Question about Sony QUALIA 005 46 in. LCD Television
Television I want to buy a good quality 50in flat screen television do you have any suggestions?
    Novelist:
  • 135 Answers
Some top brands in no particular order are, Panasonic, LG, Samsung, Sony, Sharp, Toshiba. Bear in mind that within any brand, there are budget models, mid-range and top range models. The LCD panels will range in quality based on their price range. Features will improve with price as well. One top feature is 120 hertz refresh rate leading to very smooth motion. You may not require such smoothness. Size is probably the most overlooked consideration. Take the screen diagonal measure and double it for the closest distance the screen should be from your viewing location. Three times the screen should be the maximum. For a 42" screen it might be 42" x 2 = 84" or 7' minimum and 42" x 3" = 126" or about 10' maximum. Measure your existing viewing distance, go to a Best Buy and stand at that distance to see how it might look in your home. Don't get hung up on precision if you are a few inches outside of these guidelines.
If your viewing area is brightly lit from outside light, favor LCD. If you will be in a dark room, plasma TV's are an option, but they will run hotter, draw more power and will be heavier requiring a substantial mount to wall mount them, not a one man job.
Posted on Nov 11, 2008
I bought my tv three months ago and just moved. The screen is now cracked. It's a 50in JVC LT-50E350 where can I go to get this fixed or can it even be fixed. Please help!!!
having no idea where you live , all I can suggest is check with the place you bought it and see who they recommend for repairs .
Mar 15, 2016 | JVC Televison & Video
Samsung 50in flat screen hss sound nompix.. backlight sppeard on dcreen not all blzck. Any ideaa?
T-Con board controls the picture. It is not working. The board has 2 flat ribbon cables going to the bottom of the screen when you have the back of the TV removed.
Nov 16, 2015 | Samsung Televison & Video
There is no cable screw in jack on tv, how do I hook up tv to cable box
Using an hdmi cable which is the whole point of buying flat screen televisions for the amazing picture quality. They should come with the television but they don't.
Your screw in cable is analogue but your television is now digital. Buy good quality cables with gold flashed contacts. Be prepared for the shock of seeing such a fantastic pin shap picture ??
Oct 06, 2015 | Televison & Video
I need a picture tube for my 50in.Sony t.v . I live in central MI. Need to know where & how , to buy & fix the pic.tube Thank You...
projection screens dont use tubes,a 50 inch tv tube will cost 1000 a new flat screen tv is alot cheaper,buy a flat screen hd ready tv
Apr 16, 2015 | Televison & Video
Why does my 50in vizio cuts off by itself
Please tell me that you didn't REALLY buy a REFURBISHED TV!?!?!?! And a Vizio to boot! The problem with refurbished units is that they rarely get properly tested. Many are returned with intermittent problems that do not show up at the refurbishing center, and thus they are resold with the same defect present. Vizio used to be the YUGO of the TV market. They have gained some credibility, but they still lag far behind the competition for reliability. What you are probably experiencing is a power supply problem, which is the most common problem with flat panel TVs, and a seemingly inevitable problem among Vizios.....usually a week or two after the warranty expires. I hope that you got some kind of warranty with the refurb....many are only 90 days which basically says - good luck sucker!
Mar 06, 2015 | Vizio REFURBISHED E500IBIE 50IN 1080P...
Power light on no video or sound on 50in. flat screen tv
I think somehow that the input is changed. locate the input button on your remote and toggle between all the input to find your lost signal
Oct 13, 2014 | RCA 50in Tv M50 Wh 92s Dlp Hdtv Works But...
Crack screen
It will be cheaper for you to buy a new TV set. Replacement screen most likely will cost more than the price of a new set
May 12, 2012 | Samsung 50 in. Plasma TV
I have a 50in philips. when i turn it on it only has 3/4 of screen. 1/4 on the right side is solid black. any suggestions.
could be a bad ribbon cable conection to the 'X' circuit boards along the bottom of the display panel
Apr 01, 2011 | Philips 50PFP5332D 50 in. Plasma...
My Philips 50in flat screen when turned on goes to the update screen. Software Upgrade Application R0.8.24 the Current software info is EX11U-1.5.0.0_09571 Release for 2nd spin:EX11U-1.5.0.0_09571...
don't open the tv because they have a problem inside your tv and after that if you want .................................................................................later.
Nov 18, 2009 | Philips 42PF9431D/37 TV
SAMSUMG PLASMA 50IN.
I'm afraid you'll have to buy a new plasma screen. The gas inside the screen is a sealed unit and it would have been disturbed by dropping the plasma screen. If the seal is broken then all sorts of funny colours and pictures would show on the screen, and unfortunately it would require a completley new plasma. I wouldnt of thought it would be fixable.
Oct 24, 2008 | Samsung HP-R5072 50 in. Plasma HDTV
Sony QUALIA 005 46 in. LCD Television Logo
105 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
