Question about Microsoft Computers & Internet
I m facing problem in excel , when i type 4 numeric number its automatically chnaged in 1 number, i clear all formulas, vlookup. also i unistall n install new office but problem is not resolve pls give me help.
  • 20 Answers
Please tell me the numbers exactly as you enter them and the exact result you get.
Posted on Jul 10, 2010
Dont understand how to use vlookup in excel 2007
This tutorial also helped me much to understand how vlookup works:
http://www.myhowtoos.com/en/excel-howtoos/84-how-to-match-values-in-excel-using-vlookup
Feb 18, 2009 | Microsoft Computers & Internet
How to use vlookup in openoffice using different sheets
=VLOOKUP(A2;Sheet1.$A$3:D27;2;0)
The cell I created this formula in was Sheet 3 Cell C9 - to show the different sheets
A2 is the cell I want to look up
Sheet1.A3:D27 is the range of cells that contains the data I want to return, The first column relates directly to cell C9 is Sheet 3. I locked the first cell in my range as I wanted to apply the same formula across other cells hence the $
2 is the number of the column that has the data I want to return, I had a choice in this formula of 4 columns
0 is the value to complete the formula
Feb 11, 2009 | Microsoft Excel for PC
VLOOKUP Formula
Using IF function or filter to generate the membership type and create a VLOOKUP for that..... Or using filter function you could create a pivot and insert the specific formula per type in that.
Feb 10, 2009 | Microsoft Excel for PC
How to use vlookup
you can a tutorial here.
please rate.
Feb 06, 2009 | Microsoft Excel for PC
VLOOKUP FORMULA PROBLEM
VLOOKUP(A1,Sheet2A2:B20,2,FALSE)
The assumption here is A1 in Sheet 1 is the cell you want to reference, This cell can be pasted - Any problems let me know.
Jan 21, 2009 | Microsoft Excel for PC
Excel formula
I'm assuming you'd like to assign a numerical value to cardinal references (1st, 2nd, 3rd, 4th, etc.).
Best way to do this is to create a quick lookup table on a separate sheet of the same .xls document. Down at the bottom of the page, click on Sheet2 and create a quick table where column A has 1st, 2nd, 3rd, etc. and column B has your values.
Now click back to Sheet1 where your data is and in A2 put this formula:
=VLookup(A1, Sheet2!$A$1:$B$x, 2, FALSE)
Note: replace the lower case x in the formula above with the number of the last row of data in your lookup table on Sheet2.
You can copy and paste this formula down the column to calculate your other values.
Hope that helps!
Terry
Aug 30, 2008 | Microsoft Excel for PC
HELP with macro config
Hi Hss Holdings,
The easiest way to do this is to use a formula called vlookup. You need to have the raw data some where in the workbook, but it can be a separate sheet. Put all the raw data in a table, make sure the account number is on the furthest left column, then start entering the formulas
vlookup(value_to_find, table_to_check, column_index_number, range_lookup(true/false))
value_to_find = the value you want to find on the left most column of the table
table_to_check = the table you want to find the data from
column_index_number = the column number of the data field you want to return into this cell, 1 = the left most column.
range_lookup = false for an exact match, true for the nearest match
Say the table is on sheet2 between A1 and E300
B15 is whatever you type, so no formula needed here
B12 =VLOOKUP(C1,Sheet2!A1:E300,2,FALSE)
G12 = B12 =VLOOKUP(C1,Sheet2!A1:E300,3,FALSE)
etc
Jul 12, 2008 | Excel (SS8SATAS5128400R)
Excell vlookup formula
Suggest you do some debugging in steps:
1. Open the 'bills up to 022908.xls'
2. Use an empty cell to "=CONCATENATE(D3,L3)". That way you can see what values are being generated.
3. Copy the values of that cell and see if you can find them in Col G of 'bills up to 022908.xls'.
Once its broken down into pieces you can usually see "the error of your ways."
Hope this helps.
Mar 09, 2008 | Microsoft Excel for PC
Vloop
Are you referring to the VLOOKUP function in Microsoft Excel?
I love vlookup!
Suppose you have 1 worksheet with song numbers and titles in Row 1, Cols A:B:
Song# Title
123 Love Me Tender
234 Blue Suede Shoes
345 Dixie
Another worksheet has song number and performer in Row 1, Cols A:B
Song# Performer
123 Elvis Presley
234 Carl Perkins
456 Cher
Notice there is NO performer for song number 345 in the 2nd worksheet.
Now in the 1st work sheet, cell C2 insert this LOOKUP function: =LOOKUP(A2,Sheet2!A:B)
Copy that cell to row 3 and row 4 in Col C. You should get a Performer for all songs even though there is not a song number 345 in the performer worksheet.
Help me out Mr. VLOOKUP.
Insert this VLOOKUP function in cell C2 of the first worksheet: =VLOOKUP(A2,Sheet2!A:B,2,0)
Copy that cell to row 3 and row 4 Col C. You should get the performer names for the 1st 2 songs, but not for 345 Dixie. The result should be #N/A.
That means VLOOKUP could not find a DIRECT match for song 345 in the second worksheet.
That is why I prefer VLOOKUP over LOOKUP.
I have found this explaination of the VLOOKUP parameters helpful:
1. Needle (A2)
2. Haystack (Sheet2!A:B)
3. RELATIVE Col containing result (2)
4. Need DIRECT MATCH ONLY (0)
Hope this helps.
Jan 07, 2008 | Computers & Internet
About function
I love vlookup! Suppose you have 1 worksheet with song numbers and titles in Row 1, Cols A:B: Song# Title 123 Love Me Tender 234 Blue Suede Shoes 345 Dixie Another worksheet has song number and performer in Row 1, Cols A:B Song# Performer 123 Elvis Presley 234 Carl Perkins 456 Cher Notice there is NO performer for song number 345 in the 2nd worksheet. Now in the 1st work sheet, cell C2 insert this LOOKUP function: =LOOKUP(A2,Sheet2!A:B) Copy that cell to row 3 and row 4 in Col C. You should get a Performer for all songs even though there is not a song number 345 in the performer worksheet. Help me out Mr. VLOOKUP. Insert this VLOOKUP function in cell C2 of the first worksheet: =VLOOKUP(A2,Sheet2!A:B,2,0) Copy that cell to row 3 and row 4 Col C. You should get the performer names for the 1st 2 songs, but not for 345 Dixie. The result should be #N/A. That means VLOOKUP could not find a DIRECT match for song 345 in the second worksheet. That is why I prefer VLOOKUP over LOOKUP. I have found this explaination of the VLOOKUP parameters helpful: 1. Needle (A2) 2. Haystack (Sheet2!A:B) 3. RELATIVE Col containing result (2) 4. Need DIRECT MATCH ONLY (0) Hope this helps. Let me know if you have any questions.
Aug 27, 2007 | Microsoft Office Standard for PC
Computers & Internet Logo
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
