Question about Simplex Kaba Ilco Unican L1000 keyless lock
LEVER HANDLE BROKEN OFF KNOB ON FRONT LOCK HOUSING
ILCO UNICAN L1000 LEVER HANDLE BROKEN OFF KNOB ON FRONT LOCK HOUSING ASSEMBLY.. IS REPLACEMENT KNOB AVAILABLE WITH OR WITHOUT LEVER? ie. A ROUND KNOB OR A HANDICAP LEVER?
SOURCE: Bought house from bank and trying to retrive lock combination
I'm trying to remove a unican lock from my door but I can't see how to get the handle off. any suggestions?
Posted on Aug 22, 2009
  • 56 Answers
SOURCE: How do I remove a
Inaert the pointed end of the spanner wrench into the hole in the lever hub (you may need t tighten up the rose temporarily to expose the hole), and depress a retainer to release the lever.
Once the lever is off, remove the two screws that were exposed when you removed the control cylinder and plate,
the lock should come off the door at this point.
Posted on Jan 06, 2011
  • 963 Answers
SOURCE: I have a Simplex Kaba
I believe you can find this to be relevant:
I found this instruction elsewhere on this site ( thanks to pctuneup191):
PROCEDURES TO CHANGE THE COMBINATION OF
SIMPLEX 1000 SERIES CIPHER LOCKS
1.) ENSURE THE DOOR IS OPEN.
2.) INSERT THE DF-59 CONTROL KEY INTO THE COMBINATION CHANGE PLUG ASSEMBLY (ON THE BACK OF THE DOOR) AND UNSCREW THE CYLINDER BY TURNING THE KEY COUNTERCLOCKWISE.
3.) TAKE THE CHANGE PLUG ASSEMBLY COMPLETELY OUT OF THE DOOR.
4.) TURN THE OUTSIDE DOOR KNOB CLOCKWISE ALL THE WAY UNTIL IT STOPS, THEN RELEASE THE KNOB.
5.) PRESS IN THE EXISTING COMBINATION FIRMLY.
6.) INSERT THE SPANNER WRENCH IN THE COMBINATION CHANGE SLEEVE. IT SHOULD INSERT AT THE NINE O'CLOCK POSITION.
7.) TURN THE SPANNER WRENCH GENTLY CLOCKWISE UNTIL IT STOPS AT THE 12 O'CLOCK POSITION. NOTE THE NOTCHES IN THE COMBINATION CHANGE SLEEVE MOVES AS THE SLEEVE IS MOVED.
8.) TURN THE SPANNER WRENCH COUNTERCLOCKWISE BACK TO THE NINE O'CLOCK POSITION UNTIL IT STOPS. REMOVE THE SPANNER WRENCH.
9.) TURN THE OUTSIDE DOOR KNOB CLOCKWISE (ALL THE WAY, UNTIL IT STOPS), THEN RELEASE.
10.) INSERT THE NEW COMBINATION BY PRESSING IN THE BUTTONS. USE AT LEAST three numbers and a maximum of five.
11.) TURN THE DOOR KNOB CLOCKWISE ONCE, ALL THE WAY, UNTIL IT STOPS. HOLD IN THIS POSITION AND CHECK IF THE LATCH IS RETRACTED.
12.) RELEASE THE DOOR KNOB.
13.) TURN THE DOOR KNOB CLOCKWISE ONE MORE TIME TO THE STOP POSITION. AT THIS POINT, THE LATCH SHOULD NOT RETRACT UNLESS YOU USE THE NEW COMBINATION.
14.) REINSERT THE CYLINDER INTO THE BACK OF THE DOOR BY SCREWING IT IN CLOCKWISE WITH THE DF-59 CONTROL KEY (DO NOT OVERTIGHTEN!)
REMOVE THE KEY.
A Df-59 key can be purchased at this site:
http://absupply.net/kaba-access-control-lock-1000-series-key-df59.aspx
The spanner wrench (SMPBC201278 Simplex:SpannerWrench $9.00) referred to can be purchased from this site:
http://www.ckilock.com/Mpage18.asp
Here is the "literature grid" from the KABA website, which has manuals and parts lists for the Simplex mechanical pushbutton locks:
http://www.kaba-ilco.com/access_control/literature/literature_grid_mechanical_pushbutton_locks.aspx?id=13
Here's the website to continue your search:
http://www.kaba-ilco.com/access_control/products/eplex.aspx?id=6
Good Luck!
Posted on Mar 06, 2011
  • 963 Answers
SOURCE: Forgot code to Unican L1000 lock. How can you
PROCEDURES TO CHANGE THE COMBINATION OF SIMPLEX 1000 SERIES CIPHER LOCKS
O'CLOCK POSITION.
maximum of five.
REMOVE THE KEY.
You will find a link to download the manual for your model on this page:
These are PDF files, requiring Adobe Reader to open. There is a link on the same page to download Adobe reader.
Customer service can be contacted from this link:
http://www.kaba-ilco.com/access_control/support_contacts/service_and_support.aspx
  • 963 Answers
SOURCE: We are trying to recode
http://www.kaba-ilco.com/access_control/literature/literature_grid_mechanical_pushbutton_locks.aspx?id=14
Tech Support from this link:
http://www.kaba-ilco.com/access_control/support_contacts/technical_support.aspx
How do I change the handles from right to left?
If you don't have the print instructions for your lock, go to this web page:
On the grid, go across from L1000 to the "Manuals" column & click on PDF, which will download the file of the manual for your lock.
If you cannot open the file to view it, you need to install Adobe Reader first. You can get the download (free) from here:
http://get.adobe.com/reader/
Now you should have the manual for reference.
Someone else who was wanting to change the handle sent me this information:
"I've got a Simplex L1000 series combination that needs the Outside Lever Assembly-Right Hand and Outside Sleeve Assembly changed on it. I have the parts needed but I can't figure out how to remove the Outside Lever from the Front Lock Housing.
I had the original question. For others viewing and needing the answer it's as follows: After looking and removing the internal parts I still couldn't find the solution, so I ended up sending it to a locksmith to replace the parts. They told me later that ALL internal parts from the Front Lock Housing needed to be removed, then rotate outside lever 180 degrees. Using spanner wrench depress the front knob retainer, then outside lever should slide off. Remove Drive Assemply and Front knob retainer from rear of front lock housing. *The key was rotating the lever 180 degrees. Nowhere in the directions was this mentioned nor was it mentioned in the email reply I received from Simplex.. So for all you out there, Good Luck! And make sure to add this key step to your directions."
As you will find in the manual, you need a special spanner wrench for this operation.
Aug 11, 2011 | Simplex Kaba Ilco Unican L1000 keyless...
Iv'e got a Simplex L1000 series combination that needs the Outside Lever Assembly-Right Hand and Outside Sleeve Assembly changed on it. I have the parts needed but I can't figure out how to remove the...
Here is a link to the Kaba Ilco web page which has a grid chart, including the L1000 series lock:
Of particular interest to you will be the Manual (page 10) and Parts List, which shows an exploded view of the lockset. Hopefully this will give you the info that you need.
On the same webpage you will also find a link "Contact Us" for further technical information and parts.
Also on that page is a link to get Adobe Reader. If you don't already have it installed on your computer, you will need it to open the PDF files for the manual and parts list.
Hope this helps. Good luck!
Mar 17, 2011 | Simplex Kaba Ilco Unican 1000 keyless...
Lock has a Best core in the outside handle but door cannot be locked
I recommend that you contact Kaba Ilco directly for technical assistance.
good luck!
Mar 16, 2011 | Simplex Kaba Ilco Unican L1000 keyless...
How do you zero out the Unican L1000 (with levers)? The lock is not responding to the old or new combination.
Yow will find a link to download the manual for your model L1000 on this page:
This will download a PDF file; you will need adobe reader installed to open it. There is a link on this same page to download adobe reader.
http://www.kwikset.com/Customer-Support/Contact-Us.aspx
Feb 14, 2011 | Simplex Kaba Ilco Unican L1000 keyless...
The KABA L1000 Simplex lock that I have won't open from one side of the gate. The master key and correct code will turn the handle, but the latch doesn't engage. The latch will open from the other side...
I recommend that you contact Kaba Ilco directly with your problem.
Feb 02, 2011 | Simplex Kaba Ilco Unican L1000 keyless...
How do I remove a unican L1000 lock from the door? I have the upper lock cylinder out, and used the spanner wrench to remove the ring on the non entry side. How do I get the handle off to remove the lock...
use the other side of the spanner wrench with the point and insert it into the hole in the inside sleeve and you will feel some spring tension.........push in the tool and pull the handle off at the same time.
Jan 04, 2011 | Simplex Kaba Ilco Unican 1000 keyless...
Simplex unican L1000 lock, occasionally the top two buttons do not 'connect' when pressed. Can this be remedied easily?
Nov 11, 2010 | Simplex Kaba Ilco Unican 1000 keyless...
Unican combo lock handles are loose
If the handle has been forced their is a part inside that is broken and it appears as if the handle is loose. I have priced the replacement parts and they were over 75% of  what I could purchase the whole thing for ,so I elected to purchase new and go with the direct replacment model L1000 (Lever) to make it ADA compliant at the same time.
Mar 05, 2009 | Simplex Kaba Ilco Unican 1000 keyless...
Nov 12, 2008 | Simplex Kaba Ilco Unican 1000 keyless...
Simplex Kaba Ilco Unican  L1000 keyless lock  Logo
257 people viewed this question
Top Simplex Locks & Locksmithing Experts
Frank Mangiapane
Level 1 Expert
Michelle Balcom
Are you a Simplex Lock and Locksmithing Expert? Answer questions, earn points and help others
