Question about Hotpoint Aquarius WMA42 Front Load Washer
It makes a grinding noise when spinning and noice continues to increase like an aeroplane trying to take off
    Problem Solver:
  • 5 Answers
It may be ur brushes or failing that ur bearings
Posted on Jul 07, 2010
Noise while driving at low speeds
does the noice increase with incresed speed, if it is speed dependent it could be tire noise, wheel bearing noise
Nov 08, 2013 | 2006 Mazda MX-5 Sport
There seems to be a grinding noice coming from the bottom of the copier. It will feed paper from either source, the tray or the manual feed, and then the copy gets caught and shuts down the copier and you...
Diagnosing noises over the internet is an impossible task unless it is a known problem on a particular model. usually grind noises are casued by something trying to turn something that wont. It maybe something as simple as a siezed drum. As you have not stated what model of copier you have, i am sorry but i cannot proceed any further.
Jul 24, 2011 | Canon Office Equipment & Supplies
Dryer making rubbing noise like belt is weak, sprayed belt no change, tilled dryer forward noice stopped. ,also spayed with lubercate inside holes inside dryer noice stopped temporily
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker
Dec 30, 2010 | Hotpoint NVL333GY Gas Dryer
A noise had been gradually increasing from a grinding sound to a high-pitched whine. COntinues until the screen is completely off. Sounds like a fan motor may be out of lubrication.
THAT TV HAS WHAT IS CALLED A COLOR WHEEL WHICH SPINS AT VERY HIGH RPMS AND CAN MAKE HIGH PITCHED WHINING/GRINDING NOISES IF A FAN WAS BAD THE TV WOULD SHUTDOWN AND THE SOUND WOULD BE MORE DULL SOUNDING.
Dec 17, 2010 | RCA Scenium HDLP61W151 61 in. HD-Ready...
Wont spin and makes alot of noise
You could check if its drum by removing the belt turn drum by hand if its okay no noise check motor pulley ....is motor ok ?
Nov 17, 2009 | GE Profile Prodigy WPSE4200A
Washer has started making a heck of racket during the drain/spin cycle. It's not consistant. Two loads may go thru ok no noise. A third load and it will make a very loud grinding chain like noise.
Grinding noises are most often the result of a failing water pump. The noise can increase during the spin\drain cycle due to the added load on the pump. Although less likely it could also be the drive belt rubbing on something or a pulley bearing failing. If you are able to locate and remove the drive belt, you should be able to turn the water pump pulley by hand. If the pump does not turn smoothly it is bad.
Aug 06, 2009 | Maytag Washing Machines
Amana - noise while washing, not when spinning
There is a device called an Oldham coupling that connects the output of the electric motor to the transmission on the tub. It uses rubber vibration dampers in the coupling. Get some WD 40 and spray it generously on the coupling. You will have to tilt the machine nearly onto its side to see and spray the coupling so get some help.
Jun 22, 2009 | Amana DLW330RA Top Load Washer
Kenmore Washer 110.94818200 Spin Grinding Noice
the bearings are bad and yes they can be replaced but a service tech will have to do it. very big job
Jun 22, 2008 | Washing Machines
Loud grinding noice before starting to print
Mine makes a grinding noise when scanning or making copies. As long as everything is working, I just tolerate the noise in which the rest of the staff find amusing at first and then ignore it as I do.
Jan 25, 2008 | HP PSC 1210 All-In-One InkJet Printer
Hotpoint Aquarius WMA42 Front Load Washer Logo
112 people viewed this question
Top Hotpoint Washing Machines Experts
puggy666
Level 1 Expert
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
