Question about Jet 354173 Model Jdp17dx 17 Drill Press
I have a jet 13r drill press and need the chuck
I have a jet 13r drill press and need the chuck taper
  • 10865 Answers
SOURCE: Replace drill chuck on 23 year old Craftsman 8" drill press
Yes it does have a Morse taper and you can remove it by gently hitting it with a rubber or nylon mallet.
Posted on Feb 08, 2009
rowdy45176
  • 2176 Answers
SOURCE: Craftsman Drill Press chuck problem
It is unless there is a tang on the end. What you need to do is thoroughly clean the parts with something like brake clean to remove all the oil and then wipe with a clean paper towel. What I do it put the arbor into the drill press or the chuck onto the arbor and then put a 2x4 on the table and press the parts together or if you have enough room fully retract the jaws and use the block of wood to "tap" the parts to seat them. Let me know if you need more assistance
Posted on Aug 25, 2009
Testimonial: "Thanks rowdy45176. Your solution was spot-on. I cleaned both sides and them , with the chuck jaws fully retracted, tapped it with a plastic mallet"
rowdy45176
  • 2176 Answers
SOURCE: Craftsman 10" bench drill press chuck wobbles
If this is a new tool I would take it back and get it replaced. The only other way to eliminate this problem is to determine if it is the spindle or the chuck and replace the defective unit. Warranty works better.
Posted on Oct 08, 2009
rowdy45176
  • 2176 Answers
SOURCE: Set Ring for a Jet Drill Press
Got it if you still need the part, just found your posting. Go to Waltermeier.com and under shop parts type in your part number and add to cart. The cost is 26.82. Let me know if you need more help
Posted on Oct 13, 2009
Testimonial: "Thanks I'll check it out "
cojon
  • 7 Answers
SOURCE: Chuck keeps falling off drill press
While roughing up with sandpaper might work, but the usual problem that causes a chuck to fall off is a mismatched taper or either the chuck or the spindle has a dirty surface. The tiniest bloom of rust will cause this. Additionally a mismatch of depth will also cause a poor fit. To fit correctly the taper must be correct on both parts and they need to be clean and lightly oiled.
If it is necessary to san these pieces, use a very fine wet or dry paper. I would not use paper beyond 320 and use a light oil such as kerosene or diesel oil rather than water. Check the dept by looking inside at the wear marks. If the inside of the chuck receiver shows wear so close to the bottom that you cannot ascertain any distance between the wear marks and the bottom, the chuck may be bottoming instead of tightening on the taper correctly. You can easily check it with some fine shim material or perhaps three to five thickness of aluminum foil. Cut five thicknesses to fit in the bottom of the chuck (not all chucks have actual bottoms and go clear through) but not on the walls that are tapered. Reinstall, and remove. Is the aluminum foil damaged/show contact marks? If so, did the chuck go on all the way and come off more easily? If so, the problem is bottoming. Bottoming is quite rare but can happen when different than spec chucks are used.
You might also examine the surfaces of both. They should look pristine with no scratches and marks. If not, that could also be the problem. A correct taper fit is difficult to spin, or remove during normal drilling operations.
Posted on Jan 04, 2010
How to fix a out of round drill press chuck (ToolKraft 350B
The chuck could be threaded like an average power drill.
Respectable drill presses use a hollow quill shaft that is likely to be machined into a taper that is likely to be number 1, 2 or 3 Morse taper.
Morse taper drill bits are used a lot - the shank is tapered and will grip and drive when inserted into the quill with just a small force. When the bit is to be removed the quill is turned by hand until a slot in the quill lines up with a slot in the housing and a wedge-shaped steel tool is slid in and tapped breaking the taper fit.
Most such drill presses are supplied with a chuck for light duty drilling already mounted. The chuck is often a Jacobs type mounting by means of a Jacobs taper onto a Morse taper adaptor.
The adaptor is tapered at both ends - at the lower end the taper is steep and the chuck must be pressed on with some force. The upper end will have the same gentle taper of the Morse taper drill bits and is removed in the same way.
Using the chuck drilling is limited to the capacity of the chuck, typically 1/2" or 5/8" unless blacksmith's drill bits are used that have stepped shanks.
Morse taper drill bits will allow heavy duty drilling far in excess of the chuck capacity.
Hopefully your problem is caused by the chuck rather than a bent quill.
Dec 03, 2017 | Drills
Removing chuck from a sears & roebuck model 113.24611 drill press
It is a morris taper wedge fit, so just tap it out.
Dec 29, 2016 | Sears Drills
How do I make the spindle chuck stay in the quill of my model FDM 16 SPC drill press? I have forced it down on a block of wood. It will stay for a while that fall out.
16 speed should have a Morse taper
for the std drill chuck
to fit a different chuck the morse taper needs to be emery sanded
and the replacement chuck should stick
after using the wood block pressure press method
if not you need a new morse taper for that spindle chuck
hint
i had my drill accuracy and off center spin tolerance down to one thou
with stretched old belts I got more speeds than 16
for special jobs
my 16 speed used a morse taper two for the drill chuck
this picture says its a spindle chuck
26313356-3kt1rk2qq1yye1uaamrjudob-5-0.jpg morse taper
Oct 16, 2016 | Drills
Where can i find a 5/8 in. chuck for a Pit Bull CH-16NF Drill press
Take it to a local engineering sales shop. They are all basically the same and fit into the shaft with a morse taper. You just need the correct taper.
  • 5/8 in. Keyed Drill Press Chuck ' Princess Auto www.princessauto.com/en/detail/5-8-in-keyed-drill-press-chuck/A-p...
    • 4.5/5
    • 2 REVIEWS
    Email Signup. Never miss a sale and receive special online only offers.
  • King Canada KDC-58M Chuck, Drill Press, 5/8" JT6 for ... https://eastcoastpowertools.ca/chuck-drill-press-5-8-jt6-for-milling King Canada KDC-58M Chuck, Drill Press, 5/8" JT6 for Milling At East Coast Power Tools
  • 5/8 in. Keyed Drill Press Chuck ' Princess Auto www.princessauto.com/en/detail/5-8-in-keyed-drill-press-chuck/A-p... Help others make a decision about this product by sharing your experience.
  • Related searches for 5/8 in. chuck for a Drill press
  • Woodstock D3455 Drill Chuck, 5/8-Inch by JT33 - Amazon.ca https://www.amazon.ca/Woodstock-D3455-Drill-Chuck-8-Inch/dp/B000HRXOLS This item: Woodstock D3455 Drill Chuck, 5/8-Inch by JT33 CDN$ 47.71. In Stock. Ships from and sold by Amazon.ca. FREE Shipping. ... (Canadian Tire) Drill Press.
  • 5/8 Drill Chuck ' eBay 2q== www.ebay.com/bhp/5-8-drill-chuck Suitable for drill presses or lathes spindle accepts R8 shank. Chuck key and R8-JT33 arbor are also included in the package. Special quenching treated ...
  • 5/8" Drill Press Chuck [MAG-DPC58] - $29.99 : KMS Tools ... https://www.kmstools.com/5-8-drill-press-chuck-2990 KMS Tools & Equipment from Vancouver BC 5/8 ... Home > Metalworking > Lathes and Milling Machines > Chucks and Taper Adapters > 5/8" Drill Press Chuck 5 /8 ...
  • 1 32 5 8 Heavy Duty Drill Chuck with Chuck Key and R8 Arbor Amazon com
    Jun 05, 2016 | Drills
    What size taper is on a delta DP220 drill press so I CAN BUY A 1/2" DRILL CHUCK TO PUT ON IT
    If its possible, pop along to a local machine shop and ask nicely if they could help with identifying the Morse Taper, if its a Morse. Go online for what tapers would have been used around that period. Drill chucks are usually 1/2 UNF mount even if its a late metric unit. You would need a Morse to 1/2 UNF or taper to taper if you buy a taper fit chuck.
    Dec 29, 2014 | Delta Woodworking Vintage Delta Dp 220 14"...
    How do I remove the chuck from my drill press
    Need to know what make and model drill press you have. You could have a taper or a threaded chuck setup. If threaded it would turn opposite drilling rotation and the may be a screw inside the chuck that needs to be loosened/removed and if it is a taper you need a removal tool to pop it out with.
    Sep 21, 2014 | Drills
    The adjustable chuck on my sons Jet JHM-610 comes off when using it in the milling function. What is the best fix for my situation? It is coming off at the taper.
    You should really be using end mill tool holders for milling. The torque is too great for drill chucks. You will get better results machining with surface finish, size as well as longer tool life. Side note..take care with reassembly of drill chuck. Tapers must be dirt and burr free or chuck will have run out as well as taper lock will break and come apart on you more often. If there is damage to the tapers replace the arbor and or chuck with new.
    Apr 29, 2011 | Jet JHM610 Hobby Mill Drill
    Would like to replace the 3/4 Chuck on Jet Drill Press
    Grizzly sells a nice variety of quality chucks at good prices. Look at the numbers on the chuck you have to determine what to buy. You should remove and re-use the taper from your present chuck. You probably have a Morse #2 taper up into the spindle like the picture shown below. I assume you know 92bb256.jpghow to get that out of the spindle. What is not shown in this picture is the taper that is inserted into the chuck. This is probably a Jacobs taper. To separate that you need to support the chuck in a vise with the long taper pointing down. Put something below it to catch it without damage when it falls out. Open the chuck as far as it will go. Get a bolt (about 3/8) that you can hit with a hammer inside the chuck straight down to knock the taper out of the back of the chuck.
    Apr 12, 2010 | Jet 354170/JDP - 20MF 1 Drilling Capacit...
    I have a model 1689 drill press with a 33 taper jacobs chuck I need to remove the chuck to put a larger chuck on is the smaller chuck threaded on and if it is, is it RH or LH thread and how do you hold the...
    you dont hold it, the chuck is a taper fit and you would need wedges to remove it. the newer chuck would also have to have the same taper to work. if replacing the new chuck you would need to make sure the parts are clean, use a brake cleaner and a paper towel to clean them and then they would press together. Let me know if you still need more assistance.
    Jan 13, 2010 | Speed Clausing 15" Variable Floor Model...
    Broken return spring
    Here is a link to your parts manual:
    http://content.wmhtoolgroup.com/manuals/m_354169.pdf
    And here is a link to order parts for you jet drill press:
    http://industrial.jettools.com/Parts.aspx
    Since I don't know exactly what spring you need I can't get you a price. But this should fix you up.
    Mar 31, 2009 | Drills
    Jet 354173 Model Jdp17dx 17 Drill Press Logo
    924 people viewed this question
    Top Jet Drills Experts
    Tom Chichester
    ray gallant
    Are you a Jet Drill Expert? Answer questions, earn points and help others
