A
Anonymous Posted on Jun 24, 2010
I need to change the ip address of my sharp ARM276 network printer and I don't know the user name and password. I need to reset the username and password to their defaults to login. Can someone help with the procedure and what the default username and password is. Thanks.
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Nov 09, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1304
Points
You can't reset password, but you can see admin PIN on printer's display.
Just use simulation 22-7.
You can read about simulations in "service manual".
How do i change my username
You need to go into the setup on your router. There you will find a screen to change the user name and password.
If you are locked out your can reset the router to factory codes by pushing the reset button.
You need to know the IP address of your router and the default name and password provided. This will be found in the users guide.
3answers
Password recovery for ZyXEL3480wfy
ZyXEL Router Passwords
Finding your ZyXEL router's user name and password is as easy as 1,2,3.
  1. Find Your ZyXEL Router Model Number
    Look in the left column of the ZyXEL router password list below to find your ZyXEL router model number.
  2. Find Your ZyXEL Router Username
    Look one column to the right of your router model number to see your ZyXEL router's user name.
  3. Find Your ZyXEL Router Password
    You know the drill. Look another column to the right to find your ZyXEL router's password.
Great! You've found the password and username for your ZyXEL router! What next?
Login to Your ZyXEL Router Using the Router Password
Try logging into your ZyXEL router using the username and password.
Don't Know How to Login to Your ZyXEL Router?
You can login to a ZyXEL router in three easy steps:
  1. Find Your ZyXEL Router IP Address
  2. Enter Your ZyXEL Router IP Address Into an Internet Browser's Address Bar
  3. Submit Your ZyXEL Router Username and Password When Prompted By Your Router
=============== OR: ===============
Forgot Router Password?
If you are having trouble logging in to your router, there is a good chance that your router's user name and password are still set to the default settings.
What should you do?
Login to Your Router Using the Default Router Password
Try logging into your router using the default username and password for your router.
Don't Know How to Login to Your Router?
You can login to a router in three easy steps:
  1. Find Your Router IP Address
  2. Enter Your Router IP Address Into an Internet Browser's Address Bar
  3. Submit Your Router Username and Password When Prompted By Your Router
For more information on how to login to your router please see our Free Guides.
Still can't login to your router even when using the default username and password for your router?
Reset Router Password To Default Settings
(Use this as a last Resort!)
Find Your Default Router Password
Simply select your router manufacturer from the list below to display the default router passwords and usernames.
I do not know my user ID
Your Internet service provider (ISP) requires a username and password to access service features, including Internet and email.
Your ISP should provide this information when you set up your Internet service.
Typically, once you complete the setup and save the information, your router or modem transmits it behind the scenes when you try to access the Internet.
As a result, the username and password can be easily forgotten because they are not used daily. If you reset your router or simply forget the password, gaining access to network resources and the Internet becomes a challenge.
Navigate to your router's Internet Protocol (IP) address using a Web browser, entering the IP as if it were a Web page URL, to view its Web-based configuration page.
This IP address varies by network, but if you run a home network the IP is most likely 192.168.0.1.
Oftentimes there will be an "Account" section where you can view your user name and, if the router's firmware was written poorly, your password in plain text as well.
Look at the original documentation you were given by your ISP.
This documentation often includes your user name and password.
Also, if you use a combined telephone and Internet service, your user name and password are likely identical for both accounts.
Your user name and password may also be the same as your ISP email account.
Check your billing statements.
Some ISPs only require an email address and some personal information to authenticate.
Your billing statement will include additional information, such as your account number, that may be a part of your log in credentials.
Call your ISP and ask them to reset your password. Some ISPs may provide a Web resource for acquiring or resetting your password. Try your ISP's website before you call them.
Lynsksy E1200 tried to reset. my passord and network name are of no assistance. After running software, router is not found. Tried using "admin" for both but nothing works. Please advise. ...
Reset your router back to it's factory settings by holding the reset button for about 5 seconds. I have provided a list of the most popular router brands. If it does not work you may need to google what your specific model's default IP address/default username/default passwords are, for example search for "Encore ENHWI-2AN3 default IP address" The default login info can change, it can depend on where you obtained your router. If you purchased it yourself from a store then the standard defaults should work. If you obtained your router from your Internet Provider you may need to contact your service provider. It also may depend whether it's an old or new model router as well. And you may need to press and hold the reset button on your router several times before it actually clears. Make sure you have a wired connection then once you have accessed your router simply run the Setup Wizard. Set your SSID as something you'll remember like "Mavericks Network" and your Password can be something like your phone number for example 3109876543
Belkin - Username: Leave the field blank Password: Leave the field blank Default IP address is: 192.168.2.1
Buffalo - Username: root Password: Leave the field blank Default IP address is: 192.168.11.1
D-Link - Username: admin Password: Leave the field blank Default IP address is: 192.168.0.1
Encore - Username: admin Password: admin Default IP address 192.168.1.1
Linksys - Username: admin Password: admin Default IP address 192.168.1.1
NetGear - Username: admin Password: password Default IP address will be: 192.168.0.1 or 192.168.1.1
TP-Link - Username: admin Password: admin Default IP address 192.168.1.1
TrendNet - Username: admin Password: admin Default IP address 192.168.10.1
Zhone - Username: admin Password: admin Default IP address 192.168.1.1
Zyxel - Username: admin Password: 1234 Default IP address 192.168.10.1
I keep getting the error 323. I forgot my name and pass to the router and i cant get on the internet through 192.168.1.1 because its not admin i changed that to. can u help and tell me what to do. i have...
1helpful
I have Kyocera Mita KM-2050 Printer/Scanner. The machine has moved networks. I have setup the printing OK but cannot get the scanning to work. I have gone into the panel on the machine & changed the IP...
The NIC card will need to be reset back to the factory defaults if you do not have the user name and password.
If you contact me through www.gfbm.net I will assist you with resetting the scanner over the phone.
Once reset the scanner NIC you will need to re input the IP and all your other scanner information.
I hope this is helpful,
Shawn
Unable to access setup for my linksys by entering 192.168.1.1, not sure whats wrong
For information on how to change your router's password, click here. All Linksys routers have built-in web-based setup pages that allow the user to customize settings and set up advanced properties.
NOTE: Before accessing the router's web-based setup page, make sure the router is powered on and the computer is wired to one of the Ethernet ports on the router (1, 2, 3 or 4 ).
Accessing the Router's Web-Based Setup Page
NOTE: To learn how to reset your device to factory default, click here.
Step 1:
Open a web browser such as Internet Explorer.
3714-015.png Step 2:
Go to the Address bar and enter your router's IP Address ("192.168.1.1" is the default IP of most Linksys routers) then press [Enter].
NOTE: If the IP address of the router has been changed, type the router's IP address in the Address bar instead.
The router's IP address can be changed by:
  • Running the router's setup CD.
  • Changing it on the router's web-based setup page.
If you forgot the router's IP address you can:
  • Check the router's IP address.
  • Press the Reset button at the back of the router for 30 seconds.
NOTE: This procedure will reset your router to factory defaults. Any settings on the router will be erased. The router's IP address will be "192.168.1.1" and the username and password will be "admin" after resetting.
Step 3:
A new window will prompt for a User name and Password, type "admin" (this is the default user name and password), then click OK.
4525-003.png NOTE: If the user name and password of the router has been changed, type the router's new user name and password on both fields instead. In case the router login is forgotten, you will to reset the router.
NOTE: This procedure will reset your router to factory defaults. Any settings on the router will be erased. The router's IP address will be "192.168.1.1" and the username and password will be "admin" after resetting. To reconfigure the router, refer to the links below:
  • To configure the router with DSL ISP, click here.
  • To configure the router with Cable ISP, click here.
1helpful
I have Dlink 615 model router. i reset one time and now i want to change again my name and password but i cant log into. I try admin in with the IP address and also my user name and password but i cant get...
When you reset your router the IP address will revert back to its factory default IP address and access information, if you changed the IP address prior to the reset you will have to use the default IP.
default IP: 192.168.0.1 (make sure that your network cards IP address is somthing similar like 192.168.0.2 and not 192.168.1.2)
Default username: admin
Default pass: leave blank
If you are still having issues let me know.
k24674
ADMIN Andrew
ADMIN Andrew
