Question about Nokia E71 Smartphone
How to do internet settings manually on nokia e71
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 107 Answers
BEFORE YOU BEGIN, please note the following:
On the Nokia E71 some of VoIP settings are hidden by default, and you will need Nokia's new VoIP SIP application.
This application can be used to configure VoIP settings on your Nokia. You can create new VoIP profiles and modify the existing ones, and create and modify VoIP parameters and NAT/Firewall traversal settings and that are normally not visible on the device UI, such as codec settings and SIP domain-specific NAT/FW settings. It is also possible to save all the VoIP profile settings to a text file. It also enables VoIP over WCDMA which means you can make VoIP call over 3G Internet connection.
Using your PC you can download free Nokia SIP VoIP application from here or you can check Nokia web sitefor latest version.
Extract and install SIS file using Nokia PC Suite software on your PC.
Once installation is complete you will be able to see "SIP VoIP Settings" application under Applications menu on your Nokia, which you will need in STEP 5 of this configuration guide for better voice quallity or enabling VoIP over 3G Internet connection.
Here you can find Nokia E71 SIP settings for voip setup and SIP client configuration guide with VoIPVoIP service.
STEP 1 Go to Tools / Settings / Connection / SIP settings. Create the following profile
Profile Name: VoIPVoIP Service
Profile: IETF Default
Access point: (your WLAN AP name)
Public user name: 5551231234@sip3.voipvoip.com ( Instead of 5551231234 account number example, use the account number assigned to you when signed up for VoIPVoIP service. When recorded your phone will show sip:5551231234@sip3.voipvoip.com )
Use Compression: No
Registration: "Always on "
Use Security: No
STEP 2 You do not need to enter Proxy Server settings
Proxy Server Address: none
Registrar Server:none
Realm: none
User Name: none
STEP 3 Enter the following for Registrar Server settings
Registrar Server: sip3.voipvoip.com (When recorded your phone will show sip:sip3.voipvoip.com)
Realm: voipvoip.com
User Name: 5551231234 (Instead of 5551231234 account number example, use the account number assigned to you when signed up for VoIPVoIP service. )
Password: Enter the password that you chose when you signed up for the service.
Transport Type: UDP
Port: 5060
STEP 4 Go to Tools / Settings / Connection / Internet Tel. Settings
Create a new profile for "voipvoip"(555123xxxx), name it "voipvoip"
Choose "voipvoip" as Preferred profile
STEP 5 For better voice quality or in order to be able to make VoIP calls over 3G internet connection you need to use Nokia SIP VoIP Application you installed.
Go to Applications on your phone and click on "SIP VoIP Settings" application. Choose VoIP services/VoIPVoIP (or the name of your VoIPVoIP account Internet profile.)
Click on "Profile Settings" and find "Allow VoIP over WCDMA" option and change it to "ON" This change allows VoIP over 3G connection on Nokia phones.
For better voice quality go to Codecs and delete all codecs except G729. There should be only G729 codec left under codecs setting
STEP 6 Reboot your phone. Once your phone is back on it will automatically register to VoIPVoIP.
Once it is registered you can start making calls.
Default call type: To switch between normal GSM calls or VOIP calls, navigate to Tools / Settings / Call / Default call type. Select Cellular to make normal calls to the phone number or Internet to use VoIP to call the number or address
Make Calls!
To dial any phone number that is part of the NANP (North American Numbering Plan), you must dial:
1 + Area Code + Phone number
To dial any phone number that is outside of the NANP (North American Numbering Plan), you must dial:
Country Code + City Code + Phone number
For example if you want to call Brazil (country code 55) phone number in Rio de Janeiro (city code 21) you must dial 5521 and phone number. + sign can also be used and number can be dialed as +5521xxxxxxx
BUT RATHER THAN FOLLOWING THESE PLS CALL TO YOUR CUSTOMER CARE THEY WIL GIVE THE SETTINGS. SAVE THEM. THEN FOLLOW THE INSTRUCTIONS. THIS DOES NOT COST ANY COST. PLEASE TRY THIS
Posted on Jul 07, 2010
3 Suggested Answers
  • 78 Answers
SOURCE: IWANT INTERNET SETTINGS FO G FIVE E71
please say your service operator. u can manuallly set ur internet settings. u just need to assign ur access point. u can get that from your custo0mer care
Posted on Feb 15, 2010
ss_sudeep
  • 79 Answers
SOURCE: internet settings for nokia e71
Talk to your customer care of your service provider for internet settings.. they will send some settings.. save it and then u can access internet on your mobile...
Posted on Mar 23, 2011
How can I activate my GPRS on my phone?Globe
-Hi,
To set up your internet connection in your Nokia E71 click here
Hope this help, please rate and leave a comment if the infimation was helpful, thanks!
Aug 27, 2011 | Nokia E71 Smartphone
Internet settings for nokia e71 chines phone
Mar 23, 2011 | Nokia Cell Phones
My nokia phone doesn't have mms, intenet and GPRS settings
hi, most nokia phones dont come with internet setting... what you need to do is to call your network service provider for the inernet setting...the setting will allow you to send mms and also browse the internet with your phone.
cheers
Mar 08, 2011 | Nokia E71 Smartphone
I have nokia E71 dual sim card from China and it is failing to connect to the internet.
If you haven't got the settings configured in the access point menu you may need to get it manually done. Check out for the settings in the menu go to connectivity and then go to data settings then to access point names. check if the settings exist. if it doesn't then just call up the customer care office of the operator they would help you manually setting the access point up.
Mar 01, 2011 | Nokia E71 Smartphone
I have nokia e71 when i download skype or any other files then after finish the downloading when i apply for instal the file but my phone can not instal...its show this word ( certification maybe not yet...
you should set Online Certificate Check to "OFF" to rectify the issue.
You can set it OFF by doing the steps below:
1. Menu
2. Settings
3. Phone Settings
4. Applications
5. App. Manager
6. Set Online Certificate Check to "OFF"
7. "Software Installation" should also be set to "ALL"
another way is;
1. Menu
2. Settings
3. Phone Settings
4. Data Manager
5. Application Manager
6. Options
7. Settings
8. Set Online Certificate Check to "OFF"
9. "Software Installation" should also be set to "ALL"
After you have done the steps above, clear your phone's web browser's cache:
1. Menu
2. Internet
3. Web
4. Options
5. Clear Privacy Data
6. Cache
After which, turn off and on phone then try to install application again.
Feb 25, 2011 | Nokia E71 Smartphone
Hey there. i just bought a m mobicel e71 pro and now i cannot seem to access internet. please he me. thank you.
Boss, if you have NOKIA E71, then you have to put the settings to avail internet. The said settings will be available on request from the customer care center of which service provider line you are using. try this and enjoy the mobinet...
Jan 05, 2011 | Cell Phones
I have many problem with my nokia e71 chinois 1/invalid sim 2/imei introuvable 3/i can't find his atf box 4/can't connect to internet
it may be due to network lock, contact service provider if it locked , you can get unlock codes here http://www.wickedunlock.com/nokia-e71/rs11wp9/
you need to specify the country and network provider,type *#06# to get imei ,check settings,try gprs function to connect internet
Dec 22, 2010 | Cell Phones
Nokia E71 Smartphone Logo
815 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
