Question about LG WD-1280FHD Front Load Washer
My LG WD-1238C 7.5kg front loader is leaking soap bubbles from the soap drawer. It looks like small amounts are still getting into the wash, but not like previously. Why is this?
4 Suggested Answers
guide2u
  • 461 Answers
SOURCE: Soap
How much HE detergent is used can vary from household to household, depending on such factors as water softness level, soil level of clothing, load size, etc. Because excessive suds can cause build up in the machine, leading to decreased cleaning performance, odor and damage to parts, reduce the amount of detergent if sudsing occurs. How do you know when you have gotten all the soap out? Try extra rinse and make use of custom program to perform additional rinse.
Posted on Sep 09, 2007
SOURCE: Front Loader LG Inverter 7.5kg WD-1238C
CL is about the Child Lock which is done by pressing both the buttons together. To release the same do press both the buttons under the display simultaniously.
Posted on Jan 19, 2008
Soap
Sep 09, 2007 | LG WM-2277HW Front Load Washer
I have a LG WD 1238C Front Loader Washing Machine and the display has a CL on it.
Remove power for some time , allow the power to drain off the memory and see if the display is clear. If not hold the start button and switch on power. Check the inlet and drain filter , free water flow, if not remove and clean.
Nov 01, 2013 | LG WD-1280FHD Front Load Washer
Lots of water pouring out on to the floor from the laundry soap dispenser in my front loader and doesn't say any error and when i start it pours out
Disconnect first the mains, power plug off the wall. You could have a clog in your soap drawer; pull the dispenser drawer completely out. There is a tab that needs to be depressed to release the drawer to remove. Clean the soap drawer with an old tooth brush. The usual block could be old soap, softener, etc. (you could also be using too much soap powder). I usually use just above 125ml (my measure cup says ml, I use front loader powder for the 5.5kg load) The wash is very gud. This is the normal issue that will cause water to leak out of the dispenser housing.
Wash the dispenser drawer thoroughly with warm water. Make sure that you pull off the siphon covers and wash all siphon holes. This process is described in your owner's manual. Next could be one of hoses has become loose, should be re-fixed. Examine by removing top of the front loader; this will give you a gud view of the pipes.If helped, click.
Apr 03, 2013 | Samsung WF328AAW Front Load Washer
Water leaking out of soap dispenser?
Mar 17, 2013 | Washing Machines
Simpson front loader washer leaking from front soap drawer on the spin and rinse cycle when filling
Mar 10, 2013 | Washing Machines
I need to remove a drawer front for cleaning.
If this is a front loading washing machine..................Disconnect first the mains, power plug off the wall. You could have a clog in your soap drawer; pull the dispenser drawer completely out. There is a tab that needs to be depressed to release the drawer to remove. Clean the soap drawer with an old tooth brush. The usual block could be old soap, softener, etc. (you could also be using too much soap powder). I usually use just above 125ml (my measure cup says ml, I use front loader powder for the 5.5kg load) The wash is very gud. This is the normal issue that will cause water to leak out of the dispenser housing.
If helped, click.
Mar 02, 2013 | Refrigerators
Electrolux front load washer leaks from soap drawer
This is a common problem with front loaders. Probably poor design.
Jun 23, 2017 | Electrolux AWF 1435 Front Load Washer
WM2277HS front loader , the drawer to put the detergent in is stuck, how do I get it open?
I have slightly different model. Tried the remove the top option. It turned out the the drawer assembly had removable top, removed to two screws that held the assembly in place, uncliped e front assymply drawer handle and cleaned out the soap deposits. Soap build up under dispenser parts had caused the problem. It seems like running the machine a few times might have cleared the soap.
Mar 14, 2011 | LG WM2277HSW XL Front Load Stackable...
LG WD-1280FHD Front Load Washer Logo
47 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
