Question about Brother MFC 7840W Printer
I can't get my brother mfc 495-cw printer to print wirelessly. The printer recognized my network but the installation program won't find the printer when I try to install wirelessly. (i was able to print through a usb connection.)
Patzky
  • 240 Answers
SOURCE: My MFC 685 CW will not print.
Hello ,
First, we will have to make sure the printer is properly connected to the network
  1. Go to your printer.
  2. Press “menu” and scroll down to network, then WLAN
  3. Go to TCP/IP
  4. Go to IP address. Make sure there is an IP address here (not 000.000.000.000). Change the last 3 digits to “050”
  5. Change the boot method to “static”
If your IP address is not a valid one (all zeroes) or is an APIPA address (starting with 169.254.#.#) you will need to run the wireless setup wizard again as the machine is not properly connected wireless
If you had a valid IP address before changing anything, it means that the printer offline is caused by the computer not being able to locate the printer.
This is usually caused by the printers IP address changing.
Changing the boot method to static will make sure the IP address on the printer does not change.
Now we will have to make sure the computer knows where to find the printer.
On your computer, go to your start menuè control panelè printer
Here you should see your brother printer. Right click on the printer and select “properties” (If you are running windows Vista, make sure select “run as administrator” and then properties)
Go to the “ports” tab
Select “add Port…” and then double click on “standard tcp/ip port”.
This will bring you to the add port wizard, click next.
In the field for “Printer name or IP address” enter in the new IP address of your printer and then press next and finally “finished”.
Make sure to apply the changes.
You should now be able to print.
Thank you,
Posted on Mar 29, 2010
SOURCE: OCR with Brother MFC 5440CN
Abbyy finereader 6 works well with the 5440cn. The latest version is 9.
Posted on Apr 24, 2008
lucky1484
  • 90 Answers
SOURCE: cant connect printer to wireless laptop.
have you setup the wireless connection in between the printer and the laptop...
your laptop is working wirelessly with the internet but for making the printer to use it wirelessly the printer should be also a wireless printer.
and if the printer is a wireless printer then you have to setup the connection in between the printer & laptop to work wirelessly.
Posted on Apr 25, 2009
the kowalski
  • 86 Answers
SOURCE: I can not print
You could try to use static ip to remove possible problems with dns retrieving:
  • Set the machine to static ip (Menu -> Network -> WLAN -> Boot Method -> Static).
  • Check the ip number on the machine (Menu -> Network -> WLAN -> IP address)
  • On your PC, go to Control Panel -> Printers
  • Right-click printer, choose Properties
  • Choose Ports and click "Add Port"
  • Double-click on Standard TCP/IP, follow the guide and type in your IP number earlier retrieved.
  • Save settings, press OK and the problem could be solved (if it was due to dns problems).
Also, if it works, you can change the network settings for scanner driver to go to ip address too instead of dns, even if it isn't a problem right now, it could later be.
Posted on Jun 02, 2009
  • 126 Answers
SOURCE: cant finish installing mfc 490 cw printer install on my computer
Sounds like you may ahve the 32 bit version of the driver. Try uninstalling all brother software, then reinstalling the 64bit version from:
http://welcome.solutions.brother.com/bsc/public/us/us/en/dlf/dlf/000000/003600/dlf003657.html?reg=us&c=us&lang=en&prod=mfc490cw_all&type2=1&os=84&flang=8&dlid=dlf003657
Posted on Jul 11, 2009
Cannot clear memory on brother mfc 495 cw
go to the printers and devices near the control panel of the computer , click on printer and see what is printing
cancel any task pending not completed
Sep 30, 2016 | Brother 495CW MFC-495CW Copier/Fax...
Brother fax machine MFC 495 CW won't print a received fax
Hello sir; would you try on another phone jack if still have same problem then replace phone wire.
Nov 01, 2012 | Brother MFC-495cw Color Inkjet All-in-One...
My brother mfc 665-cw is saying offline no matter what I do to try to print wirelessly
Go to system settings and select the 'Printer' option.
Right-click on the printer and enable the 'Use Printer Online' function.
Cancel all the printing jobs till that moment and redo the process.
Sometimes the 'Printer Offline' message occurs due to a 'Job Stuck' issue.
Check all network connections and functions.
Be sure the network interfaces work properly.
Turn the printer off and on to see whether the device is working properly.
Apr 25, 2011 | Brother MFC-665CW All-In-One InkJet...
My brother mfc 495cw keeps giving an "unable to init." error message. chris.iya@lausd.net
Hi. my machine model MFC 495 CW. I did any step but my machine till show up unable to Init. 4 F. please can you help me about that. thanks you very much
Tien
Sep 07, 2010 | Brother MultiFunction Center MFC-440CN...
How to use brother mfc 495 cw wireless to my computer do not have manual
i am trying to install the printer software and it is saying it needs to be configured to the wireless router, HOW DO I CONFIGURE IT TO THE ROUTER? I HAVE A BROTHERS MFC495-CW WIRELESS PRINTER.
Apr 23, 2010 | Brother MFC 420CN All-In-One InkJet...
I get an error trying to install a Brother MFC 495 cw printer.
In my case, decrypting the %TEMP% folder solved the issue (it was encrypted with EFS).
You can find details and more troubleshooting instructions here: http://www.robertnitsch.de/notes/brother_difxdriverpackageinstallerror_5
Dec 27, 2009 | Brother Office Equipment & Supplies
My Brother MFC 495 cw scanner won't work
Hello i just bought a Brother MFC-495CW printer and for the life of me cannot get wireless to connect even though i have setup everything correctly as far as i know. Any help would be appreciated.
Dec 16, 2009 | Office Equipment & Supplies
Networking a Printer on a wireless network
Deanna, if the mfc is not that old, take it back to the dealer and ask for changing it to a wireless printer (extension: CW). Do you really need the fax function? If not, try this printer: DCP 750CW. If yes, get the MFC 845 CW. The CN printer have to be connected directly to router or pc/laptop.
Sep 27, 2007 | Brother MultiFunction Center MFC-440CN...
Brother MFC 7840W Printer Logo
647 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
