Question about Cell Phones
How to reset the dial block in IP1WW-12TXH nec Telephone..after locking in 700-????-1 i forgot my 4 digit number to unlock it.
SOURCE: phone lock code is on,forgot 4-8 digit answer
through it away
Posted on Jul 14, 2007
SOURCE: Locked Phone
just give us the code
Posted on Jan 04, 2008
  • 1257 Answers
SOURCE: i need my 4 digit id code b 4 i can get my puk number but i forgot it
Complete information :
The SIM card protects your subscription and not the phone from unauthorised users. If you change SIM cards you can still use your phone with a new SIM card. Most SIM cards are blocked at the time of purchase. If your SIM card lock is on you have to enter your PIN (Personal Identity Card) every time you turn on the phone.
If you enter the wrong password three times in a row the SIM card gets blocked. This is indicated by the message PIN Blocked To unblock this you need to enter your PUK
Note:
card (Personal Unblocking Key). Your PIN and PUK is supplied by your service provider. You can edit your PIN and select a new four to eight digit number
  • If the Message Codes do not match appears when you edit your PIN you entered the new PIN incorrectly.
  • If the message Wrong PIN followed by Old PIN appears then it means that you have entered the old PIN incorrectly.
To unblock your SIM card:
  1. When PIN Blocked appears enter your PUK > OK
  2. Enter a new four to eight PIN > OK
  3. Re-enter the new PIN to confirm > OK
To edit your PIN:
  1. > Settings > the General tab > Security > Locks > SIM Protection > Change PIN
  2. Enter your PIN > OK
  3. Enter a new four to eight digit PIN to confirm > OK
To turn the SIM card On /Off
  1. > Settings > the General tab > Security > Locks > SIM Protection > Protection and select On or Off
Posted on Jun 24, 2008
  • 7 Answers
SOURCE: locked phone forgot code for vx9800 from Verizon. 4 digit code
did you try the last four of you number
Posted on Jul 20, 2009
  • 9 Answers
SOURCE: forgot my 8 digit password phone lock code. Is
The only way to get into a phone that you've lost the password to is to completely reset it, wiping out all of the data on it in the process.
You can check with your provider and see if they might have a built in solution for forgotten passwords, but typically you'll need to wipe out the phone and start over.
Posted on Dec 07, 2009
Setting date and time on a NEC Phone 1P4WW-12TXH-A-TEL
To set the date and time manually:
1. When the handset is in idle mode, press MENU/ SELECT to
enter the main menu.
2. Press qCID or pDIR to scroll to >set date/time and then
press MENU/SELECT.
3. Press qCID or pDIR to select the month, then press
MENU/SELECT, or enter the number using the dialing keys.
4. Press qCID or pDIR to select the day, then press
5. Press qCID or pDIR to select the year, then press
MENU/SELECT, or enter the number using the dialing keys,
then press MENU/SELECT to move on to set the time.
6. Press qCID or pDIR to select the hour, then press
7. Press qCID or pDIR to select the minute, then press
8. Press qCID or pDIR to highlight AM or PM, or press 2 for AM or
7 for PM. Then press MENU/SELECT to confirm. There is a confirmation
tone and the screen returns to the previous menu.
Apr 11, 2014 | AT&T DECT 6.0 Cordless Phone System with...
Line three comes up busy and says vacant number
There is either no outside line connected to that port on the switch or you do not have access to that line.
Mar 31, 2014 | NEC Dx7na 12txh 80573 22btn Phone...
HOW COULD I RESET THE NEC SL100 PBX SYSTEM?
Download manual from: https://www.manualslib.com/manual/832824/Nec-Sl1000.html?page=531
System Reset on Page No. 2-509 of the manual:
Dial 1 + press HOLD (Press Hold key only to cancel)
Jul 04, 2013 | NEC PABX SL1000
How to deactivate DND?
lift handsetpress dnd button, then press 0
replace handset
Jul 27, 2010 | NEC Lands Phones
Our phone is stuck on Night
Try doing the following: press the CALL 1 key and dial 8181. This should work. Try it from the main phone.
Mar 15, 2010 | NEC Lands Phones
Unlock My Stuff
try the last 4 digits of the telephone number.
If you hard reset, you will return to factory specd ... my stuff will be gone though.
Sep 29, 2009 | Samsung SYNC SGH-A707 Cellular Phone
How to unlock the lock code?
If you didn't change the code the default is the last 4 digits of the telephone number.
If you changed the default code, you can call your carrier and they should be able to reset it for you. Hope this helps.
Aug 14, 2009 | Nokia N73 Cellular Phone
How to I forward incoming calls on my phone to a cell phone 3?
Call forward, off-premise is available on the NEC Electra Professional phone system if you have the Level II system (metal cabinet, not plastic) and you have system software level 700 (7.00) or higher. To get your system software level, press <FNC> - 3 from any display telephone when idle. The procedure to forward is (with phone idle): press <FNC> - dial 60, dial trunk access code (usually - 9), dial telephone number, press <FNC>. Additionally, your station class must be set to allow this feature (by default it is not allowed) and you may need trunk-to-trunk capability turned on in system programming (which is also, by default, not allowed). Hope that all helps.
Dec 30, 2008 | NEC Electra Professional ETW-16DC-2
Cell Phones Logo
305 people viewed this question
Top Cell Phones Experts
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
