Question about Vacuums
How do you clean the bissell steamer carpet cleaners suction front? cannot get some of the fuss from that front part. Thank you
    President:
  • 1,673 Answers
Take off the 2 screws at the bottom, and it will lift off so you can clean it. Of course this depends on which model number you have.
Posted on Apr 20, 2008
How can I download Bissell Little Green Clean Machine manual?
direct
https://canada.bissell.com/support
or the first link has it, also videos
  • BISSELL LITTLE GREEN 1400 SERIES USER MANUAL Pdf ...
    www.manualslib.com > ... > Vacuum Cleaner > Little Green 1400 SERIES
    Bissell LITTLE GREEN 1400 SERIES User Manual. ... Vacuum Cleaner Bissell Little Green 1400 SERIES User ... Rcvd a used bissell little green machine w stagnant ...
  • Bissell Little Green Machine ' Walmart.ca
    www.walmart.ca > Walmart.ca > Appliances > Vacuums > Steamers
    • 4.1/5
    • 185 REVIEWS
    • $99.96
    Bissell Little Green Machine for sale at Walmart Canada. ... Powerful suction lifts stains and spots with water or any of the Bissell cleaning solutions.
  • Little Green® Portable Carpet Cleaner ' BISSELL®
    www.bissell.com > ... > Browse By Type > Carpet Cleaners > Portable
    The Little Green® portable carpet cleaner is produced with a minimum of 50 ... Coupon code for purchases on bissell.com: ... (including all accessories and manuals) ...
  • BISSELL LITTLE GREEN CLEAN MACHINE PDF - fenbook.me
    fenbook.me/get-it-free/b/bissell-little-green-clean-machine-manual.pdf · PDF file
    Get Free Read Online Ebook PDF Bissell Little Green Clean Machine at our Ebook Library. Get Bissell Little Green Clean Machine PDF file for free from our online library
  • Bissell Little Green Owners Manual ; Bissell Little Green ...
    www.youtube.com/watch?v=PpQji8obNz4
    • BY BOTHSHOOP
    • 4 MIN
    • 11K VIEWS
    2012-11-07 · Video embedded · Bissell Little Green Owners Manual ; ... Bissell Little Green Owners Manual ; Bissell Little Green Machine ... How to fix a Bissell Carpet
  • Bissell LITTLE GREEN 1400 SERIES User Manual
    May 24, 2016 | Bissell Vacuums
    When bissel turbo steam cleaner wont suck
    google it:
    My ProHeat 2X® is not suctioning properly. What ... - Bissell
    www.bissell.com/faqdetail.aspx?id=1124 BissellAnswer: Let's start by figuring out where your carpet cleaner has suction. Check for ...If the Lint Screen is dirty, the suction won't be very strong. Cleaning the
    Jul 20, 2015 | Vacuums
    Bissel Pro Heat carpet cleaner is not suctioning cleaning water off of the carpet back into the tank. How can I fix this?
    There is a knob on the base that says floor and tools. Make sure that it is closing when you switch it to floor, Make sure that the hose works when you use it too. That will tell us what the problem is.
    Jan 30, 2014 | Bissell 1699 ProHeat Clear View Upright...
    We have lost our instruction book and need help in using our carpet steamer. The model is. 8805 1. 06272101H.....901G. Please send me any info
    http://www.ehow.com/how_8523226_instructions-steamer-turbo-upholstery-cleaner.html?utm_source=dgmodule&utm_medium=1&campaign=momme1Here's another.http://www.ehow.com/how_7405566_use-proheat-turbo-carpet-cleaner.html
    Oct 28, 2012 | Bissell ProHeat Turbo Deep Cleaner Upright...
    Bissell ProHeat 2X(9200) hose to cleaner solution no suction
    There are a couple areas to check:
    1. The black gasket where clearview water collecting unit and the base's front meet. Ensure gasket is in good condition.
    2. Check if you're getting sufficient suction: remove the water collecting unit. When you turn on the the unit, you'll feel suction out of a black hose pointing upwards next to the grey dial. If you're not getting sufficient suction you need to check that all the gaskets are seated properly. there are 3 gaskets: (1) an orange one seated between the black hose and the base unit (2 and 3): On the bottom of the unit there is a removeable panel. This panel has a gasket (red) and inside there is a white gasket.
    Jun 30, 2009 | Bissell 9200 Upright Vacuum
    Bissell carpet cleaner does not have suction like it should
    Try checking the lint filter. It is located in the top clear plastic section (the one with the dial to switch from floor to tool use) and is on the underside. It is a small (1 inch square) red plastic filter with a door on it. Flip open the door and it is probably clogged with hair, carpet fibre, etc.. Clean it out and you should have full suction once again.
    Mar 16, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
    Bissell powersteamer model 1693 not sucking up water
    I have the bissel power steamer / powerbrush # on front at bottom 310-3150 bought in october used it 2 times 3rd time it started acting up as follows
    cleaned all parts. the spin dial wont spin. the switches on both steamer and hand wand won't spray. Sometimes works then stops. Water comes out the bottom when sitting. All parts look fine no damages.
    Jan 10, 2009 | Bissell 1693 PowerSteamer Upright Vacuum
    My carpet cleaner
    There is a black ovule shaped gasket that sits between the top of the window nooze and the edge of the tank. If it is missing, then you lose suction at that point. Also is the filter on the end of the tank that sits over the square outlet clean?
    Mar 22, 2008 | Bissell 1699 ProHeat Clear View Upright...
    Vacuums Logo
    93 people viewed this question
    Top Vacuums Experts
    AskDyson
    AskDyson
    D. Floyd Kolb
    D. Floyd Kolb
    Are you a Vacuum Expert? Answer questions, earn points and help others
