Question about Xerox WorkCentre 4118 Network Kit (098N02176) Print Server
Paper size Mismatch on Xerox workcentre 4118 i cant print
  • Anonymous Mar 26, 2014
    GET /DevMgmt/DiscoveryTree.xml HTTP/1.1 HOST:
    President:
  • 2,072 Answers
Most likely the tray setting has changed, Here is what to check.
  1. Press the [Machine Status] button on the Control Panel. 'Machine Setup' will be displayed on the Display Screen.
  2. Press the [Enter] button.
  3. Press the [Left] or [Right] arrow button until the required tray is displayed, and then press the [Enter] button.
  4. Press the [Left] or [Right] arrow button until the required paper size is displayed, and then press the [Enter] button.
  5. Press the [Stop] button to return to the Standby mode
I am sure you will find one of the tray settings to be incorrect.
If not, click on the printers on your computer, Right click the 4118 and look in the printer properties. One of those settings may be off.
More likely is that the machine settings have changed for whatever reason.
Posted on Jul 09, 2010
2 Suggested Answers
  • 39 Answers
SOURCE: Paper size Mismatch on Xerox
HI wat you can do is Most likely the tray setting has changed, Here is what to check. Press the [ Machine Status] button on the Control Panel..
Posted on Jan 10, 2011
How to solve mismatch paper size on xerox 4118
Set the paper size correctly.
http://www.fixya.com/support/t5246564-paper_size_mismatch_xerox_workcentre Paper size Mismatch on Xerox workcentre 4118 cant print
Mar 06, 2016 | Xerox Office Equipment & Supplies
I need need a picture on how to remove a paper jam in xerox 4118 machine right now please
Well open the printer where you can(the closest point to the jammed paper) attempt to remove the jam by attempting to pull the Jamed paper in the direction it would normally exit the machine.thats about as far as I can get you with the information I have--Good Luck.
Feb 01, 2013 | Xerox WorkCentre 4118 Network Kit - 1 x...
Jan 10, 2011 | Xerox WorkCentre 4118 Network Kit...
Hi - I have a Xerox Workcentre 4250 Printer/Fax and keep getting error code 22-504 (Paper Properties Mismatch). The tray has the correct paper size ... what to do? All the pending jobs are idle ...
Check the print settings on the documents that are idle; they may be an off size rather than the standard and you may have to fake out the printer by "resetting" the paper size to the size of the print jobs; this sounds off but works in may cases. To reset the papersize, pull out the tray and put it back in, manually set the page to whatever it is calling for.
Please let me know if this is not clear,
Good Luck!
Oct 07, 2010 | Xerox WorkCentre M-24 Color Copier
Paper size mismatch is appearing on the screen
if that is when your printing you have to check and be sure the paper tray size is set correctly. You press the machine status button and make sure, tray 1, 2 and the bypass are set to the proper size paper.
Nov 03, 2009 | Xerox WorkCentre M20i All-In-One Laser...
Paper size mismatch
If the paper supply trays have movable edge guides, make sure the guides are against the paper, also insure the paper is oriented the same a s the print job or copy require.
Hope this is of some help.
Ed
May 06, 2009 | Xerox WorkCentre M20 Black and White...
Drivers installation
Here is the web page with your Xerox printer drivers and software:
http://www.support.xerox.com/go/results.asp?Xtype=download&prodID=WC4118&Xlang=en_US&Xcntry=USA
Regards,
Graemevm
Apr 28, 2009 | Xerox WorkCentre 4118 Network Kit...
When trying to print from computers the message comes up paper size mismatch Xerox M20i
double check the paper setting and margins set up on your computer.
check the printer properties
Mar 23, 2009 | Xerox WorkCentre M20i All-In-One Laser...
Xerox WorkCentre 4118 Network Kit (098N02176) Print Server Logo
3,853 people viewed this question
Top Xerox Computers & Internet Experts
Jack McCann
Jack McCann
matt
matt
k24674
Are you a Xerox Computer and Internet Expert? Answer questions, earn points and help others
