Question about Car APS921 Remote Starter - Keyless Entry
Changed battery in car and now keyless entry dos not work batteries are good.... remotes will not work
    Problem Solver:
  • 11 Answers
Have to reprogram remotes.......see programming remotesi posted is for aps921 and aps901n that remote is the A1BTX
Posted on Jul 26, 2010
2005 Nissan Sentra, the keyless entry locks the doors but does not unlock them.
does your unlock button work in car? If it does, do you have another keyless entry key fob? If so does it work? If you just replaced the battery you can try removing battery and cleaning contacts within remote. I know some of the nissan altimas had the same issue and the only solution was a new key fob. Good Luck
Jan 04, 2013 | 2005 Nissan Sentra 1.8
2008 HHR Remote Starter not working
Is this an issue with all 2008 HHR remotes??? Highly doubtful , probably the vehicles keyless entry system . Taking the vehicle to a qualified repair shop an having the keyless entry system checked for DTC'S - diagnostic trouble code's . Do you know what a DTC is ?
The keyless entry system is a vehicle entry device. The keyless entry system is used in conjunction with the body control module (BCM) to remotely activate certain vehicle features. Keyless entry will lock/unlock the doors, or release the rear compartment lid when a corresponding button on the keyless entry transmitter is pressed. This is accomplished by the transmitter sending a radio frequency to the remote control door lock receiver (RCDLR). The RCDLR interprets the signal and activates the requested function via a serial data message to the BCM. A low transmitter or vehicle battery or radio frequency (RF) interference from aftermarket devices, such as 2-way radios, power inverters, computers, etc., may cause a system malfunction. High RF traffic areas may also cause interference that could lead to a malfunction. Keyless entry allows you to operate the following components:
• Door locks
• Liftgate lock
• Remote rear doors (Panel only)
• Vehicle locator/panic alarm
• Illuminated entry lamps
• Remote vehicle start
The keyless entry system has the following components:
• Keyless entry transmitters
• Keyless entry antenna
• 2 Way Advanced Remote Start RCDLR
• BCM
Guessing will not fix this .
Jan 12, 2018 | 2006 Chevrolet HHR
My turn signal noise is still on sometimes after i've turned, my brights don't stay on, keyless entry not working,and rear defrost not working.
TURN SIGNAL PROBLEM IS THE THE MULTIFUNCTION SWITCH.KEYLESS ENTRY REMOTES NEED NEW BATTERIES.THE DEALERSHIP WILL CHANGE REMOTE BATTERY AND REPROGRAM DOOR LOCKS.CHECK REAR DEFOGGER FUSE AND RELAY.IF BOTH GOOD.YOU HAVE A FAULTY DEFOGGER SWITCH OR OPEN IN THE GRID.YOU CAN BUY A GRID REPAIR KIT AT AUTO ZONE OR ADVANCE AUTO PARTS AND OREILLYS.
Jan 31, 2010 | 2004 Pontiac Grand Am
Keyless Remote Entry Doesn't Work
Hi, Had similar problem and replaced the key fob battery, which was a waste of money because the faulty item was my "door lock actuator".  Had it replaced at a Maryland repair shop for around $180, Honda dealer wanted over $250. Good luck :)
May 29, 2009 | 2003 Honda Accord
How do i program remote keyless entry? I replaced the battery and keyless entry quit working,
You don't normally program a keyless entry, that's done for you by the technicians that install that. If the replaced battery doesn't solve the problem, take the battery and the remote to the techies that installed it.
Mar 27, 2009 | 2003 Chevrolet Monte Carlo
How can I fix my keyless entry --wont work (changed bettery)
my keyless entry does not work and i change my battery for both the remote is there another battery or fuse
Mar 23, 2009 | 2002 Chevrolet Suburban
Keyless entry
Dummy check. Did you put them in with the + on the right side? I also noticed that you said "battery". There are two batteries in mine. if you put one in the place of two the voltage will not be high enough to operate the remote... good luck.
Mar 16, 2009 | 2000 Jeep Grand Cherokee
Keyless Remote 2008 RAV4
You can take it back to the dealer, and have them change the battery, or go to Autozone, buy the battery and do it yourself. They can show you how to do it. And which battery it takes. It's not hard to do. Good luck.
Jan 27, 2009 | 2008 Toyota RAV4
Car APS921 Remote Starter - Keyless Entry Logo
798 people viewed this question
Top Audiovox Vehicle Parts & Accessories Experts
Jim Goldsmith
Jim Goldsmith
xxxxxx xxx
Are you an Audiovox Vehicle Part and Accessory Expert? Answer questions, earn points and help others
