Question about Sony Cyber-shot DSC-W55 Digital Camera
Flash won't work!
I've had this camera since Christmas, and its been amazing. Now, the flash won't work under any circumstances. I'll put in Flash: on. No flash. Flash: auto. No flash. What can I do?!
  • 477 Answers
The flash circuit is your problem 1 of 2 things you can do but if you got it new at christmas it should be under warranty.
  1. get a broke one off of ebay and replace your flash circuit. and risk getting popped by 300 volts from the flash compositor.
  2. send it to a repair company and let them take the risk be leave me I know I bits like a starving dog on a steak bone. Lol it should only cost about 30.00 plus shipping if that's the only thing that is wrong. I repair these all the time. Let me know if I can help you with any thing else.
Posted on Apr 18, 2008
My Nikon Coolpix s230 flash won't work. It just blinks red in the lower right hand corner. I've tried all the settings and they all won't flash.
If there is a problem with the flash itself or the mainboard connection to the flash it will not charge. If the flash won't charge then it won't go off when you take a picture. The only way to fix the problem is to replace the flash with a good used one and see if that fixes it. If not, then you need to replace the mainboard. Good used parts can usually be found online for cheap; that auction website doesn't pay me to type their name, so I don't, sorry. Hope this helps!
Thomas Drayton
Owner, www.darntoothysam.com
Affordable Digital Camera Repair
Jul 24, 2011 | Nikon COOLPIX S230 Digital Camera
My camera won't flash no matter how many new batteries I put in it. It will take pictures that don't require a flash. I've reset everything twice and nothing has worked. Contacts are clean. ...
Some Canon cameras use some of the screws around the perimeter of the camera to serve as a safety switch to prevent activation of the flash if the case is opened. See this article for more info.
Jul 20, 2011 | Canon PowerShot A720 IS Digital Camera
I can not change the flash setting on my camera
I'm sorry that the flash on the Camera is not working. If the Forced flash setting is already enabled and the flash is still not working, then the issue may be due to another camera setting. Even if the Forced flash setting is enabled, the flash will still not work in the following circumstances:
  • When shooting MPEG movies
  • When shooting in the Twilight or Handheld Twilight mode
  • If shooting with the Burst or Multi Burst mode
  • Shooting with Sweep Panorama
  • Shooting with the Fireworks or High Sensitivity mode.
  • If an external flash is connected
Please make sure that the Camera is not in any of the above modes.
Try initializing the Camera. To initialize the Camera, please use the Initialize option under Main Settings 1 Menu of the Camera.
Feb 22, 2011 | Sony Cyber-shot DSC-H9 Digital Camera
I have a canon rebel Xsi and the flash will not pop up.
Will it not pop up under ANY circumstances? Try putting the camera in Manual (M) mode, set the shutter speed to 1/200 and the aperture to F5.0, then go in a dim room. Press the button on the camera body with the flash symbol on it. Does it still not come up?
Feb 12, 2011 | Canon EOS Rebel XSi Digital Camera
The flash wont work on the camera...still
1. Even if the flash is set to always ON, the flash will still not work in the following circumstances:
* When shooting MPEG movies. * When shooting in the Twilight or Handheld Twilight mode. * If shooting with the Burst or Multi Burst mode. * Shooting with Sweep Panorama. * Shooting with the Fireworks or High Sensitivity mode. * If an external flash is connected.
2. You can also Initialize the Camera. Touch the Home option. Then, select the Main Settings and then, select the Main Setting2 option. Then, select the Initialize option to OK.
3. You can also try to select the Flash Forced option to ON. The Flash Forced option is located under the Flash Settings.
Jan 10, 2010 | Sony DSC-T70 Digital Camera
Can the Vivitar 283 be used safely on Nikon Digital SLR Cameras?
I assume you're asking about the 283, not the DF-283 which is compatible with digital cameras.
As for the 283, yes, if you put an adapter such as the Wein Safe-Sync between the camera and the flash. Under no circumstances should the flash be mounted directly on the camera.
Nov 29, 2009 | Vivitar 283 Flash
Flash bulb not fuctioning my camera sony cyber shot dsc w55
1.Try initializing the Camera.To initialize the Camera, select the "Initialize" option under the "Setup 1" Menu of the Camera.
2.Even if the flash is set to always ON, the flash will still not work in the following circumstances:
Refer:
http://www.kb.sony.com/selfservice/microsites/search.do?cmd=displayKC&docType=kc&externalId=C95364
Oct 03, 2009 | Sony Cyber-shot DSC-W55 Digital Camera
Camera flash too bright
Hey,
You ve a four way navigation key Right..In that you ll have a symbol similar to a lightning bolt...press that to lower the flash intensity..or to have no flash at all..
please rate my suggestion..
Apr 15, 2009 | Sony Cybershot DSC-T200 Digital Camera
No flash on Canon Powershot S3
You will need to have your camera reviewed by a qualified technician to have it repaired, since it requires open the camera and evaluate the flash circuitry.
Best regards,
Nov 25, 2008 | Canon PowerShot S3 IS Digital Camera
Sony Cyber-shot  DSC-W55 Digital Camera Logo
Top Sony Cameras Experts
james laughton
james laughton
Are you a Sony Camera Expert? Answer questions, earn points and help others
