Hi I have had my samsung 32" hd ready tvmodel no: LA32A330J1N for almost two years now I was away for the weekend and when I got back I turn the tv on and it seems the volume- button is always pressed but when i try use the side panel to turn the Volume up it changes the channel and not the volume. And when I turn the tv off it turns itself on and cycles through the channels Could anyone help please?
  • 3 Answers
SOURCE: volume/ channel/ remote not working
I just used the following instructions from this site on my 'totally dead' Ilo remote and it worked like a charm! I did step 2 twice on each key and put the batteries back in and it worked great! Hope this helps you too. "Dead" Remotes Can Be Saved How to Re-Start Your "Dead" Remote Control This only takes about a minute and will restart 1 in 3 "Dead" Original Remote Controls. Good Luck! Step 1- Pull the batteries out of the remote and leave them out until Step 4. Step 2- Press and release each and every button one at a time on the remote control until every button has been pressed and released at least once! Step 3- If your remote has slide switches, you must move the switch to each position then repeat the button pushing in Step 2. (When you're done, be sure to put the slide switch in the correct position to operate the unit the remote came with!) Step 4- Put the batteries back into the remote, being very careful to install them correctly. New batteries should be used if you're not sure about the old ones. Step 5- Try the remote. If it works, Great! If not, it's time to call 1-800-Remotes or use this website to order a new remote.
Posted on Jan 23, 2007
trintek
  • 111 Answers
SOURCE: TV CHANGES CHANNELS (BY ITSELF)
is this tv the same model/brand? far be it from me to claim poltergeists are at work, but who knows... the very first thing i would do in diagnosing this issue is to grab some electrical tape and aluminum foil, tape a patch over the ir receiver for the remote, this should be a shiny piece of black plastic somewhere on the front of the tv, some are marked, some are not.. if you have it, aluminum duct tape works great for this purpose.
to me, it seems like someone is messing with you using a remote, tv-b-gone, or similar product like a keychain universal remote.. if the tape over the ir sensor fixes the issue, i would look at roommates, kids, neighbors, or possible interference from other ir or light sources..
possible culprits would be:
universal remotes
dirty remotes that keep sending a signal with nobody using it
laptops or cellphones with an irda port
palm devices such as palm, clie, etc that have irda
intermittent strobes (emergency vehicles, bad ballast in a light fixture, etc)
i can't guarantee this is your problem, but it seems like it since this is your second tv with the same or similar problem... as a sidenote, the sony clie came with a universal remote program, i caused much chaos in my local video stores by shutting down their video wall while browsing.
Posted on Nov 16, 2007
SOURCE: Volume and chanel number stays displayed
Pressing i+ button (bottom left on the original remote) for 5+ seconds worked for me...
Posted on Jul 26, 2008
  • 3422 Answers
SOURCE: Code to enable volume on remote control
HI,
Can you please give the make and model no. of your remote?
Posted on Sep 13, 2008
  • 362 Answers
SOURCE: Olevia 537 - wont select HD channels
I assume the control panel on the tv still works correctly? If so i would think you have a remote problem. If thats the case let me know I will send you a link to instructions to repair your remote.
lone99star
Posted on Jan 09, 2009
Blurred and fogey picture with same samsung model la32c450. Can turn of tv to get clear picture back but after a few minutes problem returns
Hi Paul,
Do you get clear OSD. If yes, it is the main board, if not unfortunately it has to be the lcd panel. Good luck.
Jan 04, 2014 | Samsung LA32A450 32 in. HD-Ready LCD TV
HD not working.
Have you connected it Via HDMI? if the screen is still connected via Scart then that is the problem.
May 03, 2010 | Samsung LE32R74BDX 32 in. HD-Ready LCD...
32' Samsung LCD Tv vertical bars on screen / sound
hi,
your lcd panel micron tube has already wron out. time to replace the panel
Apr 25, 2010 | Samsung LE32R41BD 32 in. HD-Ready LCD...
Screen Repair
Try searching SAMSUNG TV through Google search. You will find the servce center to your nearest location.
Apr 22, 2010 | Samsung LE32R73BD 32 in. HD-Ready LCD...
Samsung 32 lcd standby light on but cant turn the tv on
hi,
your lcd ip board (power board) capacitor had already exhusted. got to replace either the board or capacitor.
Mar 09, 2010 | Samsung LE32R74BDX 32 in. HD-Ready LCD...
Samsung LNR 328W TV turns itself off and turns itself back on
it sound to me like your power supplie is heating up and shuting down your power supplie is on its way out
Dec 02, 2008 | Samsung LN-R328W 32 in. HD-Ready LCD...
Samsung LE32R74BD
It should when the TV is turning on. If it happens while the set is on there is a problem with the main board or a loose connection.
Jul 01, 2008 | Samsung LE32R74BDX 32 in. HD-Ready LCD...
Dark vertical shadows
No,you can't. This is very common. I bought a new tv and i noticed right away that it had the problem you are mentioning. I took it back for an exchange and the next tv did not have this problem...until a year later. Now,of course it does have this problem,but it is out of warranty.
I think they make televisions very poorly today.
Apr 27, 2008 | Samsung LE32R74BDX 32 in. HD-Ready LCD...
Samsung lcd tv le40r8
if the unit is under warranty call samsung for the nearest authorized repair place. the problem is a bad main board.
Feb 24, 2008 | Samsung LE40R72BDX 40 in. HD-Ready LCD...
How good is Sky HD on Le32r42b
Hi
I just got the sky hd and i have a 32" samsung tv and the reception is crystal clear would defo recommend it!!
Nov 18, 2007 | Samsung LE32R41BD 32 in. HD-Ready LCD...
Televison & Video Logo
118 people viewed this question
Top Televison & Video Experts
Electro Med Services...
