Generic / Text Only (To File) printer driver cutting off at 85 columns wide
Hi, I am successfully using Windows XP's "Generic / Text Only (To File)" printer driver to print a report. However, the output seems to be cut-off at 85 columns wide. When I print the same report to a PDF, the report is not cut-off. I have tried changing the properties of the Generic printer to landscape but that didn't help. Thank you!
I found a solution to my problem above. In the Generic / Text Only driver I chose a page setup of "ledger" (as opposed to letter, legal, etc.) and that produced the correct output with all of the columns.
Posted on Apr 20, 2008
Gerror 913 en lso archivos201 segenera por tener archivos desatualizado
Obten los controladores de Windows o MAc y actualiza tu printer.Si continua el problema escribeme.
Windows Operating Systems spacer.gif [+] Generic 9-Pin Printer Driver v1.0bEs
Windows 98, Windows 95, Windows NT 4.0, Windows NT 3.51
epson10753.exe - 559KB - posted on 05/29/03
[-] Generic 9-Pin Printer Driver v1.0bEs
This self-extracting file contains the Generic 9-Pin Printer Driver for Windows 95, 98, NT 3.51 and NT 4.0 (Printer Driver v1.0bEs, Core Driver Disk v1.0). This file is for use with all Epson 9-Pin Dot Matrix Printers.
Note: Please have your Microsoft Windows CD-ROM available as the printer driver may require some OS files from the CD-ROM to complete the installation.
downloads_icon.gif Download Now
Windows 3.1
ep10759.exe - 527.2KB - posted on 05/29/03
Windows 3.1
This self-extracting file contains the Generic 9-Pin Printer Driver for Windows 3.1 (Printer Driver v1.0bEs, Core Driver Disk v1.0). This file is for use with all Epson 9-Pin Dot Matrix Printers.
Note: Please have your Windows 3.1 installation disks available as the printer driver requires the "unidrv.dll" file to complete the installation.
Macintosh Operating Systems spacer.gif [+] Network Printer Driver v2.0A
Mac System 7
EPRINT2N.SEA.hqx - 779.1KB - posted on 06/12/96
[-] Network Printer Driver v2.0A
Mac System 7
This self-extracting file contains the EPSON Print! 2 Network Printer Driver files for the 9-pin ESC P2, 24-pin ESC P2, and the DFX printers.
[+] Printer Driver (Serial) v2.0A
Mac System 7
EPRINT2S.SEA.hqx - 610.1KB - posted on 06/12/96
[-] Printer Driver (Serial) v2.0A
Mac System 7
This self-extracting file contains the Epson Print! 2 Printer Driver for serial connections with 9-pin ESC/P2, 24-pin ESC/P2, and the DFX printers.
Dec 17, 2010 | Epson FX 1170 Matrix Printer
Need Printronix p7500 driver file to install in XP Pro
how to configure lan setting in wep printonix P 7-500 Line printer
Jun 05, 2009 | Printronix P7005 Matrix Printer
IBM 6400 Dot Matrix Printer - Need Drivers for Windows XP
Try running couple of these test, to see if it might be another issue.
It should be printing these test at 1500 Line Per Minute... ?
1500LPM is at 10CPI if you have (Font size: 6, 8, 12, 14) it will make a difference.
Change your driver to Generic/Text, rerun your report... any difference?
Apr 15, 2009 | IBM 6400 Model i10 Matrix Printer
Epson TM-U220D Receipt Printing Problem
mau download driver epson tm-u220d ga ada...
klo mau cari dimana yah
Oct 21, 2008 | Epson TM-U220 Matrix Printer
Samsung CLP-315
try to do this set of instruction & solution:
  1. Go to Start | Control Panel | Printers And Other Hardware | Printers And Faxes. Double-click the icon for your printer to open the Documents window and clear any pending print jobs by selecting Cancel All Documents from the Printer drop-down menu
  2. Try printing a test page from the printer, not from Windows XP. Most printers have a built-in test function that's activated by holding down one or more buttons while the printer is starting up. Check your printer's user manual for instructions. If this page prints successfully, you know the problem is either with your connection or with the software in your computer.
  3. Check your printer's USB or parallel connection.
  4. Try printing something simple from Windows' Notepad. To open Notepad, go to Start | All Programs | Accessories | Notepad, type a few lines of text in a document, and try printing it. If it successfully prints, the problem is with the software program you originally tried to print from.
  5. Try printing using Windows XP's generic printer driver. Open and run the Add Printer Wizard. When you get to the Install Printer Software screen, select Generic under Manufacturer and Generic/Text Only under Printers (see Figure 2).
  6. Select No for Do You Want To Use This Printer As The Default Printer? (see Figure 3). Click Next.
  7. When prompted on the next screen, tell Windows XP to print a test page. If the page successfully prints, then you probably have a problem with your installed printer driver. Either update or reinstall the driver.
Sep 16, 2008 | Samsung CLP 300 Laser Printer
Pixma IP3000 will not print
Sep 16, 2008 | Office Equipment & Supplies
Printer will not print
And.....
How about telling is what the make and model of the printer, what operating system you have, any error messages that pop up etc etc etc
TO Print the image using IPL.
I've printed images over 500kb. Can you print a small image? If not, perhaps the driver is the problem.
If you're trying to send a text file of IPL commands to the printer, set up a Generic Text printer driver, to to send the file as ascii characters instead of as a graphic image. You can set this up in addition to your Intermec driver.
Go to Printers and Faxes, Add Printer, Next, Select the Port, Select "Generic" Manufacturer, "Generic / Text Only" Printer, and give it a name like "Text". Cycle the printer power to clear previous attempts, then print the file to this printer name.
Aug 22, 2008 | Intermec EasyCoder 3400 Thermal Label...
Printing from windows
as i understand, DPL will works if you are using a serial comunication. When you say "using Generic Text Driver" i can see you are trying to print snce parallel port, as any other prnter. If that is the case, you can forget the DPL. Install an apropiated DATAMAX printer driver, and print from Wordpad.
Nov 21, 2007 | Datamax I-4308 Thermal Label Printer
1,636 people viewed this question
k24674
