Question about Garden
2.5L : 0.75g = 1L : Xg what is the correct measurement for X? This is the ratio of water to plant food. I think it should be about 0.30g, but my math is terrible. Thanks
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 183 Answers
Correct
Posted on Jul 27, 2010
If direction for plant food mix calls for 15ml per 4 liters of water,what mix ratio for a 1650ml watering can?
1650 ml = 1.650 ltrs
the ratio of 15 to 4000ml(4ltrs) =3 : .0800 ml
8 : 1650 is the ratio
Jul 29, 2017 | Garden
What is the cure for yellow leaf on tomato plants
Usually fungus. You need to plant tomatoes where the sun will dry the overnight dew quickly each day. Don't water at night (water in the morning). Try to water the soil and not the leaves.
Ask your nursery for a fungicide (or if something else is causing yellow leaf in your area). They will know and guide you.
Best set to pull off the dead/yellow leaves to limit cross contamination and spread of the fungus/mold.
Jul 29, 2014 | Scotts Miracle Gro Tomato Plant Food 1.5...
What do wetlands do to animals and plants?
They provide ideal habitat and food for many creatures and plants. There are a great many plants that can live only in areas where there's enough water to support them. 'Marginal' plants need their roots under water at varying levels, while some plants grow entirely under water. Countless animals need wetlands to thrive, from huge moose to insects and tiny crustaceans that make up a vital part of the food chain. Wetlands also clean water of many modern contaminants, even heavy metals.
Jun 17, 2014 | Garden
Clumping palms are dying
check you soil ph sometimes the soil Ph can change. and can cause this. also try some plant food in water. out side plants sometimes need some food over the cold months. also if it gets to cold for to long it can kill the plant off.
Jan 30, 2014 | Lenovo ThinkPad Computers & Internet
Alcogas is 20% alcohol and 80% gasoline.in a motor used up 5liters of this fuel.how many liters of alcohol were consumed ?
The amount of alcohol motor consumed is 20% of fuel (alcogas) which is 20%*5L=(20/100)*5L=(1/5)*5L=1L.
For more information about percentages see this article and this game. For calculating percantages you can also use this online calculator.
I hope I helped you :)
Sep 05, 2011 | Casio FX-300MS Calculator
Can I dilute Scotts Miracle Grow for use in my Ortho dial spray bottle?
Yes, you can use Miracle-Gro Water Soluable Plant Food in the Ortho Dial N Spray hose-end sprayer. Simply set the dial on the Dial N Spray to 4 ounces. The label rate for Miracle-Gro All Purpose Plant Food is 1 tablespoon per gallon of water. To make 8 gallons of finished spray, measure 8 rounded tablespoons of plant food into the Dial N Spray jar and fill the jar with water. Mix thoroughly. Set the dial at 4 ounces. When you have sprayed until jar is empty, you will have applied 8 gallons of properly diluted spray. Hilary@Scotts
Jul 23, 2011 | Garden
Please give instructions - dilution rates for Roundup Amenity 5L . This would be for a small garden
For 5L of water 50ml of roundup can be used. Remember Roundup works by being absorbed by leaves not through the soil so spray in calm weather and shield your plants with a bit of cardboard or plastic if you need to get really close.
Apr 03, 2011 | Roundup "" Weed & Grass Killer
A milk man has a can of milk and he has only two measuring units of 5lts and 2lts. if a customer comes for a milk of 1lt how will the milkman measure it?
Fill The 5l can..
fill 2l can with 5l can...
pour 2l can back into original can...
There will be 1l left in the 5l can...
Oct 28, 2010 | Computers & Internet
What is the proper fuel mixture for a husqvarna chain saw ?
The Correct Fuel Mixture Ratio
All two stroke engine will use a 50 to 1 ratio using today's two stroke oils. I once used an old chainsaw probably from the 1960s, that had a sticker on it that said to use a 25 to 1 fuel/oil ratio, but that would have been using two stroke oils of the time period the chainsaw was manufactured. In that chainsaw I used 50 to 1 ratio with no problems. Today's two stroke oils compared to yesteryears are more efficient at lubricating. It is like comparing today's synthetic motor oil to motor oils of decades ago. All the equipment I use in landscaping, anything from a weed eater, leaf blower, chainsaw, hedge trimmer, use 50 to 1 ratio, and I use all types of makes and models, Stihl, Homelite, Husqvarna, Shindaiwa, and Echo, Sears. I mix up a 5 liter fuel can and use it in all of the equipment for my customers and for my landscaping. To calculate the ratio is simple. For instance , if you have 1 gallon of fuel it is best to break it down into smaller units, like ounces. One gallon = 128 oz. You then divide this amount by the ratio of the mixture which is 50 to 1 (50 parts fuel, 1 part oil). So therefore 128 oz of divided by 50 = 2.56 oz (you would just measure out 2.5 oz ) of two stroke oil. If using metric, say a 5L gas can, you would break this down to smaller units, which would be milliliters. 5L = 5000 ml. 5000 ml of fuel divided by 50 = 100 ml of two stoke oil.
Jul 25, 2009 | Garden
Science
it belongs to the plant which cook food by itself
Jun 04, 2008 | The Learning Company Achieve! Math &...
Garden Logo
60 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
