Question about Sharp AR-C160 Color Copier
We have sharp-mx2301N it prompting a message collection toner container need to be change?
4 Suggested Answers
SOURCE: Sharp AR-C160 Color Copier Problem
hi im jules_09.its easy just remove the collecting container it must be full with waste toner then just disposse of the waste toner.just open the front door then locate the container its just ther you cant miss it.its a plastic bottle sometimes at the side of the machinre,
Posted on Oct 12, 2007
Bubbabear64
  • 2794 Answers
SOURCE: toner collecting containr of transfer unit
Remove the toner bottle and look for a black sensor. Clean it. Clean out all the toner in the bottle and try copying on it.
Posted on Oct 03, 2008
  • 22 Answers
SOURCE: Sharp MX 2300N - Toner
REPLACING THE WASTE TONER BOX
The waste toner box collects residual toner that is produced during printing. When the used toner box is full, the display
will show "Replace used toner container". Follow the procedure below to replace the used toner box.
Open the front cover.2
Release the used waste toner box.
The waste toner box will fall forward as shown.
Gently support the box with your hands as you let it fall forward
as far as it will go.
fmtx.png Remove the waste toner box.
Hold the box by both hands and lift it up slowly.
If the waste toner box falls too far forward, it will not be possible
to remove it. (Remove the box when it is at an angle of about
30 degrees.)
Install the new waste toner box.
Insert the box from above at a slant. (The direction opposite to
when you removed it.)
Push the waste toner box into the
machine.
Push the box in until it clicks into place.
Close the front cover
Hope this helps.
Posted on Feb 07, 2011
Testimonial: "Many thanks for your fast and accurate advice and solution. We have now ordered this unit and will install as you suggest."
Please help ..i have sharp mx2301n it doesn't work with blank result
Hi Doni .
Have you got a black toner cartridge to swap with the one in the machine ?
May 31, 2016 | Sharp MX-2300N Color Copier
Message the toner bottle is full please call the server machine printing rico 4500
The bottle full message indicates that the waste toner collection bottle is full. The full bottle needs to be removed and the toner disposed of properly. Then a replacement collection bottle needs to be installed and the waste toner counter reset. This site has the toner bottle: http://www.precisionroller.com/waste-toner-containers-for-ricoh-aficio-mp-c4500/details_47769.html . It is possible to reuse the bottles but most people will spill the toner when they try to empty a collection bottle. You do not want loose toner in your environment.
Turn off the printer (at the power switch) and wait for the lights to stop blinking before attempting the replacement. See page 62 of the network guide for the replacement procedure. See https://www.ricoh-usa.com/downloads/downloads.aspx to search for your printer and get the manuals.
I hope this helps
Jul 06, 2015 | Office Equipment & Supplies
Changing waste container
The is no waste container on Phaser 6500. There is a "waste collection box" in every toner cartridge and the waste toner is discarded along with the empty cartridge. The is also a waste toner reservoir on the transfer belt and this one will be replaced along with the transfer belt.
If there is an error message saying, for example, "Waste Full Cyan Cartridge", it means the waste toner counter reached the replacement value for that color and you have to replace the corresponding cartridge. But the waste collection box is not really full.
Sep 30, 2012 | Xerox 6500/N Phaser Laser Printer
Sharp MX 2300N - Toner collection unit needs replacing, not sure what this means. We replaced toner cartridgers very recently and assume this is a container that collects loose toner particles. How do...
30 degrees.)
machine.
Hope this helps.
Feb 07, 2011 | Sharp MX-2300N Color Copier
Change the toner cartridge message doesn't go away on AR-M237
plese check you have changed the same partno toner or not. if its ok you have problem in connector wich hold the toner cartrdge ic
Feb 10, 2010 | Sharp AR-M237 Digital Copier
Panasonic DP C262 replace toner waste container
The waste toner container is the box in the front of the drums, you see it when you open the door its a box that collects used toner. You need to go to pansonic dealership and get a new box to replace the full one.
Sep 01, 2009 | Panasonic Workio DP-3530 Copier
Changing toner cartridge on copier
Open up the large front door, it will swing downwards. At the top section you'll see four boxes with front handles. Each of the boxes is a slide-out container of toner.
Follow the instructions on the new toner box to prepare it for the copier.
You'll note each toner box has a color designation (on a plastic label just above where you grab). Simply grab the handle on the one you need to replace, pull it out and then slide in a new one.
Also note there are four colors: Yellow, Magenta, Cyan and Black. The LCD screen should indicate which toner bottle(s) to replace.
Aug 30, 2009 | Sharp MX-2300N Color Copier
Toner collecting containr of transfer unit
Oct 01, 2008 | Sharp AR-C160 Color Copier
Oct 11, 2007 | Sharp AR-C160 Color Copier
Sharp AR-C160 Color Copier Logo
477 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
