Question about Magic Chef CTF1826AR Top Freezer Refrigerator
I have a Magic Chef refrigator and it freezes up
I have a Magic Chef refrigerator and it freezes up about every 14 days. I have changed the freezer seal and checked for other air flow. What could be causing this?
Regards,
Tom
  • Magic Chef Master
  • 3,361 Answers
A bad defrost timer located on the right rear.
A bad defrost heater located in the freezer under the freezer floor panel.
Posted on Jul 07, 2010
Testimonial: "Thank you very much..."
I have a Magic Chef MCBR1000W. The recent east coast earthquake shook the freezer door open while I was away on vacation. When I returned three days later, the freezer compartment (open) and refrigerator...
Quite often when the door gets open for a extended period of time the vents in the ceiling of refrig.compantment where the cold air from the freezer enters the ref.section...by looking up in the rear of the ref.ceiling you should be able to see these vents and see if they are frozen..if they are frozen a hair blow dryer will thaw them
Where here in the east coast are ya im 20 miles north of the epicenter in dumfries va
Aug 28, 2011 | Magic Chef CTN1521 Top Freezer...
I have Magic chef Model # CTB1923ARW. We find water all over the refrigerator section. This unit does not have Ice maker
Remove the food and the ice maker from the freezer ( if equiped ) . Remove the rear freezer panel . Using a hair dryer , start in the middle , below the coils , defrosting , until you see the drain hole . Use hot water to help defrost the hole . Once water starts going thru the hole , use a small hose inserted into the hole , and blow thru , to remove any unseen debris in the drain line . Use an ALUMINUM or COPPER solid wire , 14-16 guage , with the insulation completely off , and insert one end into the drain hole as far as possible without any force . Lightly hook the other end over the glass rod (defrost heater) , above the hole . When refrig goes into defrost , the heat will transfer from the heater , to the wire , keeping the hole from freezing up again .
Sep 27, 2010 | Magic Chef Refrigerators
I have a 6-7 year old Magic chef top freezer, refrig which is collecting water each day at the inside bottom of the box, refrigerator section. I notice that a slight drip of water comes thru the middle...
The defrost drain is located just under the cooling coils in the back of the freezer. You will need to unload the food and remove the shelves from the freezer. Take the back panel off from inside the freezer and you will see a hole just below the coils. Flush it with hot water using a turkey baster or small hose. See the link below for more details.
Defrost Drain
Jul 21, 2010 | Magic Chef CTB1821AR Top Freezer...
Magic chef refrig model # MCBR1000W defrost thermostat
RepairClinic.com is a fantastic online site for ordering appliance parts.
Jul 29, 2009 | Magic Chef CTB1821AR Top Freezer...
Side by side Magic Chef refrigerator. Freezer
The fridge gets its cold air from the freezer through a vent between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp ..
Could also be begining of a defrost problem.
Jun 14, 2009 | Magic Chef CTB1821AR Top Freezer...
MAGIC CHEF CTF1920ARA - Freezer works, Refrig. portion does not.
Sounds like a defrost problem. Check to see if there is any frost buildup in the back wall of the freezer. If so, it is not defrosting as it should.
  • possible causes:
  1. bad defrost timer
  2. bad defrost heater (in freezer)
  3. bad thermo switch in freezer
If you don’t know what these are then unplug the machine and let the ice melt in the freezer overnight with the door open. Then try it the next day, if is cooling fine then you need to have a service person replace one of the above items.
Jul 04, 2008 | Magic Chef Refrigerators
SIDE BY SIDE MAGIC CHEF REFRIG
your drain line is frozen. you nee to put hot water down it
Feb 17, 2008 | Magic Chef (CSD2610KRW) Top Freezer...
Magic Chef CTF1826AR Top Freezer Refrigerator Logo
554 people viewed this question
Top Magic Chef Refrigerators Experts
John Tripp
John Tripp
Lawrence Oravetz
Are you a Magic Chef Refrigerator Expert? Answer questions, earn points and help others
