Question about Audiovox D1730 Portable DVD Player with Screen
Audiovox D1730 portable dvd player with screen...screens goes black when I insert a dvd disc.
  • 6 Answers
SOURCE: Nexxtech N700-PD DVD Player - Discs will not load
Tracking motor has to be replaced
Posted on Jan 04, 2008
  • 146 Answers
SOURCE: audiovox d1708 portable dvd player: DVD spins and says loading...
If it does it with all discs then the player is dying. If it is just the one disc I would say it is a bad disc. You can also see if there is dirt or grease or fingerprints on the laser pickup lens.
Cheers
Posted on Jan 01, 2009
  • 814 Answers
SOURCE: my portable dvd player has sound but no picture on the screen. pl
If you still have use of the on screen menu functions, you can try using the restore to factory setting option in the preferences section of the set-up menu. Press the setup button on the remote control and use the up and down arrows to find and highlight the preferences section, press ok to enter the sub-menu.In the sub-menu use the up and down arrows to find and highlight the default option. Press ok. This will reset the dvd player to the factory settings. If you do not have the use of the on screen menu, you can use the a/v outputs to a external monitor or television to perform the abouve procedure to try to restore the dvd player to normal operation. If all this fails you can call Phillips customer support at this telephone number. 1-888-744-5477 They will be able to help you, either solve your problem or get the dvd player serviced.I hope this information helps you with your problem.
Posted on May 31, 2009
  • 5 Answers
SOURCE: Audiovox D1998 Portable DVD Player will not load DVD
you need to clean the disc and make sure it fits in wright if that dose not work try another disc.
Posted on Sep 15, 2009
  • 5 Answers
SOURCE: Philips PET710 DVD player shows 'no disc' when disc inserted
The safest way , this may sound really stupid but has always worked for me is give it a slightly rough slam on its bottom and it will work , dont judge this badly for it actually wotrks
Posted on Feb 16, 2010
Disc says loading and goes no further
First try different DVD discs. All players of DVD or CD are likely to fail in this way over time. You can try to clean the lens inside the unit, but it may not fix it. Its wise to buy the cheapest replacement, because they never last much longer than a year.
Dec 15, 2013 | Initial 5820 Portable DVD Player with...
Audiovox D1210 DVD won't load to play. When we put in a DVD to play a movie, the screen displays "loading" for a while and then reads "no disc". Using a can of air (and sometimes jolting the player itself)...
Your DVD players may have slip out of calibration. You can try setting them back to factory specifications. To do this go to the set up menu main page. Highlight preferences and press enter.Next highlight defaults and press enter. This will reset the DVD player to the factory settings. This procedure is explained in the owners manual on page 26. If this does not solve your problem, you can try using a cleaning disc to clean the laser head and transport. This should restore the laser, and transport so that you can use it. If you are still experiencing problems with the DVD player, you can call Audiovox customer support at this telephone number. 1-800-645-4994. Give them the model number of you DVD player and tell them about the problem you are having with the DVD player. I hope this information helps you with your problem.
Feb 18, 2009 | Audiovox D1210 Portable DVD Player with...
Audiovox d1708 portable dvd player: DVD spins and says loading...
Cheers
Jan 01, 2009 | Audiovox D1708 Portable DVD Player
Audiovox D1020 DVD player won't read DVD anymore
I have the same problem! The only way to fix this is to replace the motor that spins the DVD. if you take it apart and spin the DVD the movie will play. The motor is just wore out and has no torque to start the play process. I am still looking for a replacement motor for it and haven't found anyone that carries the motor required. Only Audiovox so far and they want 180 to send in and fix.
Nov 16, 2008 | Audiovox D1020 Portable DVD Player
Audiovox D1812 disc loads & plays but VERY dim screen
Sounds like the backlight isn't working, could be the flourescent tube or the inverter that powers it. At least those are the likely suspects in other LCD monitors that have similar problems.
Apr 01, 2008 | Audiovox D1812 Portable DVD Player
Screen reads NO DISC
I had the same problem but I solved buying "Laser Lens Cleaner " Philips Magnavox after 3 attempts the DVD starts to work fine again. First only 3 min, then 10 min and now the entire CD cleaner and after I left the CD cleaner for 15 min I tried to play the DVD and WORKS!!! perfect!!!
Nov 08, 2007 | Audiovox D1420 Portable DVD Player
LG DVP7772 Portable DVD Player with Screen showing disc error
its aged and old, all pordable dvd players stuff up eventually, get a new one.
Jun 14, 2007 | LG DVP7772 Portable DVD Player with Screen
Multiple vertical colored lines on DVD player screen
check this out http://www.techlore.com/forum/thread/12629/
Sep 26, 2006 | Audiovox D2010 Portable DVD Player with...
Audiovox D1730 Portable DVD Player with Screen Logo
Top Audiovox Televison & Video Experts
Jaime Hernandez
Are you an Audiovox Televison and Video Expert? Answer questions, earn points and help others
