Question about Minn Kota Endura 30 Freshwater Transom Mount Trolling Motor
I have 5 forward and 3 reverse speeds. My motor goes forward in the reverse and reverse in the forward speeds. Why?
Youve connected the cables incorrectly.....!!! sigh!!! lol
Posted on Dec 10, 2011
Reversing the battery cables doesn't do it?
Posted on Jul 23, 2010
Same problem. Bought motor used. Can't figure it out.
Posted on Jul 17, 2010
Is there no reverse, goes forward but won't go in reverse
Outboard won't go into reverse ?? - General Discussion Forum ' In ...
www.in-depthoutdoors.com > ... > General Discussion Forum
Aug 9, 2006 - 8 posts - ‎7 authors
There's 2 cables that go into my outboard. ... It would have forward just fine but it would not shift into reverse. Assuming it's a wheel boat does the throttle handle go intoreverse but reverse doesnt work or does it not even ... Here are instructions to recover your old idofishing.com or idohunting.com account:.
Boat won't go in reverse - Lake-Link.com
www.lake-link.com/forums/boats-motors/.../Boat-wont-go-in-reverse
Sep 23, 2013 - 4 posts - ‎3 authors
Fishing Boards - Boats & Motors: Boat won't go in reverse. ... Forward seems to be working OK, but reverse just won't engage. ... I'm not sure if this is something at the throttle control end or something wrong at the motor. Any thoughts ... Looks like there'sa piece missing that's supposed to hold that in place.
Help! Will go in Reverse but not Forward gear! - The Hull Truth ...
www.thehulltruth.com/boating.../526873-help-will-go-reverse-but-not-f...
Jul 30, 2013 - 8 posts - ‎5 authors
Whether you're researching a new boat, or are a seasoned Captain, ... and it was notengaging fully into forward gear, but into reverse just fine. ... I'm a little dumbfounded as to why it will lock the prop when it's not running, but won't go into forward gear when it is ... While your there, change out the bellows. Mercury 125 won't go into reverse - The Hull Truth ...
Mar 17, 2014
Mercury 25 Horse Won't Shift into Reverse
Apr 5, 2009
90hp Yamha won't go in reverse & more - The Hull ...
Oct 4, 2007
Boat wont go forward or reverse - The Hull Truth ...
Jun 6, 2006
More results from www.thehulltruth.com
Dec 16, 2015 | Boating
My golden companion 2 Gc 321 goes forward when i push reverse and goes reverse when i push forward
Sounds like the motor cables are in reverse at the controller. Check that the red is in the positive and the black wire is in the negative on the controller.
Aug 12, 2014 | Golden Technologies Golden Companion 2 -...
How to change a travelmate 3 to left handed control
i think you mean forward using left hand, reverse using right hand, if so there should be 1 red and 1 black wire from the motor going to the motor controller if you switch these wires then your throttle should work the way you want but unless there is a speed control pot on the throttle enclosure you may also now run faster in reverse than forward
Mar 29, 2014 | Amigo TRAVELMATE Mobility Scooter ()
Model 2000 fs. Red light flashes when forward or reverse is pushed. hear the motor click when the button is pushed. lost reverse then would not go forward shortly after.
Turn the dial-a-speed down to half-way. If issue continues check motor wiring. The click is likely the brake disengaging - which it should. If motor is okay (under 2 ohms) then you likely have a bad speed pot and/or engager assy.
These are wear items and are usually replaced every 3-5 years.
Sep 26, 2013 | Pride Health & Beauty
Pride GoGo Ultra X battery meter needle
you could have a bad throttle pot o speed pot possibly a key switch problem aswell. Hi I a Phillip the "DFW Mobility Specialist"send me a email at dfwmobilityspecialist@yahoo.com if you live in or near the Dallas Fort Worth area.
Apr 10, 2013 | Pride Mobility Products GoGo Ultra X...
JD mighty mover tractor, 27MHz, 3 function remote 1. forward/reverse, 2. left & right, 3. loader bucket up/down Problem: no forward or reverse, front wheels turn left and right just fine, loader goes...
My son and I took apart the toy as we have the same problem with ours. The green terminal on the motor moves when we apply pressure to it and the motor speeds up considerably. It appears that a weak or bad terminal is the cause of loss of power. We are not sure how to maintain the pressure on this terminal.
We are going to put it back together and see if it works.
Apr 23, 2011 | RC John Deere Mighty Mover Dump Truck
Runs very slow speed forward or reverse. full chg battery
you may need to fit a new battery or the drive motor has burnt out?
if the battery is over 3 years old its past its sell by date and if its been ran fully flat often or left flat that will shorten its life as well,,,
the battery is not to pricy,, you could try testing the motor by hooking up with "jump leads" a car battery just to check the motor is ok,,,
Jul 31, 2010 | Peg Perego John Deere Gator HPX
PEREGO GAUCHO 4.0 WON'T GO FORWARD
Believe it or not but it is the reverse switch not the forwards one that is your problem.
May 22, 2010 | Peg Perego Gaucho Rock'in
Goes in reverse but not forward
hi, that sounds like the scooter
a. the speed pot is faulty (Wig wam) thumb throttle , check just in case there a reverse switch,
b. been taking apart and reassembled incorrectly.
Regards
GeWiz.
Jul 03, 2009 | Pride Mobility Victory 3 Wheel Electric...
Minn Kota Endura 30 Freshwater Transom Mount Trolling Motor Logo
624 people viewed this question
Top Minn Kota Boating Experts
Mike Marcotte
Mike Marcotte
Andrew Taylor
Andrew Taylor
Colin Stickland
Colin Stickland
Are you a Minn Kota Boating Expert? Answer questions, earn points and help others
