Question about Lexmark JetPrinter X1185 All-In-One InkJet
My printer is a Lexmark X1100
The printer has started to feed improperly and the little roller ball pulls the paper to the right
Hhhhhhu
gvgvvvbbv
Posted on Apr 24, 2008
Paper is pulled through crooked printing is not straight. how doyou clean the rollers?
This can be caused by several factors. It could be that there's something(like small foreign objects in the paper feed area) causing the paper to get crooked. It can also be caused by improperly adjusted paper guide or the paper is not in good condition.
Paper Feed Rollers Are Rolling But the Paper Is Not Feeding
How the Accu-feed Paper System Works
Mar 23, 2011 | Lexmark X75 All-In-One InkJet Printer
When feeding my paper it keeps pulling the paper
You need to replace the feed rollers. One side is probably worn. You should be able to buy a rebuild kit for it. Try ebay.
Nov 02, 2009 | Lexmark X2600 InkJet Printer
E240 LEXMARK WON'T PULL PAPER FROM TRAY 2
Try pulling out the tray and looking for the feed rollers that pull the paper up into the printer. The 2 rollers should have rubber "shoes" on them (they look like thick black rubber bands). Remove these roller "shoes", turn them inside-out, and put them back on the rollers. This worked for me, maybe it will work for you too.
Mar 31, 2009 | Lexmark E240n Laser Printer
Lexmark z2300 printer won't pull in paper
1. Turn the printer off and open the access cover.
2. Look for any obstructions in the paper path and remove them if necessary. (It is possible to move the carrier assembly with the power off.)
3. Turn the printer on, load some paper, and press the Form Feed button. (On the X83, press the Select button.)
4. Watch the paper as it feeds through and try to determine where the jam is occurring.
5. Check to see if all the rollers are turning.
If all the rollers are turning, there may be something in the feed path that you can't see. Go to step 6.
If not, there is probably a feed motor or a gear problem and the printer may require service.
6. If the paper is jamming under the carrier assembly, you may be able to fix it using the manual feed slot.
7. Turn the printer off.
8. Take a #10 envelope and feed it through the left side of the manual feed slot until it comes right through the printer to the back of the exit rollers.
9. Move it up and down first, and then slowly move it over to the right side. If something is stuck under the black guide plate, this may work it loose.
Jan 03, 2009 | Lexmark Color JetPrinter Z23 InkJet
Lexmark x 3350 all-in-one
I picked up a used Lexmark 3500 with the same problem. Had requested help fixing.
Tried to feed more paper through - still pulling hard on the right side. Tried to feed several pieces of paper - one at a time, getting them jammed then pulling them back out. Finally one got jammed way down in there - yanked it back out. Open the top(as to load ink cartridges) Saw a tiny piece of paper sticking out between the plastic rollers, got a small crochet hook (tweezers would have worked), grabbed a hold of it and pulled it out enough to get a good hold of it, then pulled it out. There had been a shread of paper jammed in the roller area. 3" long by from 1/4" to 1 1/2" wide.
My problem was the chunk of paper stuck in the roller mechanism where you could not see it or get to it, until it was partially forced out.
Hope this helps someone else!
Oct 16, 2008 | Lexmark X1270 All-In-One InkJet Printer
Lexmark X2250 uneven paper feed
Oct 02, 2008 | Lexmark X4270 All-In-One InkJet Printer
Lexmark x73 Printer
push the paper a little bit to help the printer to pull it correctly if not working then there is a problem with the rollers and that would be a hardware issue and needs to be fixed at the shop.
cheers
Sep 03, 2008 | Lexmark X73 All-In-One InkJet Printer
X1270 paper feeding to right
If this printer uses rubber rollers to feed the paper through the printer, try using alcohol on a cotton ball to clean the rollers. That might help restore the 'grip' on the paper.
Hope this helps, and please rate my advice.
Good luck!!
Jan 19, 2008 | Lexmark X1270 All-In-One InkJet Printer
Paper Jam
We need to the model/make to help you
but using some detective skills I've decided you are using a HP machine
Yup Dirty damaged worn feed roller but what model machine is it they are all different but pull out tray 2 cassette all the way and look in, there is probally a cylinder like rubber roller 5cm wide front centre of where cassette slides in, there might be roller on the cassette too at the front center as well.
Most modern printers feed rollers just slide off after lifting small plastic tabs on them and gently pulling, feed rollers are available but you can sometimes also get results by cleaning them with a dash of metho or water on a rag.
If paper feeds 2wo sheets at once then you need to change the seperation pad/roller too.
Nov 01, 2007 | Dell W5300N Laser Printer
Paper wont feed propaly
Something probably fell into that tiny pinch of an area where the paper goes. I have found everything from a Tostito crumb to a chip of drywall blocking my paper feed. Flip your machine over, poke it if you have to, and shake it around til the little bugger falls out.
Sep 22, 2007 | Lexmark X1270 All-In-One InkJet Printer
Lexmark JetPrinter X1185 All-In-One InkJet Logo
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
