Question about Zebra 105SL Thermal Label Printer
Our printer 105 SL printhead is over heating kindly solve our problem
  • 518 Answers
The thermal senser may be u/s
Posted on Jul 07, 2010
Why will my printer not print. shows error 3802. just prints blank page. do have ink.
Error: "Printhead Failure" (105-3802) - Kodak
support.en.kodak.com/.../error%3A-printhead-failure-(105-3802)
KodakAug 25, 2010 - How do I resolve the error message "Printhead Failure" (error code ...If you are not prompted to calibrate the printhead, turn off the printer, wait ...
Error: "Printhead is missing, not installed correctly, or has ...
support.en.kodak.com/.../error%3A-printhead-is-missing,-not-inst...
KodakAug 25, 2010 - How do I resolve the error message "Printhead is missing, not installed correctly, or has come loose" (error code 105-3513) on my ESP or HERO All-in-OnePrinter? ... If the printhead and ink cartridges are not installed in the printer, install them: ... If the error continues, restart the printer and try to print.
Jan 18, 2016 | Kodak ESP5 AllInOne InkJet Printer
My printer is showing error code 3802, I do I do?
Hello Dave,
The error that you are showing means Error: "Printhead is missing, not installed correctly, or has come loose" (105-3513) Please use the following link to help you trouble-shoot and fix this error:
Error Printhead is missing not installed correctly or has come loose 105...
Feb 26, 2015 | Kodak ESP5250 All-In-One InkJet Printer
Error condition ribon out for zebre 105 sl
This may be due to the fact that your ribbon is too translucid, back quality transfer films.
To overcome this you must use a bit of scotch and a piece of film and stick it on the ribbon sensor.
Else try a callibate to see if the error is not solved
Sep 19, 2011 | Zebra 105SL Thermal Label Printer
Can we make 300 dpi Zebra 105 SL printer to print on label expecting 203 DPI, Any configuration setting?
Krishan, sorry there are no settings that will allow you to do this on the 105SL. If the printer code expecting a 203 DPI printhead and you have a 300 DPI Printer then your label will print out much smaller then normal.
If you are printing labels with a label printing package (such as Seagull Bartender for Windows) then all you need to do is to install the proper printer driver. If you have your printer attached to a system that is sending "straight" ZPL (Zebra Printing Language Code) then your out of luck.
Hope this helps
Mikeo@acebarcode.com
Feb 28, 2011 | Zebra 105SL Thermal Label Printer
Labesl are printing very light in the center. OK on the edges
This is a good challenge so lets start with the "simple stuff".
First, Have you cleaned the printhead? If not just use a Q-Tip and some rubbing alcohol if you don't have any other cleaning materials.
Second, look at the platen (the white roller) are there any cuts or hunks missing? This would result in voids every-time the platen rolled around to that point during printing. If you see any, the platen needs to be replaced.
Third, it would be odd but do you see any stuck labels on the platen? If so remove them.
Fourth, the "standard" 105 SL has one tension spring. I'm guessing it's already centered in the middle of the label?
Regards,
mikeo@acebarcode.com
Feb 17, 2011 | Zebra 105SL Thermal Label Printer
Our company has several Zebra printers that print out barcodes that are scanned using handheld scanners for many things including inventory management. The labels that come from ONE of these Zebras...
Power off printer. Press and hold pause button while power on. This will print dark black line across the entire label. Check for white vertical lines. If you see any in the area of the label where you are experiencing a problem then the printhead should be replaced. Power off and on to exit diagnostics.
Jun 25, 2010 | Zebra 105SL Thermal Label Printer
We have one zebra printer, Model 105-SL , its not
You can try to factory default by turning the printer off, hold down the pause and the feed buttons. While holding pause and feed down turn on the printer and count to 5 and then release the 2 buttons and the printer will return to factory setting. Typicaly when all the lights stay lit its do to the logic board being bad but sometimes you can get lucky with the default.
Jun 06, 2010 | Zebra Z4M Printer
I have a Zebra 105-SL and it seems not to recognize the distance between stickers since it prints a couple and then jumps a couple more.
Sounds like the white platen roller under the printhead needs to be cleaned or the printer needs to be calibrated.
Sep 26, 2009 | Zebra 105SL Thermal Label Printer
Printhead & Waste Tank Troubles
Try this thread, it fixed mine without the need for any new parts, also note the cleaning procedure, it may fix your old printhead
http://www.fixya.com/support/t350585-waste_ink_absorber_almost_full_canon
Sep 15, 2007 | Canon S900 InkJet Printer
Zebra 105SL Thermal Label Printer Logo
77 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
CheckitRight
CheckitRight
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
