Question about Whirlpool Duet GHW9150P Front Load Washer
What does the code F-21 mean and how can I fix it
    President:
  • 1,382 Answers
WhenF21error code appears press PAUSE/CANCEL two times to clear the display.
Also check for the following issues
1. Check the drain hose and make sure it is not plugged or kinked.
2. Unplug washer or disconnect power.
3. Check the electrical connections at the pump and make sure the pump is running.
4. Check the drain pump filter for foreign objects.
5. Plug in washer or reconnect power.
6. If the above does not correct the problem, go to step 7.
7. Unplug washer or disconnect power.
8. Replace the pump.
Thank you !!
Posted on Jul 07, 2010
I have a 1998 Toyota starlet and I have a abs light that wont go away !! fault code 21?? when I turn ignition on it clicks twice under bonnet kinda loud please help me ????
Your anti lock brake system is experiencing a problem. Don't ignore this. have a diagnostic test done at a garage or Toyota dealership to reveal what the test codes mean and what it will cost to fix.
Nov 16, 2015 | Toyota Cars & Trucks
What does the thermador dishwasher dwhd640jfp error code e:21 mean?
E21 Circulating pump blocked.
A blockage between the motor or the pump resulting in insufficient water flow.
Feb 22, 2015 | Thermador Dishwashers
What does Toshiba DVD error code E 21 mean?
It seems to suggest that you are using unsupported media to record on.
Feb 10, 2015 | Toshiba Televison & Video
What does the error code F 21 mean
F 21 indicates a drain problem.... mostly due to a clog. Google
washing machine F 21 code. There are many links including
repair videos. Good luck to you.
Regards,
Dennis
Oct 06, 2014 | Washing Machines
I have a 1997 Dodge Stratus with Check engine codes as follows: Key ON,OFF,ON,OFF,ON codes 12, 34, 21, 55 I understand 12 is recent disconnected battery & 55 is end of test, but can't find definition of...
Jeff: Go to "Allpar dot com" website and look for a complete list of codes for the older Chryslers. From mine I remember code 34 as having at least two posible meanings: a) EGR Solenoid circuit problema, and b) Speed control problema. Code 21 means a problema in the Oxygen sensor. Amclaussen.
Aug 23, 2013 | 1997 Dodge Stratus
95 dodge caravan se code 12 21 55
Well, the code 12 is telling you the battery or the computer has been disconnected in the last 50 starts, code 21 is a problem with the O2 sensor, and code 55 is telling you there are no more trouble codes stored in memory.
Code 21 means the O2 sensor is not switching from rich to lean, which can be a faulty sensor or a fuel problem.
Aug 28, 2012 | Dodge Caravan Cars & Trucks
Checkengine codes 12 21 55
how do I replace an o2 sensor in a 1997 Jeep Cherokee ?
Mar 19, 2010 | 1997 Jeep Cherokee
Error code 21 A1
This means the air intake cover problem.
21
Malfunction of Air Intake Filter Switch Ensure air filter door is properly seated. Ensure front panel is properly installed.
Error codes here: http://www.palomastore.com/paloma_error_codes.html
Mar 03, 2010 | Rheem Paloma Tankless Water Heaters...
IBM Infoprint 21- 651 HW error
Look in Printer Manual (usually in the back) for error codes.
Try cycling power including unplugging AC cord from printer for 1/2 hour.
Apr 25, 2008 | IBM Infoprint 21 Laser Printer
Whirlpool Duet GHW9150P Front Load Washer Logo
103 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
