Question about Sybase Adaptive Server Enterprise for Mac OS X 12.5
New install of Sybase v15 errors 30016 stack overflow & 30034
New install of Sybase v15 n to a client site and keeps getting 30016 stack overflow errors and 30034 Data item not found.... This site never had sybase before .. however subsequent install of Sybase to other sites and even before the problem site works just fine + What r your thuoghts
3 Suggested Answers
IB4G2008
  • 3587 Answers
SOURCE: how to develop a tool for conversion the database from sybase to sqlserver
ahh..sudeep...it is a truly glorious day for this work. The detailed solution is to call Larry Ellison, at Oracle, and enquire if you can have his code.
Posted on Apr 23, 2008
SOURCE: ERROR WHILE CONNECTING DATABASE
Hi Ravindra,
send the error log details.
Posted on Jan 19, 2009
"Stack overflow at line 0"
b> A stack is a section of memory where a program stores its variables, calculations, option states and program parameters. When started, a program is allocated some memory to use for the stack; a stack overflow happens when a program exceeds its allocation. The offending program may attempt to write into adjacent memory sections, causing conflicts with other programs. Stack overflows are common with Java, C++, Perl and other runtime environments, which assist in running programs. A stack overflow at line 0 indicates that the offending program tripped up from the start; however, stack overflows can occur on any line number.
Click "Start," "Control Panel, then "Internet Options." Click on the "Advanced" tab. Check "Disable Script Debugging (IE)" and "Disable Script Debugging (Other)" under the "Browsing" options. Uncheck "Display a notification about every script error." Check "Enable Automatic Crash recovery." Click "OK." Download and install a Java update from the Java website. http://www.java.com/en/download/manual.jsp Download and install a Windows update. Hope this helps.
Dec 24, 2012 | Microsoft Windows XP Professional
Microsoft Visual Basic Run-time error ' 28' Out of stack space How to fix it?
Hello and Welcome to FixYa!
Out of stack space means something is continuously loading the data onto the stack and when the stack gets full the it has no more space and throws the exception.
Run-time error '28' is the error code for Stack overflow.
There may be many reasons behind this, it depends on your coding.
You should see this article my Microsoft to get hands on the issue.
I hope you will have a clearer picture after reading that, If you have any Confusion, questions or issues regarding your problem do tell me.
Thank you for using FixYa!, Keep visiting..
If you think I was of help, your token of appreciation in the form of rating and a testimonial will be esteemed.
Concerned, Nooh: FixYa Team.
Jul 13, 2011 | Microsoft Visual Basic
A message just "popped up"
It has to do with memory. When you make requests of your computer programs it puts those requests in a stack (or pile) and then works on them in a predefined order. There's a certain amount of memory reserved for the stack and when you exceed it you get a stack overflow error. These errors usually either kill the request or result in a program crash.
Jan 28, 2011 | Microsoft Computers & Internet
Stack overflow at line 3400
Stack overflow is created by BAD SOFTWARE. When it occurs not only does the
program crash, but depending upon other situations, special code may get called in
such a way as to literally 'take over the system'.
Stack overflow is an exploit that is used by many virus'. As most of these are
intentionally induced by buffer overflow, software updates are the typical fix to
avoid the condition.
1) make sure you have the latest fixes for your browser
2) stay current with MS Update
3) install Spywareblaster to avoid bad ActiveX *.ocx files
Jan 18, 2011 | Sierra Online, Inc. You Dont Know Jack 2
Stack overload at line 48
You hav run out of stack space. This means you have gone into too many levels of subroutines for example and have insufficient storage allocated for the return vectors and variables.
You will have to increase memory available for the stack, or have less levels of subroutines.
You may also hava a re-entrant subroutine that keeps calling itself until the return stack overflows.
Jan 02, 2010 | Computers & Internet
Vivitar freelance V15 digital camera...HELP
OK Tested solution. pay attention please.
1. At this website you may download the Vivitar V15 Manual. http://www.retrevo.com/pdf/23576bh245/2/Introduction#q=Vivitar+V15
2. Notice device driver program PhoTags Express has "Sakar" in upper right corner. Sakar makes "inexpensive" cameras. I chose a camera most similar to V15 and download its Driver here.
http://www.sakar.com/productdetail.aspx?id=2275&categoryid=170
3. Driver install occurs normally with a restart of computer. V15 stil not recognized YET so next.
4.Get to Device Manager = press "Windows" keypad button" & "Pause" keypad button at same time. At system properties Press HARDWARE tab and the DEVICE Manager.
5. Double click camera device (may have yellow ? )
6.click DRIVER tab
7. click UPDATE Driver
8.choose NO, NOT At This Time, click NEXT
9.choose INSTALL from specific location
10. click Don't Search, I WILL CHOOSE Driver to Install
11.choose "Imaging Device"
12. choose DUAL MODE CAMERA (make certain check box has check)
13.Driver for V15 Dual Mode Camera INSTALLS.
14. Click FINISH
15. may have to restart.
16. CAmera should now show in My Computer as Dual Mode Camera
Nov 11, 2009 | Cameras
Box pop up
Stacks are reserved memory that programs use to process hardware events. A stack overflow occurs when there is not enough space in memory to run the hardware interrupt routines.
Basically you have a specific program causing the overflow or a hardware conflict (usually a driver error). find out what the program is, and depending on what it is, see if there is an update on the vendors website (usually if you are getting the error someone else has had the same problem)
Have you just installed a program or a new piece of hardware?
Microsoft has a support doc available that will explain more to you.
http://support.microsoft.com/kb/145799
Let me know if this helps or if you require further assistance
Hope that helps
Aug 22, 2008 | Northgate (STAX2517C2) PC Desktop
Error 232*
Error 232 Severity 16
Error message text Arithmetic overflow error for type %s, value = %f.
Explanation This error occurs when Adaptive Server detects an arithmetic overflow error during execution of a SQL statement. Arithmetic overflows occur when a variable has too few places to store the converted data. In particular, Error 232 is raised when an overflow occurs for a variable of datatype float.
Error 232 can occur during execution of the convert function. It can also occur during implicit conversion within Adaptive Server, either during a stored procedure run or during execution of a SQL statement which converts a float value to some other datatype.
Action Determine which variable is causing the problem based on the datatype reported in the error message output and the SQL statement on which the error occurred. If the error occurs within a stored procedure, an additional error message will be displayed showing the name of the stored procedure and the line number where the error occurred.
Increase the size of the variable that is causing the error. If it is in a procedure, re-create the procedure.
If this error occurs on a Sybase-supplied system stored procedure, contact Sybase Technical Support.
Versions in which this error is raised
Jul 24, 2008 | HP OfficeJet 7310 All-In-One InkJet...
Sybase Adaptive Server Enterprise for Mac OS X 12.5 Logo
274 people viewed this question
Top Sybase Computers & Internet Experts
David Payne
David Payne
Are you a Sybase Computer and Internet Expert? Answer questions, earn points and help others
