Fair price to fix central air conditioner leak & refill with freon
Hi there. I have a central air conditioner and was just told that there is no freon in it. The repairman said we have a leak somewhere and he will need to find it, repair it and then refill the system with freon. He already looked for obvious leaks (found nothing) next, he he'll check weld points and do a detailed search to find it. Is there some type of a price range that would be fair for this type of repair. My system is only 5 years old - a Trane XL13i. Thanks!
  • Anonymous Mar 10, 2009
    Exact same problem. They want 1400 to find the leak and refill it. Over 400 just to not fix it but refill it. I told them we needed to think on it. The price sounds outrageous to me!
  • darlinbarb May 21, 2009
    I think I must have called the same service company. Immediately going up on my roof, unscrewing and pointing a tool at it; he told me I have a leak. It would cost about $1200 to find it and fix it, or he can just refill it and see how long it lasts. That cost me 200 for 4# freon, and only 49.00 for the visit. That was sunday the 10th, monday the 18th, it was blowing hot air. He had also mentioned he could change out the entire unit for $1200. He was at my house for about 30 mins in all, including filling out the paper-work. How/where do I get other opinions?
I have heard that there is a spray you can use that will not damage your system and seals the leak when it comes in contact with oxygen
Posted on Apr 09, 2009
Put freon on my central air,4 days later its empty,hotair again coming out of the vent,how do i find the leak.cant afford a new one....help my emial is: smmhgatuz@optonline.net
i appreciate any bodies help...thanks a lot...
Posted on Aug 18, 2009
Make sure that all service caps are tightened with a wrench after refill of freon. I also have a small leak in my AC but it took a whole year for the next refill. A bad AC "professional" just wanted to replace my AC for more money. So he might have loosened the service caps on purpose to let the new freon leak. I'll have to replace the evaporator coil (13 seer) eventually for $1,800.
Posted on Jul 08, 2010
Hole in aluminum base coil of 3.5 ton air conditioner needs repair kit
Posted on May 26, 2011
Does the intertherm polaris need freon recharge?
If it is working ok, no.most small AC units don't even have a place to refill. When a refill is needed it is due to a hole or other damage and must be repaired and a valve added for refilling. Freon will not evaporate or go bad from age. On a car A/C it will leak from a bad or dried out seal or bad valve which a small unit doesn't have.
Jul 20, 2014 | Dometic Rooftop RV Air Conditioner
I dont get cold air from ac. mechanic told me to replace evaporator . he tested using a sniffer inside the car after filling freon. Gave me aquote of about 1600 USD.wanted to know if this is a fair pr
For your make and model that is a way fair price. BMW seems to be a little more labor intensive them some other vehicles. But those recommended repairs are well worth it and help the longevity on your vehicle.
May 08, 2017 | 2000 BMW 323i
When I turned on my Acura TSX A/C, it was blowing hot air, so I took it into the dealership. The customer service rep called me later and told me that I had a leak in my A/C hose that was causing freon to...
I cannot dispute the price the dealership quoted.
That said, a leaking A/C hose cannot be repaired. It needs to be replaced. These are vehicle specific parts so can get expensive. It also costs to vacuum the A/C system and refill with the the system
with freon.
The system ran out of freon because of the leaking hose, put in more freon with the leaking hose it all leaks back out.
So in effect the repair is a new hose, and a refill.
Hope this helps settle your confusion,
Wayne
Mar 13, 2011 | Acura TSX Cars & Trucks
Why the central air conditioner unit run out of freon at all times
it has a leak....freon system is a closed system, and should never run out of freon...leaks are sometimes hard to find.
Jan 25, 2010 | Whirlwind FH-778 Air Conditioner
I purchased an AC of samsung last year in 2008 The guarantee of comprassure is 5 year Now the compressure is out of order and has to be replaced. my problem is the compressure is under guarantte they are...
Hi, you are right, some companies will just replace your compressor, without charge once it's under guarantee, if they replace your compressor and want to charge you to refill your system, it's not fair, because they normally use a system to remove freon from a/c, clean it and reused back in a/c when they replace compressor, if they didn't replace compressor, they can't charge you for freon, because they didn't use , if your system had a leak, yes, they can charge you , for repair of leak, and refilling with freon. good luck.
Aug 03, 2009 | Heating & Cooling
Central air freezing up
Low freon causes this problem. It could be the compressor going bad, but 99% of the time it is that the freon is low, have it leak tested and also have freon added
May 23, 2009 | Heating & Cooling
Lg 2hp split air condition needs original refill gas
hi! there,
well! there several factor to be consider in
insufficient cooling effect,
1. under charge, low charge of freon
how to detect: Check oprerating current
using clamp ammeter ,
clamp on one line and
take reading compare
this to rated current on
manuals if below
your system is under
charge,recharge
freon 22 ,if same is good
check also on sight
glass located on hi side
if bubbles appear your
system is under charge
irecharge if clear still
good.
Freon 22 and others are refrigerant gas and easily evaporate when they escape on athmospheric pressure.they are dagerous to our athmosphere if they expose,they destroy our stratosphere that filter sunlight coming to earth the radio active of sun cannot enter or block by stratosphere if this destroy radio active affect our mother earth.
so in charging freon,they should not escape or leak in our athmosphere take all necessary precaution,there is international law about freon leaking on air,try to update on this issue.
2. evaporator coil and blower should always maintain in obstruction and paricles blocking the fin.if the ice is developed on eveporator this mean evaporator is dirty need to be clean also with fan and blower.they cannot blow air sufficiently due to ice solidified on fin to block air passage.also, on condenser tube fin don let to distored rejection of heat sufficienly help good evaporation of freon .
if fan and blower has insufficient in blowing of air, change bearing, perfomance
will improve in full effeciency.
so cheers and have a nice day to london
guys thank's
Apr 03, 2009 | Panasonic CW-1006FU Air Conditioner
1993 Buick Park Avenue Air Conditioner Leak
Try putting in a.c. leak detector first to pinpoint where the leak is coming from...That can be a costly repair if you take it to a shop especially if you can't find the leak yourself !! Well best of luck..hope this was helpful
Apr 05, 2017 | 1993 Buick Park Avenue
Punctured an air-conditioner Freon line
when the freon is released from the unit,you have to repair the leak,pull a vacumm to rid any moisture in system then refill with freon,if you dont have the equipment,it would be cheaper to just replace the unit
Nov 09, 2008 | Maytag M7Y15F2A Air Conditioner
I have central air and it comes on but blows out air (not cold) and only stays on for a few minutues and then shuts off and continues this cycle
Your central air needs Freon R-22, do not use it, it is going to damage your compressor.
Check the leak first, fix it and fill up Freon R-22 by professional licensed AC person.
Jul 07, 2008 | Heating & Cooling
Heating & Cooling Logo
10,214 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
