Question about Hitachi 50HDT55 50 in. Plasma Television
Six thin pink lines running vertically across the entire screen
  • patrickmu772 Jul 08, 2010
    I do not have the electrical expertise to fix this probelm myself, but at least now I will contact a repair person to do the fix instead of just buying a new TV, which is what I was originally planning to do
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. From what you have described it seems to be the issue with Y-main however, Y-buffer and the logic board should also be checked. These boards are located on the right side of the unit and to check them you’ll have to open the back of the unit. Once you have opened the back also check for any blown/bulged capacitors.
All this is only recommended if you have electrical expertise & know how to solder/re-solder components as these units contain high voltages even when in off position. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Jul 07, 2010
I have a 70 inch Bravia XBR 70X850B which up until yesterday green/red/pink vertical line that runs across the middle of the screen.
If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts
Nov 17, 2016 | Sony XBR Televison & Video
Why are there vertical colored lines all over screen?
Thin vertical lines cover screen on Samsung LCD - AVS Forum ' Home ...
www.avsforum.com/...lcd-flat-panel.../1127410-thin-vertical-lines-cover...
Mar 7, 2009 - 30 posts - ‎25 authors
I have read there could be ribbon cable connection issues so I plan to .... I have a VizioVW22LHD TV,I hooked it up using a HDMI cable to my Toshiba satellite laptop. ... If you have thin multi-colored vertical lines on your tv panel, that do ... my TV on the thin vertical lines come all over the screen and the TV ... my VIZIO E470i-A0 LED has vertical colored lines on ...
Nov 18, 2013
Vizio SV370XVT lines throughout entire display. Not ...
Aug 3, 2012
Thin vertical line on LCD tv
Dec 29, 2007
More results from www.avsforum.com
Vizio P50HDTV Display Problems - Colored Vertical Lines .
Dec 30, 2015 | Vizio Televison & Video
Thin vertical line on copies
Tara, if the ink levels are ok, try clean and allignment functions from the tool menu. Use CLEAN UNUSED PAPER.
Mar 24, 2014 | Canon PC-940 Black and White Copier
Horizontal Band of Thin Red and Blue Lines on Screen
Sound like your Y-Sustain board has one foot in the grave. The Y upper buffer and Y lower buffer boards go when the Y Sus Goes too...
Mar 22, 2014 | Panasonic TCP46C2 46 in Plasma TV
I have horizontal lines over the whole tv,but the tv play you can see them good on some channels.Wat could be the problem?
There is mainly two reasons for this fault. The smoothing capacitor to video output supply voltage be bad, or the screen voltage to CRT is more than normal. These lines [thin horizontal lines runs across the screen; an inch apart or so to entire screen] is technically called 'vertical retrace lines' If you wish to get more details about this fault, check this site. It has details about it. Pull up older posts there.
Feb 10, 2013 | Televison & Video
My tv sony kv-xa21m61 display too bright and many horizontal lines. no picture
Vertical retrace lines is the problem. Thin white lines runs across the entire screen, at about an inch apart to each other. Check its video output supply voltage. Reduce the screen voltage to a little bit down and check. If you still wish to know more about this fault, check this site. Pull up older posts there.
Feb 09, 2013 | Sony KV-XA21M61 21" TV
Red Line across Screen
sounds like you have a vertical sweep problem. Where the fault lies cpuld be the vertical output IC the verticle b+ feed, could be the capacitors in the vertical circuit?? Your gonna need to troubleshoot thr vrtical circuit if your not a tech thin my advise is to take the set to a pro for sn est. Good Luck
May 22, 2006 | Hitachi 36UX01S 36" TV
Hitachi 50HDT55 50 in. Plasma Television Logo
26 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
