor
My Screen is black
More likely to be bad DC filter caps in the power supply just like the rest of VIEWSONIC and ALL other brand here:
http://www.badcaps.net
Jul 15, 2010 | ViewSonic Graphic VG2021m LCD Monitor
Hello, I ordered a Viewsonic VG2021m monitor a while ago, and recently, the monitor shows nothing but black when plugged in. All cables on it have been checked, and my computer acknowledges it is there,...
This is 2006 model year, more likely to have bad caps problem in the power supply, look for caps with leaking/bulging tops first, also look to see if you do have 12~18vdc feeding the inverter circuits.
This your power supply/backlight inverter board:
http://www.shopjimmy.com/power-supply-unit-dac-12m033-af-from-viewsonic-vg2021m.htm
Learn about bad caps and failed monitors here:
Jun 09, 2010 | ViewSonic VG2021m LCD Monitor
I have a VG2245WM Monitor it has power and pc signal but very red
The caps can be bad with high ESR with no sign of bulging/leaking: http://s807.photobucket.com/albums/yy352/budm/Bad%20capacitors/
If you get pinkish glow and dimmed screen, it can be bad lamps: http://s807.photobucket.com/albums/yy352/budm/Bad%20backlight%20lamp/
I will still suspect the caps first. Check to see if you do have about 12~18vdc feeding the inverter circuits.
Jun 03, 2010 | Computers & Internet
My ViewSonic VG2021M LCD computer screen has died on me. For the past two weeks it took 2 or 3 minutes to "warm up" before it would start working, and not it has completely stopped. Some have said that it...
I can easily see 4 bad caps (black case) with bulging tops, the other two caps (green case) should also be replaced at the same time, use only good caps, PANASONIC FM or FC series from DIGIKEY, higher value and voltage are OK to use. Learn more about what bad caps look like:
My pictures: http://s807.photobucket.com/home/budm/allalbums
Apr 02, 2010 | ViewSonic VG2021m LCD Monitor
Flickers at bootup when i turn it on and of flickers. goes blank
If the screen blinks on and off, first place to look will be the power supply, look for bad caps first, post back what you see so we can guide you further, see example of failed VIEWSONIC monitors due to bad caps: http://s807.photobucket.com/home/budm/allalbums
Feb 07, 2010 | ViewSonic VG2021m LCD Monitor
Model vg2021m. it fall and now it doesn't come
Look for bad caps as hsown here:
Sep 05, 2009 | ViewSonic Graphic VG2021m LCD Monitor
VG2021M monitor - will not power on. Power light just blinks.
Blinking power light is usually an indication or a problem with the power supply or the inverter in the monitor.
You would have to take it to get it fixed.
If you have the ability to take it apart and send me pictures of the boards to bammbamm@ptd.net, I may be able to tell you if it has obvious problems.
I repair a lot of viewsonic boards, I just have not done that model yet.
Fran
Jul 25, 2009 | ViewSonic Computers & Internet
ViewSonic VG2021m LCD Monitor Logo
882 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
