Question about Car Audio & Video
Hello, our Ford 6006 cdc will not eject CD's. Tries and can hear whirring inside but no discs come out. Any ideas please?
  • 17,130 Answers
Possible that your changer has encountered a transport failure. You have to remove the set, open the top lid and press ejecct, look for the whining noise, is this a gear slippping or a motor jamming, Please check to see if the small DC drive motor slips INSIDE THE PULLEY.Normally this gets **** and so slips off on load. remove put on glue and refix. If not look out for damaged CD's that has locked inside the set. slowly rettieve them out and check for defects in the cds. replace and start loading with one cd at a time to confirm if there is an alignment defect. Correct for any distortion of any arms/links. Hope this helps, Good day.
Posted on Jul 08, 2010
Code for ford 6006 radio
Sorry i cannot obtain a code reader for the V series as its a random number put into the radio in the factory thus it could be anything the operator felt like .dealer only
Mar 19, 2013 | Ford Transit Cars & Trucks
CDC-735
Part Number VQ776900. I got it online for 99 cents but other places can be up to 7-8.00 dollars. I removed 5 screws on the sides and rear of the case. Took case off. Press the open button and help the drawer open with your hand while the motor tries to. Then remove old belt with pliers or paper clip, etc.
I did not take anything apart on the inside to replace the belt. Push the belt into the player over the larger wheel and then I pulled the belt with a paper clip over the smaller drive wheel.
Mar 17, 2012 | Yamaha CDC-755 5-Disc CD Changer
Tray door sticks when you hit the open button
Hello,this is very common whats happening is the belt is slipping.You can remove the cover and belt and then simply take a q-tip and alchohol and clean the inside of the belt than reinstall it.Note there are 2 belts the one for the door is the one closest to the fron panel.Make sure door is ejected out and than power disconnected first.
Jan 06, 2011 | Yamaha CDC-845 5-Disc CD Changer
Ford radio 6006 CDC, fitted in Fiesta ST, fault discharge battery
Was wondering if anyone can help got a Cdc error on the stereo 6006? Also wondered how to load the cds into the stereo?
Apr 24, 2010 | Car Audio & Video
Ford 6006 cdc cd player wont accept correct code
Either the code is incorrect or you are using the wrong Code Entry Instructions.
To check your code POST ANOTHER QUESTION quoting the  radio`s SERIAL NUMBER  ( can be found on the radio casing or by pressing either buttons 1&6  or 2 & 6 )
It normally begins with M + + + + + + (or V or L or C )
Sep 12, 2009 | Car Audio & Video
Pinout of Round Connector on CDC A08 ?
See this diagram.
http://fileshare.eshop.bg/index.php?what=search2
(search for CDC A08 if link doesn't work)
Basically, 12v to pin '3' (with notch at top, it's the top row, third pin from the RIGHT) and ground to outter jacket of the connector. Push eject button, works a charm.
Cheers.
Mar 27, 2009 | Blaupunkt CDC-A08 10-Disc CD Changer
Code for my FORD 6006 cd
UR RADIO CODE IS 5615 PLEASE RATE THI PLEASE THANX.
Feb 03, 2009 | 2000 Ford Focus
Philips DVP-3020K not eject my CD
hello my friend! my dvd player did the same problem. and i solved this just with a screw driver:) if your dvd player s guaranty finished!! switch off the player and open the screws which r 2 on sides and 3 behind the dvd. open the cover and take off the two group of cables on the chipset which are on the mechanical part side! (mechanical side: dvd driver) than plug the cables again to their socket. its done! close all and go on ! i hope this will solve your problem as mine...
Dec 21, 2008 | Philips DVP-3005 DVD Player
Won't stay closed
even if the laser lense cant process the data being read it should not eject and just display disc error or no disc. That's how it normally does. anyway if is is different from yours, try cleaning the laser lense with cotton bud, dampen a bit with rubbing alcohol, then the other end to dry it. rub it in circular motion please and not too hard or excesiove force on it.
lubricate the spindle motor shaft if you can reach, not too much oil, the very thin type household use only. likewise the traverse mech. the mech is not the source of your problem but since you are lubricating the spindle motor then you might as well lubricate the rest of moving parts. try not to put oil in you platine table and other rotating parts like the rubber belts or you'll find another problem later.
Reden
Dec 12, 2007 | Yamaha CDC-502 5-Disc CD Changer
Car Audio & Video Logo
645 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
