Question about Samsung SyncMaster 214T 21.3" LCD Monitor
My samsung 214t becomes very blurry after startup and flickers hard than falls out.after a while (first it was after 10 minutes and then it started to take longer than a half an hour the screen became perfect again )when turning on and off the monitor and it stayed perfect during working with the pc. as soon as I turned off the pc for an hour and tried to started up again I got the same problem every time and.
  • Xris M
    Xris M Mar 27, 2014
    Not every fix is going to be capacitor problems. Any novice will know this. It's the cheapest fix but not always the right one. If your monitors menu is pixelated and it takes a while to warm up. It could be the main board. Had two 214ts that would take a long time to get a picture. I would turn on monitor, it would flash and then I would have to turn it off and on and then I would get a desktop that was staticky and then flip it off then on and everything would clear up and be normal. During that time the monitors menu would be pixelated if you try to open it. I replaced all capacitors, bought several power boards and replaced back lights and nothing worked. Finally as a last resort i installed a different main video board which is the other board in the monitor and it turned on good as new. It wasnt the capacitors at all. So we can't be myopic on where to look.
  • Samsung Master
  • 1,684 Answers
The flickering is caused by a power supply board that can't stabilize the output voltages. This type problem is caused by failing capacitors. If you can solder then you should be able to do the repair yourself. Check out our step by step repair guide at: http://www.ccl-la.com/blog/index.php/samsung-214t-repair/ If you don't want to do the repair yourself we do offer a repair service for this model. The repair runs $30 plus shipping. You can setup the repair service at: http://www.ccl-la.com/blog/index.php/service-request-form/
I hope this helps, if so please rate our solution.
CCL_Tech
Corporate Computer
www.ccl-la.com
Posted on Jul 12, 2010
Hi, my samsung syncmaster 214T starts up and flickers hard permanently. I can do everything, change resolution,refresh rate and the monitor responds but it does not stop flickering. Is it a power supply...
Flashing or flickering is a common indication of failing capacitors in the power supply board. The fix is very simple and just requires replacing 5 capacitors on the board. They will need to be soldered. Here is a link to a repair guide for the Samsung 214T units. http://www.ccl-la.com/blog/index.php/samsung-214t-repair/
BuddyMc
Jul 03, 2011 | Samsung SyncMaster 214T 21.3" LCD Monitor
Monitor is 22" Samsung 226BW. Problem is that it was blinking for a long time after I turned it on and after a while it would become stable and it was working fine until I powered it off and on again. Now...
The blinking or flickering problem you are having is caused by the power supply failing. There are parts called capacitors that start to fail which causes the voltages to not stabilize. When they rise and fall the display flickers until the voltages settle. We have an article posted on our web site at http://www.ccl-la.com/blog/index.php/samsung-214t-repair/ that explains what needs to be replaced and includes pictures with part lists. If you don't want to do the repair yourself we do offer a repair service, more information on this service can be found here: http://www.ccl-la.com/blog/index.php/service-request-form/
CCL_Tech
Corporate Computer
www.ccl-la.com
Aug 22, 2010 | Computers & Internet
Flickering screen
The flickering problem you have is caused by a failing power supply. There are parts called capacitors that are failing and causing the power supply board to put out pulsing voltages until it can stabilize. We have a repair guide posted on our web site at: http://www.ccl-la.com/blog/index.php/samsung-214t-repair/ If you can soldethen you should be able to do the repair yourself. If you don't want to do the repair we offer a repair service for this unit. You can get details for that service here: http://www.ccl-la.com/blog/index.php/service-request-form/
I hope this helps, If so please rate our solution.
CCL_Tech
Corporate Computer
www.ccl-la.com
Jul 15, 2010 | Samsung SyncMaster 205BW LCD Monitor
Samsung 214T wakes up from hybernation flickering (Windows 7)
A flickering display usually indicated a failing power supply. Check out our web site at www.ccl-la.com We have a free step by step repair guide for the 214t that will show you how to open the case. Once inside look at the power supply for parts called capacitors. The tops should be perfectly flat and I would bet your have bulges which indicate they are damaged. If you find bad caps and them replace them you should be back going without any flickering. Many LCD monitors will have issues after 2-3 years of use. If you have any more questions just let us know.
Buddy
Corporate Computer
www.ccl-la.com
tech@ccl-la.com
Nov 19, 2009 | Samsung SyncMaster 214T 21.3" LCD Monitor
Samsung 214t monitor would flicker
http://s807.photobucket.com/albums/yy352/budm/Samsung%20Syncmaster%20214T/
Replaced all those caps (not hte big on in the primary circuts) with PANSONIC FM or FC series from DIGKEY.COM
Aug 29, 2009 | Samsung SyncMaster 214T 21.3" LCD Monitor
Flickers then goes black
Check cable plug, conent it properly
Jul 06, 2009 | Samsung 215TW SyncMaster 21" LCD Monitor
Samsung 215TW Monitor Flicker
Its the capacitors on the backlight power supply. Samsung installed crappy ones and they blow up after a year or two. Change out the caps and you're good to go
Jan 30, 2009 | Samsung 215TW SyncMaster 21" LCD Monitor
Samsung SyncMaster 214T flickers
Hi There,
I managed to fix my Samsung SyncMaster 214T from that flickering. Just changed 3 capacitors and it worked fine!!
Jun 01, 2008 | Samsung SyncMaster 214T (Silver) Monitor
214T - flickers radidly
Yes,
A flickering screen indicates the power supply is not properly filtering the output power. This happens when the capacitors on the power board start failing. Here is a link to a repair guide that shows how to dis-assemble the unit and what to look for and replace on the power supply board. The repair guide also has videos showing the process.
I hope this helps, if so please rate my solution.
BuddyMc
May 02, 2007 | Samsung SyncMaster 214T 21.3" LCD Monitor
Samsung SyncMaster 214T 21.3" LCD Monitor Logo
1,144 people viewed this question
Top Samsung Computers & Internet Experts
270rexton
270rexton
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
