Question about Drills
Help understanding hilti tcu 7/36 charging unit
Where can I find a conecting rod for a Hilti TP-400
Try calling Hilti Customer service (toll-free), or look for a nearby Hilti service center. Contact info for the United States is linked below.
Results for My preferred Hilti Centers
Aug 03, 2015 | Hilti Drills
Wont shift into overdrive
does the heater blow hot air ? if not check the water pump is working also check the coolant level
Mar 25, 2014 | Kia Cars & Trucks
The carbon brush gone i need a replacement
Here is a detail part list from Hilti.
Link HERE to open the drawing and part list.
Please bookmark this page for reference.
The item in question is carbon brush.
This is inter-grade inside item 2 (the electric motor).
Hilti has a life time warranty on labor and two year in parts.
This model was introduced around March 2009.
Check the model plate for production date.
Contact you local Hilti rep to send the unit for free repair.
Act now to avoid the labor charge (2 year FREE labor)
In most case you can use the manufacture t oprove the unit is under 2 years old.
A sales order or receipt of this Hilti SFH 18A will help speed up the repair process.
Additional references
Hilti, Inc.
5400 South 122nd East Avenue
Tulsa, OK 74146 Phone: (800) 879-8000 Fax: (800) 879-7000 Espa?ol: (800) 879-5000
Feb 01, 2011 | Hilti SFH 18A CPC Hammer DrillDriver
I own a Hilti SF 150-A 15.6 volt cordless drill ( non hammer type ). I need a trigger assembly for it. Where can I order one?
As i know Hilti has a free of charge repair or replacement of defective parts; Hilti tools are covered by a lifetime manufacturer's warranty against material or manufacturing.Call them direct at 1-800-879-8000, the only place I know to get parts from is Hilti.
If you need more help come back.Post / thumbs / testimonial are welcome!
Nov 18, 2010 | Hilti Cordless Drill Driver SF 151A 20Ah...
Hilti te2-a both battery's won't charge i haven't used it for a while but it is under 2 years old
IF you live in the US you can send it into Hilti tool repair and let them evaluate your batteries. Or you can take it to any Hilti Center to be checked out. You can call1-800-879-8000 to locate the nearest Hilti Center to you or arrange to send into tool repair.
Jul 15, 2010 | Hilti Drills
I have a Hilti TE 905 AVR the service light came on and it stopped working. Is there a troubleshooting guide to fix and reset this. Also, schematics can be found at:...
If you have the old type TE905, which is the one with the square type handle at the back, the service light will come on for 2 reasons. Either there is a tight bearing which will increase the amount of current used to work the machine. Or more common the carbon brushes need replacing. To reset the light, simply cure the problem.
If you have the newer type TE905 with the large “D” Type handle at the back. It gets a bit more complicated. The service light will come on for the same reasons as mentioned above, but it will also come on after 200 hours of use. It will continue to work for another 50 hours with the light on, then it will shut down completely. This is to ensure that it gets regular service. Once serviced or repaired, it will require resetting. To do this you with need a Hilti optical interface, a PC, and Hilti ODA Software. This is not available to the general public. If your Hilti is less Than 2 years old, call Hilti. They will pick it up, repair it, and send it back to you in 3 working days FREE OF CHARGE. If it is older than 2 years there will be a charge for the repairs.
I hope this helped you. Please leave feedback
Jul 08, 2009 | Hilti Hammer Drill Bit, Te Yx 5/8 In. X 13...
Where is the tcu in a 2002 honda accord
it is the Transmission Control Unit. you have to find the reason why the TCU is flashing the D4 fault code. not replace the unit. have your vehicle scanned for another code. your transmission or transaxle is giving you a warning that something is wrong .
Nov 20, 2008 | 1992 Honda Accord
1992 honda accord d4 indicator light flash
change the speed sensor relay located on yhe gearbox(worked for me.
Jul 16, 2008 | 1996 Honda Accord
Hilti PD30 Laser distance meter
shut the unit off by using the power button then turn it back on holding down the power button unitl the menu is displayed allowing you to turn the beep on/off with the + key and change the units with the - key
Oct 14, 2007 | Optics
Drills Logo
442 people viewed this question
Top Drills Experts
Are you a Drill Expert? Answer questions, earn points and help others
