Question about Xerox WorkCentre 52255230 Copier
I have received an error code of 010-327 and I need to know what this is
  • Xerox Contributor
  • 185 Answers
Fuser thermal error. Check for paper wrapped around the rollers, but you will need to replace it.
PN 126K24980
Whit
Item, Inc.
Posted on Aug 13, 2010
Fase7073nwo
Good Afternoon Friend, this is Z. Thank you for your question!
An error code E64 is associated with the heater circuit in the open position. A technician would typically check the heater coils and connections for short circuits to the cabinet to determine if this is the cause of the error code. Depending on the readings, the heater and/or wiring will possibly need replacing. This is not a normal DIY job so you may want to connect with a local servicer to determine the exact diagnosis to help reduce the risk of unnecessary parts. I hope this helps explain the error code you are receiving.
Jun 03, 2014 | Frigidaire FASE7073LW Affinity 7.0 cu ft...
Error light is flashing, can't figure out why, no code
I know this was posted a long time ago but for what it's worth. The error codes are probably turned off. I can tell you how to turn on the error codes if this is still a problem. please let me know.
Dec 05, 2013 | Canon LaserCLASS Fax 710 Printer
Error code 041
wlmbug,
Our receivers can only hold a certain number of timers before some have to be deleted. To fix this message, on most receivers, press the DVR button three times to access "Daily Schedule". From there select 'Timers' then 'Edit Timers'. Once they have been deleted, more can be setup!
If you have any questions, or need further assistance, let me know!
Tommy Faust
DISH Social Media Representative
Sep 30, 2012 | DISH Network Televison & Video
Fix error code 67
Error Message
"Data Call Failure
Error Code : 67
Error Code 67 Registration Failure. Your PCS Vision username and/or password may be incorrect. Please try again."
This error message is an example of the error message you might have received. You may find that your computer is running slower than you first got it. After frequent use, you may also have system crashes or even blue screen of death.
We strongly suggest that you run a quick scan for error code 67 for your PC to check and fix the errors.
Buy Now (Only $34.95)
30-Day Money-Back Guaranteed
What Is Error Code 67? One thing you should know is that when you access the Internet, your system will have some access to the recourses of a remote computer. If the name of the particular network cannot be found, error code 67 will show up to your computer screen. And you will not be able to use the resources provide in the network.
Fix Error Code 67 Error Now! How to Fix Error Code 67? Sometimes, Windows error codes also indicate a faulty hard ware in your computer. It could be a hard ware that has not been installed properly. Or it could also be insufficient free space in your hard drive. When you receive error messages like that, you should go and check the condition of your hard drive immediately in case of further damages.
Now that you know what the causes of error code 67 are, you have to learn to fix the relating problems. To do this, you can take a look at the tips below:
  • Remove files you do not need from your hard drive. You might have stored files in your computer like movies, music or images that you have accessed for a long time. If you do not need these files, you should better delete them from yourcomputer. This will ensures the sufficient free space in your hard drive.
  • Uninstall unnecessary software and disable startup programs. If you have some software that you no longer need, uninstall them from your computer. Besides, too much startup programs will hinder the process of starting up of your system. You could check and disable the programs you do not need in startup.
  • Scan your system in a regular basis. If your computer keeps on giving you error messages and your system performs slower and slower, you should pay attention to the safety of your computer. Chances are that your computer has been infected by virus or Trojan that hinder the efficiency.
  • Clean your registry. If the registry of your computer is corrupt, you would also receive irritating error messages. So you should scan your registry, identify and fix all the errors in your registry.
Jan 29, 2012 | Refrigerators
Error code 4701 for Konica Minolta bizhub pro C6500
- 4701 error
Communication fifo problem error 4702/4701 of 5500;6500;6501 konica minolta mfp printers
1) reseat all connectors in Ipb
2)image memery controle board
Inspite doing all these if the problem persists please reload the firm ware/flash firm ware.
Last one is to replace image memory board only .no need to replace prcb; overall status board; nvram
Jan 09, 2012 | Office Equipment & Supplies
Error code 04ee on Dish network 722 vip HDD,
Hello this is luke. I do not know of any 04 ee error code on dish network. The closest will be 004. Try to check if it is coming from the receiver or from the tv by unplugging the receiver from wall outlet while tv is on. If the code stays, then it is from the tv, if it goes away with the lights on receiver, it is from the receiver. Let me know.
Jan 23, 2011 | DISH Network ViP622 DVR DTV Receiver /...
I am receiving error code 39,012.40:76243 on C2424
Replace document feeder. 004k07270 $390.00
Sep 04, 2009 | Xerox C2424 Copier
Canon i860 error code 5200?
5200 is a printhead temperature error, defective printhead You need a new printhead,
QY6-0049-000 around $40.00
Aug 03, 2009 | Office Equipment & Supplies
I have an error 39 on my LITE-ON DVDRW SHM-165P6S and I dont know what it means
I have done some researching and found the following information about the meaning of the error code you are receiving and instructions on how to fix it. Please let me know if this does not solve your problem or you need further assistance. Another place to check is the microsoft website which gives detailed instruction about fixing the problem also. The error you are receiving could also be known as an error 31 and has some other errors you might receive. Let me know if you need further assistance.
If you do not mind please rate my help after I have helped you fully, I would appreciate it. Thanks
Jul 16, 2008 | Computers & Internet
Error code
The other end cut the received page as it was longer than the
maximum limit. Split the page into smaller pieces, or ask the other end to change their maximum receive length setting, then resend.
Oct 16, 2007 | Ricoh FAX5000L Plain Paper Laser
Xerox WorkCentre 52255230 Copier Logo
1,153 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
