Question about Dryers
BEKO DRCS 68 S Dryer- will not start... cleaned filters, emptied water, adjusted setting to correct time (although have tried them all!) Press start... 'beep beep' and nothing... tried holding down the two buttons as is normal reset procedure... 'beep beep' and nothing... turned off at mains, started again... re-cleaned ALL filters... press staart ... 'beep beep' guess what... you guessed it- nothing! Only light that is on is the green 'start' light. A little help please? Soggy clothes not comfortable! :)
JR JR
  • 116 Answers
SOURCE: Kenmore Elite HE3 Dryer (3 yrs. old)
when u push the buttons do all lights light up if so ,, machine is in lock mode ,, press and hold the little icon that read lock for about 3 seconds unitll lights are off then run ,, let see
Posted on Nov 30, 2008
mark_37388
  • 100 Answers
SOURCE: new whirlpool dryer duet steam wont work
Sound like the unit doen't know the door is closed the door switch is not working. does the light inside the drum come on when the door is open and off when the door is closed
Posted on Mar 30, 2009
  • 9 Answers
SOURCE: Dryer won't start when start button is pressed and held
check door "close"contact button/switch usually the culprit..
Posted on Aug 02, 2009
  • 65 Answers
SOURCE: beko drcs 68w the sensor stops the drying process
you have a bad sensor...try just using timed dry
Posted on Jan 17, 2010
heatman101
  • 43501 Answers
SOURCE: Start button will not initiate on cycle. Get 3 beeps.
There can be many reasons why your dryer2_bing.gif will not turn...
This tip that I wrote will help you to figure out what is happening...
Dryer2_bing.gif Repair - The Dryer2_bing.gif is not Turning
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
Dryer2_bing.gif Repair ? The dryer2_bing.gif will not start
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
Posted on Jun 21, 2010
Beko Dryer model DRCS 68W
First unplug power cord for a min and see if it will reset cycle
Jan 09, 2018 | Dryers
I have a beko 4311w dish washer that wont empty. i emptyed the water manually and have checked all filters and hoses and all seemed to be clean.then switched back on and machine completed one complete...
The motor runs in one direction to wash and the opposite direction to pump out the water. Look at the motor direction controls to see what is starting to fail.
Jan 03, 2015 | Beko Dishwashers
Beko drcs 68 w cond dryer 3 yrs old an electrical trip sound followed by a burning wire smell
It could very possibly be that some of the lint has migrated thru the cracks of the lint "tunnels" and settled down around the heating element. Danger Will Robinson! Learn how to remove the front cover/door or back side and inspect for loose lint. It is normally lots more accumulated than you could imagine.
Nov 07, 2014 | Dryers
Beko dryer
i have had this problem and its usually the pc board is faulty
Mar 28, 2014 | Dryers
Got a beko condenser dryer drcs 76w drys clothes but water doesn't go into draw comes out under machine
Sounds like the hose has come loose at the drawer and so it's just pushing water directly down on to the floor, check your owners manual to see how to access the water resiviour.
Dec 05, 2013 | Dryers
My beko drcs 76b tumble dryer isnt heating up
First turn of the breaker, then back on. Check the wiring from the plug at the receptacle to the back if the dryer. You should find your problem there. Then next is the element. See if the wiring is ok to the element. Next visually check the element for
Mar 10, 2013 | Dryers
Our tumble dryer has stopped working and has the display "water tank full" but it is actually empty.
It appears that the water level sensor has failed. You will need an OHM meter to determine if it has failed or not.
Jan 21, 2013 | Dryers
Beko DRCS 68W tumble dryers drum is not rotating (spinning), heating, drying is working
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Aug 27, 2011 | Dryers
Hello I have a Beko CRS 68 W condenser dryer (18 months old). I have cleaned out filter and Big unit at bottom ( Which I think is the Heater Exchange unit ) as instructed - However when we put a fresh load...
Clean the exhaust line connected to the rear of the dryer.
Run a load of laundry with the rear duct removed completely and see if the light comes on.
Mar 10, 2011 | Dryers
Dryers Logo
44 people viewed this question
Top Dryers Experts
