Dell inspiron 530
Monitor goes blank and comes back on. message reads displaydriver failed and has fixed the problem. this has happened several times. today the top part of the monitor was all lines. This corrected after I restarted the computer. How do I fix this problem
Eileen Maum
  • 20 Answers
Go into control panel and check your display settings. change them to a larger setting if this does not work, try different monitor. Old monitor may not go high enough resolution for your video card. Second try you should disconnect your display and check the video connection pins to see if they are bent or missing.
Posted on Apr 18, 2008
My dell inspiron pc 530 desktop monitor does not come on at all when starting
Check in order:
1 Is the monitor power line connected?
No? Connect it
2 Is the monitor switched on (bezel switch with telltale light)?
No? Find the switch and toggle it.
3 Is the data cable (VGA or whatever) properly connected?
No? Connect it.
4 Does another monitor work on this system?
No? You have bad graphics on your PC. Replace card or PC.
If you answer YES to all those questions, then your monitor is defective. If so your most likely problem is a failed back light. Consider replacing the monitor - the cost of a service call goes a long way to the $100+ you might spend on a replacement.
Oct 15, 2012 | Dell Inspiron 530s Desktop Computer
I have a Inspiron 530... The monitor reads "NO
Hello
You may try another graphic card, it is quite possible the card may not compatible with board, also push the RAM stick to place them properly may the RAM gone dislocated.
Hope it helps
Dec 30, 2010 | Dell desktop and monitor- Inspiron 530...
I HAVE A DELL INSPIRON 530,AND WHEN I TURN THE POWER BUTTON ON PC THE MONITOR JUST GOES BACK TO AMBER AND THE COMPUTER WILL NOT COME ON !!!!
is the computer working can u hear the fan ? if it is working then u might need to change the back cable that is connected to the computer and the monitor
Dec 14, 2010 | Dell Inspiron 530s Desktop Computer...
Monitor intermittently goes blank, esp. after computer has been running for some time. Turning monitor off and on solves for several minutes before it happens again. Bad video card, or monitor problem?
If another monitor is available, then I'd suggest trying one and see if the issue follows the monitor. OR Try this monitor on another system.
If neither option is available, boot the system in the Safe Mode (F8 at boot) and see if the issue occurs in the safe mode. If it does, then I'd say the monitor is the more likely failure point.
If still under warranty, contact Dell, if not, then generally cheaper to replace a monitor than to pay for repairs.
Dec 12, 2009 | Dell Inspiron 530 Desktop Computer
Screen goes blank after hibernation - Dell Inspirion 530 Vista
Turn off vista hybrid sleep and hibernation mode. It causes more problems then it helps.
Jun 25, 2009 | Computers & Internet
Comp. powers on, shuts down three times then goes into powersave
You may want to check the power supply fan whether it works properly or not. Also, you may need to check your BIOS setup if you had done anything with it.
Jun 23, 2009 | Dell Inspiron 530 Desktop Computer
The display driver on my Inspiron 530 keeps failing, the screen freezes/glitches or goes black, then starts functioning again about 5-10seconds afterwards. This can happen several times in a few hours,...
This could be a problem with your monitor, your vga cable or your graphics card, or a combination of those so you need to eliminate them. It would be useful to test your monitor on another machine if possible to eliminate the monitor and cable. Generally Dell also have on their CD's a diagnostics utility that you can boot into to test for example the graphics card. By a process of elimination, you will pin point where the problem is. You could also double check your electrics..!!
Jun 05, 2009 | Dell Inspiron 530 PC Desktop
Restarts or reboots screen reads "diskett 0 drive failure"
1024 X 768 is the ideal setting for a 17" Monitor. Are you still getting sound output despite the error message? If no sound then your integrated sound card has failed, you will have to install anew one in the PCI Slot, otherwise forget about the warning & keep listening. You could try visiting the Official website to see if any driver updates have been released till date and refresh the drivers(sound) installation...............sodeep
PS: Check your Floppy drive? If not working simply disconnect and likewise in the BIOS if REQUIRED.
Apr 10, 2009 | Dell desktop and monitor -Inspiron...
Dell Inspiron 6000 monitor comes on when loading and goes blank
you most likely need a new video card for the monitor
and tell me more info about saving to cd what happened and were you able to do this before and if your getting an error message
Feb 06, 2009 | Dell Inspiron 6000 Notebook
Computers & Internet Logo
David Payne
David Payne
