Question about Canon CLC 1150 Color Copier
E008 0000 Error on Cannon 1150
I own 2 Cannon 1150 printers. A few days ago I needed to refill my cyan toner. After filling I received the E008 error. I went into engineer mode and cleared the error. When the machine warmed up the error returned and despite several more attempts, it still comes back. I have swapped the complete fuser oil assembly units between the 2 printers and the error remains with the machine and not the fuser assembly. Please can you advise me where the problem is
Thankyou
Kevin Baker
  • 1,219 Answers
The problem is somewheare in fixing pcbs.
Probable causes:
• The fixing oil pump driver PCB is
faulty.
• The DC driver PCB is faulty.
• The CPU PCB is faulty.
Try to reconnect all connectors on these pcbs.Or start to swap them from one to another copier, until you discover the cause.
Posted on Jul 07, 2010
ERROR SC682-223 ? Also, Error for CPU cyan at starting.
Memory chip at TD sensor: Communication error
Retry of memory chip communication fails three times after the
machine has detected the memory chip communication error.
?? Damaged memory chip data
?? Disconnected inter face
?? No memory chip on the development unit
?? Noise
Replace the PCU.
Jan 06, 2016 | Ricoh Aficio SP C820DN Laser Printer
IRC3080i. How do I correct error code E000020-0201?
add toner to the cyan. then its a sensor under the hopper unit . its covered in toner needs cleaning
Aug 14, 2015 | Cannon Office Equipment & Supplies
Dell Printer problem
Generic toners often cause this error. Was the cyan you purchased a aftermarket compatible?
Jul 26, 2012 | Dell 5100cn Laser Printer
Error code E 020 0181 How do I clear error code? Cannon 1150 color laser copier
Hi
Error code E 020 0181 means that the patch sensor has turned bad or is dirty, to access this try removing eac dev unit and gently unscrew each top so that the patch sensor window is visible. Also, check whether the toner hopper is overfull, it happens sometimes that the toner motor worm gear splits as a result of the hopper becoming packed tight. This may cause the worm gear to split and break if the hopper is 1/2 full or less. You may need to replace toner motor, part number (FH7-1762-030). If the toner motor is fine, then check whether the web solenoid is activating. Clean the web solenoid and ensure free action. This would clear error E020. If the error still not disappears then make sure that the DC controller is fine and the connections from the controller are fine.
Hope this helps...
Daniel
Oct 11, 2010 | Canon CLC 1150 Color Copier
We have a Phaser 7400. It continues to give us
If you've already changed out the toner cartridge and the problem persists, then it could be several other parts that are either defective, dirty or blocked.
You may want to contact a certified Xerox technician and have them look at the Imaging Unit Agitator Bar and the Low Toner Sensors for Cyan/Magenta. There could also be a faulty toner supply motor.
Sep 10, 2009 | Xerox Phaser 7400/DT Laser Printer
Using the same cartridges for the HL-4070CDW, I refilled the black yellow cyan and magenta cartridges. when I put them all back into the printer, the RED toner life end comes on saying that cyan, magenta,...
There's a window on each end of the cartridges and light shines thru to show when they're empty, your refill toner may not be the right density. If you put a small piece of electrical tape over the windows on the cartridge, the error will go away, but you have to watch print quality to change or add toner.
Aug 11, 2009 | Brother HL-4070CDW Printer
Toner not detect
If you refilled it then yes, you would need to purchase this chip as it is telling the printer that it is out of toner.
Aug 09, 2009 | HP Color LaserJet 2550n printer + HP Color...
Canon IR C3200 Error Code E000020-03C0?
plz tell me reason of e602 code in canon ir c3200
Mar 20, 2009 | Canon imageRUNNER C3200 Copier
Canon CLC 1150 Color Copier Logo
364 people viewed this question
old marine
old marine
