Question about Gaggia Titanium Espresso Machine
Pressure drop The air pressure is dropped and stopped when activated. It needs a delay time to build up the pressure in order to heat up the milk. Please help
    President:
  • 1,070 Answers
Welcome to FixYa
Here is User Guide for your Product here[Read it Carefully]
You can increase the temperature of your drink anywhere from 10-20 degrees by adjusting the machine’s temperature settings and ensuring that all of your brewing components are preheated properly:
  • If your machine has adjustable temperature, enter into the machine’s menu mode and choose the temperature setting you want.
  • While in menu mode, verify that the rinse mode is turned on. The rinse feature runs a quick dose of hot water through the brew spout upon startup. This helps to warm up the internal components of the machine, and also rinses away any coffee build-up that might alter the taste of your espresso.
  • Run water through your hot water spout and into your cup. This accomplishes two things- It helps to preheat the internal components and it heats the cup as well.
Also check this Link-there is Lot of Troubleshooting for your Model and Solutions[Detailed Instructions]....
I hope you got an Idea Now...thanks for Contacting FixYa
Posted on Jul 07, 2010
Water dispenser sudden low flow/pressure. Bottom freezer KBFA25ERss. I have replaced valves, removed every segment of line and blown them clear from dispenser tip to supply line. Supply pressure and flow...
Sounds to me you have something wrong with the filter and retaining air there. That air must be purged to get the pressure you need from water supply. Double check that water filter I think your problem is there, Thanks Sea Breeze
Aug 17, 2012 | KitchenAid Architect KBFA25ERSS Stainless...
Coleman POWERMATE Lo502710. Compressor runs and builds up pressure and then keeps on running even when 100 PSI. It will not shut off. I do not hear a leak when I pull the electric plug to make it stop...
There is a problem with your pressure switch. You should have a little black box with a red lever to turn your air compressor on and off. This housing contains your pressure switch, the pressure switch sends an electrical signal to the switch to make your air compressor run. When enough pressure builds up the pressure switch activates, and breaks the signal until the pressure drops below a certain point. I will do some more research on your compressor and find out which pressure switch you need to order. i need you to find any numbers on the compressor you can, serial number, model, stock number, anything you can to help me find the part number.
Thank you for patience,
Calvin Smith
Nov 19, 2011 | Coleman Powermate 27 Gallon Air Compressor
My 1999 crown vic is still not building fuel pressure. I've changed the fuel pump and fuel pump relay still not building enough pressure. What else can i try
check or replace fuel pressure regulator. symtoms are. lack of fuel pressure, excessive fuel pressure, black smoke and engine running rich, instant drop of fuel pressure, when turned off delay building back up sufficient fuel pressure. also be sure fuel filter is not plugged. check the filter first !!
Oct 24, 2011 | 1999 Ford Crown Victoria
Porter cable 3hp air compressor 130 psi no model number visible compressor runs builds up pressure and kicks off when the pressure is builded up in the tank// the compressor will not kick kick back on when...
Check to see if the switch will kick in if the pressure is released from the hose going to activate it...if so then the problem is the air being trapped between a check valve and the switch in the hose...
I think that is your problem...
There should be a way for the air pressure to change and represent the tank air pressure accurately....
The different compressors all have different ways of checking the air and then allowing it to release as the the tank pressure decreases..
There is a small hole there somewhere that is clogged with dirt and or oil...find that and clean it and you are in business again...
heatman101
Jul 27, 2011 | Porter Cable Air Tools & Compressors
The radiator was emptied out and i want to add antifreeze and water? there are 2 areas that say antifreeze goes here?
  • One is the radiator and the other is an overflow tank. Sometimes anti freeze will back pressure a bit and need somewhere to go and other times the antifreeze gets low in the radiator. That is the purpose of the radiator.
  • Put the antifreeze in the radiator fist and then add to the reservoir. Pay attention to the cold/hot level fill on the overfill tank.
  • You need to find out where all that antifreeze went to if the radiator was empth. Pull the dipstick and look for a chocolate milk look on the oil. This would be a head gasket or a cracked head.
  • Otherwise keep an eye out for a leak and repair it soon.
  • Hope this helps and thank you for using FixYa.
Regards, Tony
Jun 15, 2011 | Ford F-250 Cars & Trucks
The compressor runs fine and shuts off when the pressure builds up to the appropriate level. When I use air, it tries to kick on to build pressure up again, but it's not able to get started and...
Check the circuit feeding power to the compressor. These conductors may be too small. Conductors have a degree of resistance. Resistance consumes power. The power conductors consume is dissipated as heat and present a voltage drop to the equipment being served. Length and size of the conductors determine power loss.
An electric motor momentarily needs up to six times the running power and this power loss is squared ( PxP) at start up.
The bottom line: Shorten the length of the conductors or increase the conductor size to avoid voltage drop.
Aug 10, 2017 | Craftsman 33 gal Air Compressor 6 hp...
Compressor runs to 175psi but trips pressure relief when pressure drops tries to restart motor but motor wont turn blows breaker. changed whole pressure switch have same problem.
The problem is lilkely the check valve between the compressor and the tank -- it is alowing pressure to build from tank to compressor preventing the compressor from turning over. Clean, maybe replace, check valve...
Charlie
Jan 09, 2011 | Craftsman 25 gal Air Compressor 3 12 hp...
I have a new Puma La5721 and when I adjust the pressure to 120, it drops back to 90 and starts running aagain,after releasing pressure from below the switch box. Am I doing something wrong.
yes buddy it will do your adjusting the stop pressure so say you set it too 150psi once it reaches this pressure it will stop then as the pressure drops to about 120psi the compressore will restart and build to 150 again and you can adjust the starting pressure
Oct 11, 2009 | Air Tools & Compressors
Ec12 hard restart after drop in air pressure
It sounds like the air pressure assembly unit is not reading the pressure drop. some of these units have adjustments under the covers and be reset.
Aug 31, 2008 | Hitachi EC12 Portable Electric 2hp Air...
Open Questions:
See all Gaggia Titanium Espresso Machine Questions
Gaggia Titanium Espresso Machine Logo
35 people viewed this question
Top Gaggia Coffee Makers & Espresso Machines Experts
Henry  Thomas
Henry Thomas
Shehu Pro
Shehu Pro
Are you a Gaggia Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
