Question about Bissell Healthy Home HEPA Bagless Upright Vacuum - Metallic Blue
Bissell Healthy Home vacuum brush won't spin
We have the Bissell Healthy Home vacuum. We got it in December. When you go to use it, the brush will start rotating then stop after a few rotations. I have tried making sure the extension is plugged in and that there is nothing obstructing the roller/brush. What else could it be?
  • 126 Answers
SOURCE: Brush won't spin when position of handle changes
The belt for this machine is very specific and only one size fits. It is not uncommon for vac shops to sell the wrong belt because the proper belt is not available from normal supply houses, so they will substitute something they think will work.
Also, assuming you do have the right belt, check the tension arm that drops down on the v-belt when the handle is brought back. This arm has a wheel/bearing with a plastic "tire" or trim that rolls on the belt to tighten it. Sometimes, this tire cracks and falls off and then the remaining bearing won't have the necessary tension to tighten up the belt.
Posted on Jan 27, 2008
Kazong
  • 152 Answers
SOURCE: roller brush of vacuum not rotating
u might need 2 change the belt on the attachement there r 2 screws on top take em out after u take off cover there is a plastic cover over the belt take off c if the belt broke the rest is easy
Posted on Mar 02, 2008
CompuGuy44
  • 432 Answers
SOURCE: Bissell Velocity Vacuum brushes stopped
The brush bearings wear out on these things. I know I replaced mine twice before buying new carpet. I've had it for 10 years,
You can order these parts on the Bissell website:
http://www.bissell.com/Products/p/CleanView+Brush/product.aspx
http://www.bissell.com/Products/ak/replacementparts/p/CVPT+II/product.aspx?%23=Detail#Detail
http://www.bissell.com/images/UserGuides/35934_804.pdf
Posted on Mar 30, 2008
SOURCE: directions for Bissell upright rug shampoo vacuum
need belt on brush
Posted on Sep 30, 2008
Techvisitor
  • 63 Answers
SOURCE: Bissel Healthy Home vac brush/roller is
You'll need to take the bottom plate off, remove the roller, remove the belt, and pull out whatever may be clogging the rollers on the side of the brush/roller.
Can you give us a model name for your vacuum? I can give you more details on how to remove the roller.
Usually a pair of needle nose pliers can help with this.
It happens when hair, carpet fibers, and other fun things get tied up and tangled around the sides.
Best Wishes
Posted on Nov 03, 2008
I have the Bissell Healthy Home vacuum, it will turn on but the brush won't spin and I have tried the grey button and tightening the screws. Neither worked, any other suggestions?
You can purchase Bissell replacement parts directly from Govacuum with an exclusive 11% discount for Fixya.com readers, use code: FIXYA11 to checkout to avail the offer. We also offer free shipping over $35.
Bissell - https://www.govacuum.com/collections/bissell
Jeethu
Govacuum Team
Apr 26, 2014 | Bissell Healthy Home HEPA Bagless Upright...
Bissell 5770 Brush Issues
Hi their... By touching accidently the screw driver ok circuit board that may be caused of a short of any kind fues on the board or small resistant... Please contact to electronic technician to repair it rather than purchasing new board... Thank you
Oct 24, 2017 | Bissell 5770 Healthy Home Bagless Upright...
Bissell healthy home vacuum roller won't spin
Hi Helen. Your Healthy Home vacuum has a lifetime belt. If the belt needs replacing, you should bring it to one of our Authorized Service Centers for repair. Also, here is quick link to troubleshooting steps to assist you:
http://www.bissell.com/FAQDetail.aspx?id=1394&cid=ccsocial
Here's a quick link to assist you in locating one in your area:
http://www.bissell.com/service-centers/?cid=ccsocial
Apr 05, 2013 | Bissell Healthy Home HEPA Bagless Upright...
The vacuum brush does not rotate when on. What should I check?
Check the drive belt that drives the brush from the motor. You should be able to see it underneath the machine.
Feb 06, 2011 | Bissell Healthy Home HEPA Bagless Upright...
Brush won't turn.
Is the grey "brush" button on the handle depressed? Brush won't turn unless the button is down
Feb 03, 2010 | Bissell 5770 Healthy Home Bagless Upright...
The motor for brush won't turn on for the bissell healthy home vacum
Jan 01, 2010 | Bissell 5770 Healthy Home Bagless Upright...
Bissell Healthy Home HEPA Bagless Upright Vacuum - Metallic Blue Logo
953 people viewed this question
Top Bissell Vacuums Experts
Jim Parker
Jim Parker
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
