Question about Motorola Mobility RAZR V3m Cellular Phone
White Screen I opened my phone and got a text and my phone was fine but there was a gray line on the right side.   I shut my phone and put it in my pocket. 10 minutes later I opened the phone again and it was all white.  What happened?  I didnt drop it or get water damage. I have Cellular Motorola phone. Got the same problem. It started to become grey and bleak. I turned it off and charged. After charge completed I turned it back on and it was still grey. After restart all I got is a white screen. Any ideas?
  • Anonymous Apr 19, 2008
    My phone was working fine when I went to bed, but when I woke up, the screen was blank. I cycled power and then it came up all white. The phone seems to work fine - I just can't see anything on either the external or internal screens. I backed up the contents and then removed the battery for a while, but it didn't fix it.
  • cjmisner May 11, 2010
My problem is closed. Thankfully, my phone still was on warranty so it was replaced. People at the warranty place suggested that the problem might occured because I work in the data center.
Posted on Apr 20, 2008
My panasonic phones (KX-T7731) have the dss buttons on left, and personal speed dial buttons on the right. how do i go about labeling these when they are like...right across from each other?
My default designation label has 24 lines, the top ones in white and the bottom ones in gray. If you left justify the top and right justify the bottom text, you'll get 24 items in.
Here's a simpler way :-) http://public.carl.airpost.net/misc/77xx%20labels.xls
Carl
Jul 18, 2011 | Panasonic KX-T7731 Corded Phone
Iphone screen white, clicks and turns on and off but cant see!
if is not water damage , apple should repair it. If not well open the iphone go to youtube see vid how to open it. turn off iphone open it just pull off #1 and put back in. that's the lcd connector. This should work if not take #1 then #2 and # 3 put all conector back that should work. #1 Lcd conectot #2 is the Digitizer #IS the ligth. If you got gray lines the lcd may be broken.
Apr 04, 2009 | Apple iPhone 3G
Vertical gray stripe on left edge, all pics and text gave a blur
any vertical or horizontal line (any color any size) showing stable on the screen that is the hardware damage at the LCD panel back board ( call panel driver board) . it repair complicate but easy to do change LCD panel (common parts). you need find a PC service dealer to do so.
Feb 07, 2009 | Dell E207WFP LCD Monitor
A series (10) vertical lines on print outs
See Charge roller my be dirty or Catriges PCU Units
Jan 22, 2009 | Ricoh CL3000E Laser Printer
My iphone's screen is white with vertical stripes
try to restore ur fone manually.
that should work
Dec 29, 2008 | Apple iPhone Smartphone
White Screen
replaced the lcd on the phone
Nov 28, 2007 | Samsung C417 Cellular Phone
Convergence not lining up
Sounds like the green is out of focus. If the focus control for the green does not control it enough to make the width the same as the red, then, the lens on top of the green can be adjusted to focus that tube. On the lens, there is a wing nut on a screw to loosen it and move the lens left or right a bit to help with the focus. Hope this helps.
Apr 15, 2007 | Mitsubishi WS-65315 65" Rear Projection...
Motorola Mobility RAZR V3m Cellular Phone Logo
110 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
