Question about Sony DAV-S888 System
It wont power up. The Standby light is flashing
Hi the main amp of the DAV -S888 wont power up.
The Standby light is flashes about 15 times then nothing!
Any suggestions welcome...
2 Suggested Answers
SOURCE: Sony HCD-BC150 As soon as I turn it on, it shuts
Change the audio amplifier IC are on short circuit and that´s the cause your device goes to protect mode
Posted on Aug 11, 2009
Testimonial: "Tell me how to download a sony hcd-bc150 service manual! Your answer was brilliant!"
Mum pressed some buttons on amp now the amp wont respond to the original remote or the universal remote. buttons wont work, batteries good and lights up. is there a button that blocks ir signal?
Looking at the user guide it appears that the amp has a standby mode.
See not below on turning standby on. Question can you see the standby light flashing.
I would also suggest using function on the amp to remove any possible issues with the remote.
One would expect the system to return to normal operation by pressing the power button again. If not what do you see on the display.
Note:
Press 1 to turn on the receiver.You can also turn on the receiver using 1 on the remote control. When you turn off the receiver, press 1 again. "STANDBY" flashes on the display panel. Do not disconnect the AC power cord (mains lead) while "STANDBY" is flashing. This may cause a malfunction.
Jul 08, 2017 | Sony Audio Players & Recorders
TV wont power on, SB light shows one flash
hi no sound or picture usually can be down to the mainboard, corrupted firmware, check the capacitors on the psu board for swollen tops, but they don't have t be swollen to be faulty, thanks
shaun
Mar 18, 2017 | Toshiba Televison & Video
Standby light on, but won't power on
This could be an indication of power suply failure.
Nov 15, 2013 | Koss Audio Players & Recorders
Sony kp53v35 standby light flashing wont power up
The flashing of standby light means that there is a failure on its circuitry. The system cotroller activates the protection mode if one part of the circuitry is gone bad to avoid further damage.Please count the times of flashes after 3 second of interval. The number of flashes helps us to locate the faulty components in circuitry & ill post other details to help you fix your unit.
Feb 18, 2011 | Sony KP-53V35 53" Rear Projection...
Tv wont power up Standby light keeps flashing.
First step in any Sony LCD projector repair is bulb or lamp replacement. Fixes 95% of problems.
Taking apart and trying to measure things without a known good bulb is a waste of time and effort.
easyab
ConvergenceRepair.com
Feb 26, 2010 | Sony Grand WEGA KDF-60XS955 60" Rear...
Sony Trinitron Wega Standby blinks & the TV won't turn on
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
http://homenol.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Apr 12, 2017 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Aug 11, 2009 | Sony DAV-BC150 System
Locked dvd player
Hello, try pressing stop and eject together for 3 seconds. Best regards, Arpi
Jun 17, 2007 | Sony DAV-S888 System
Sony DAV-S888 System Logo
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
