My Canon Pixma mini 260 leaves "tracks" on all photos regardless of the print quality paper selection paper thickness and amount of cleaning! What can be done to fix this?
lean The Print Head Nozzles (Windows)
The
following contains instructions to check the nozzles for poor print
quality and perform cleanings of the print head nozzles as necessary.
If print results are faint or streaks are printed, the print head
nozzles may be clogged. Print quality can be improved by performing
print head cleanings or print head deep cleanings.
aution: Only used the approved
methods below to clean the print head. Use of other methods may further
clog the nozzles on the print head and may cause permanent damage the
print head. Note: It is important to check the cleaning results by printing Nozzle Check Pattern after each cleaning. Cleaning and Deep Cleaning consumes a certain amount of ink. Only perform a cleanings when necessary. Print a Nozzle Check Pattern
Confirm that the printer is connected to the computer and the printer is turned on.
Issue:
Banded or streaked prints Solution:
Change the Print Quality Settings (Windows)
The
Quality setting controls how finely ink droplets are placed on the
printed page. Depending on the type of paper being used a higher Print
Quality setting does not always insure a better print. Print speed will
decrease as the Print Quality setting is increased. Follow the
instructions below to change the print quality settings in the Canon
printer driver for the Windows operating system through a printing
application.
Click 'Properties' in the Print dialog box.
Note: Depending on the Application software, 'Properties' may be displayed as 'Preferences'.
Set the desired print quality in the 'Print Quality' section.
Select 'High', 'Standard', or 'Draft / Fast'.
To set more detailed print quality settings, follow this procedure:
Select 'Custom' and click 'Set'.
In the Set Print Quality dialog drag the slide bar from 'Fast' to 'Fine' to select the print quality.
Note: There are five options in 'Quality'. However, selectable options are limited depending on the media type.
Select 'Auto', 'Dither', or 'Diffusion' from the 'Halftoning' section.
Hi
This may work
The 6A00 is a Canon generic code for paper path jam.
Solution 1: Move the printhead carriage back and forth a few times.
Solution 2: Check the purge unit: Moving the print head assembly will not clear a purge unit if its jammed with paper, paper clips, push pins, screws, cookie crisp, flower bud pods or the like.
Solution 3: Press the ink pads down in the purge unit. Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
go into the preferences of the printer, under the maintenance tab you will see head clean. clean the head and do a nozzle check. If you get nothing after two or three head claens, then the head is failing and will require replacing.
Paper type must be set to "Plain" to select Normal or Fast for Print Quality. Every other paper type selected will automatically set print quality to Fine (Photo).
If you are using Glossy paper, when you go to print make sure to go into the printer Properties from the Print dialog box and select Glossy paper in the type. This will put the printer into it's highest print quality mode.
So from most windows applications, it would be :- CTRL-P (to print with dialog box for changes) Click on Properties Select a Media type of glossy photo paper Select standard or high print quality.
p.s. you may need to experiment which if the media types gives you best quality for the paper your using, unless it's Canon paper and then just match it up.
