Hello i have a toshiba l305 laptop and can't get the internal mic to work with any program that uses it
  • 304 Answers
The Microphone might not be working, as it may not be enabled.
However, you may enable the Microphone manually by performing the below steps:
For Windows XP:
1) Double-click on the Volume Control. 2) Select the "Properties" option from the "Options" menu. 3) Select the "Recording" option in the "Adjust volume for" section. 4) Click the OK button. 5) Check the box labeled "Select" under the microphone volume and you should now be able to adjust the volume for the microphone.
For Windows Vista:
1) Right click Speaker near Clock - Recording Devices - right click in box - check 2) Show Disconnected Devices and Show Disabled Devices - check your mic - highlight them and then on lower right properties. 3) Make sure the proper one is enabled and check other settings - on Levels tab make sure MUTE is unchecked and APPLY / OK changes.
For Windows 7:
1) Right click on the volume icon in the system tray and then click “Recording devices”. 2) Right click on the blank place in the popped up window and then select “Show Disabled Devices” and “Show Disconnected Devices”. 3) Right click on Microphone and then click “Enable”. 4) Highlight the microphone and then choose “Set as Default Device”. 5) Click Apply. 6) Select Microphone and click on Properties. 7) Click on Levels tab. The default Microphone Boost is set to 0, increase it.
Hope this helps.
Posted on Jul 07, 2010
Toshiba How To get inbuilt microphone working
Open the Control Panel, select Speech Recognition to very the Mic is in working order. Set Up Microphone. Open Sounds to select Mic. If you are trying to setup in a software program, say Skype, open Skype Setting and configure/select Internal Mic and webcam.
May 12, 2013 | Toshiba Satellite C850D-BT2N11...
How do I turn the webcam on, in my toshiba computer:satellite L305-S5937
Most Toshiba's use a utility program for the webcam.
I would recommend installing the latest version for your model here.
Let me know if that works, it should ;)
Dec 31, 2010 | Toshiba Satellite L305-S5877 Notebook
After loading windows vista ultimate build in mic not working.
Start looking up the exact audio card used in that unit. I have an L305 and the Vista driver works fine 4 mine. So u may need to look at other drivers for that particular card for the mic to operate.
Aug 13, 2010 | Toshiba Satellite Pro L300 Notebook
I have a toshiba l305-S5957 and can't find an internal mic for use with skype
While most laptops comes with a built in webcam and microphone, this particular model does not. If you don't see a web cam built in to the top of your screen, chances are you also won't find an internal microphone. You'll need to purchase additional accessories in order to use your laptop with Skype.
Mar 08, 2010 | Toshiba (P000257700) Microphone
Hi, my toshiba satellite A200-1Rk built in microphone is not working please help me to resolve. i installed drivers but only mic not working
Normally a problem with the mic isn't driver related unless you have no audio as well. What program are you using that the mic is not working with? More than one? Will the mic work in one program and not the other? If its not working in any of them, you may want to make sure the correct device is selected to record from in windows.
1. Start>all programs> accessories > entertainment > volume control
2. In the "master volume" panel select options > properties
3. in the mixer device drop down select the one that says input somewhere in the title
4. The check boxes below should now show you your options of devices to record with. Select the laptops internal mic and try using it again.
If that doesn't work there's most likely an issue with the hardware and you would need to replace the mic if possible.
Jan 14, 2010 | Toshiba Satellite A200-S18X01G Notebook
Help for laptop L305-s5907
sounds like internal ram fried .due to a virus thats affecting Ram and cpu
Jun 28, 2009 | Toshiba Satellite L305-S5907 Laptop
How to Replace hard drive for Toshiba Satellite L305-S5875
This useful link will help you...
http://www.bixnet.com/toshiba2.html
Jun 24, 2009 | Toshiba Satellite L305-S5875 Notebook
Reinstall camera assistant software
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=DL&os=&category=&moid=2199091&rpn=PSLB8U&modelFilter=L305-S5905&selCategory=3&selFamily=1073768663&selModel=2199091|PSLB8U
All you need to do now is choose your operating system and then download the web camera driver. If this helps please rate. Thank you
Feb 12, 2009 | Toshiba Satellite L305-S5907 Laptop
Computers & Internet Logo
75 people viewed this question
David Payne
David Payne
