I have a sony dvd/cd player home theater system. it is flashing standby, wont turn on or completely off. tried unplugging it and turning it on and unable to load or play cds/dvds. the speakers are functioning.
    Genius:
  • 1,456 Answers
Hello there
First check that the player is well connected to power and that the power is not too low or too high as this can damage your player..
Reboot the device if the Sony player doesn’t work at all. It’s possible the circuitry needs resetting. Turn the player off and turn it on again.
Inspect the cable running from the DVD player into the wall outlet. Make sure there are no cuts or chew marks in the cable, a common occurrence with animals in the house. If there is damage to the cable, wrap the cuts with electrical tape for insulation.
Unplug the power cable running from the DVD player and insert it into a different electrical outlet. Outlets can burn out and not function. Plugging the cable into a different outlet may correct your problem.
Look for glass fuses on the back of the player that control the unit's power distribution. If the fuses are black or broken, pick up some new ones at an audio or home improvement store
Change the temperature. Electronic equipment is designed to function best at room temperature, and DVD discs are no different. If they are too warm or too cold, try adjusting the temperature in the room and see if that helps the DVD (and your repair efforts) work properly.
Ventilate the room. If you were performing your initial repairs in an area that was dusty or smoky, the particles in the air may have interfered with the process. Ventilate the room for an hour or so, and then try again.
Make sure the player is set for CD/DVD playback. You will get no picture or audio from the Sony player if the system is set to the VCR , for example. The selection can change simply by brushing against a button on a remote control
GOODLUCK
Posted on Jul 08, 2010
Dvd player and cd work but no Radio or tv sound also hooked up a turn table and that wont play. Help
Hi, i think you have to get your unit looked at as it looks like the solder joints are drying up.
Feb 26, 2016 | Sony DAV-HDX266 Theater System
Philips HTS3154 Theater System. The redlight by the standby button flashes on/off continuously and depressing the standby button will not get the machine to turn on. Like wise the remote control will not...
Your Home Theater has problem in Amp section. Please check speaker wires are connected properly and see its insulation as well. If found fine, Amp Output in Home Theater is bad.
Aug 15, 2008 | Philips Televison & Video
I can't turn demo mode off or Standby from flashing on my Sony CMT-MX550i, can't turn unit off without unplugging it.
Sony CMT-MX550i -- I had good results by pressing the "TIMER MENU" button on the remote and simply setting the time. After that, no more demo.
Jan 16, 2013 | Sony CMTMX500i Desktop Micro System
Standby mode
When the STANDBY indicator
flashes
Immediately unplug the power cord
and check the following items.
• If your unit have a voltage selector,
is the voltage selector set to the
correct voltage?
Check the voltage for your region,
then make sure the voltage selector
is set correctly.
• Are the + and - speaker cords shortcircuited?
• Are you using the supplied
speakers?
• Is anything blocking the ventilation
holes on the rear of the unit?
After checking the above items and
fixing any problems, plug in the power
cord again and turn on the unit. If the
STANDBY indicator still flashes, or if
the cause of the problem cannot be
found even after checking all the
above items, consult your dealer.
Dec 20, 2012 | Sony Mhc-gn1300d 3 Dvd/vcd/cd Changer...
Flashing standby and disc wont eject
Try this: Turn it off and unplug everything from the wall and the device. Then hold in the on/off button for at least sixty seconds. Replug and try it. No guarantees but worth a try to reset the device.
Apr 16, 2010 | Sony DAV-SC6 System
Sony dav dz100 won't eject dvd
Press standby button to turn on the set, select dvd function then press and hold STOP and EJECT button for five seconds or more to UNLOCK cd slot. You will see UNLOCK in display.
Jan 02, 2009 | Sony DAV-DZ100 System
I have a samsung DVD Home Theater System HT-WX70. My son put a cd copy in the DVD player and PROTECTION flashed on the player and it turned off. I turned the player back on and took the cd out. ...
If it is, the protection message usually meant either a speaker had blown, or more commonly a wire to a speaker had come disconnected or broken/shorted.
Try unplugging the speakers one at a time, and if you have a set of speakers of the same rating to try, try plugging them in as you remove the originals (obviously doesn't need to be done in the setup positions in the room, just have them beside the player to check it works.)
This might then identify which speaker or cable is the problem one for you to replace or repair.
If this is the speaker overload/short mesaage as I think it is and the above doesn't cure it, it would appear the amplifier board has a short somewhere and that's an electronics engineer job time
Hope it helps!
Nov 18, 2008 | Samsung Televison & Video
FAC-FC7 DVD player is locked and the Standby indicator flashes
I had the same problem and searched FIX and found a solution for a Phillips DVD player that worked on my Sony DAV-FC7 dvd player. Someone posted that they called their Phillips Tech Service and was told to (a) unplug the dvd unit from the wall and wait 20 seconds,then (b) press the standby+plug the unit back into the wall at the same time and hold for 10 seconds. I did this for my Sony DAV-FC7 which would not power on nor eject (just red light on). IT WORKED!! after doing these steps, my SONY powered on and the rented DVD ejected. The dvd palyer works again. Thanks fellow FIXYA "posters".
Nov 12, 2007 | Sony DAV-FC7 System
Flashing standby message.
Are any of the buttons not making a click feel when you press them like maybe one is stuck?? You didnt say if the same thing happen with the radio as did with the cd. If it is then a switch is stuck or bad or a problem with the switch matrix for the Microprocesor . Only way to trouble shoot this is I would use a scope and check all of the matrix {ie scann lines as well as input lines for distortion or noise and make sure when the buttons are pussed that they change and switch accordinly. If they dont then the processors bad. Good luck
Apr 23, 2006 | Sony DAV-SC8 System
26 people viewed this question
 Grubhead
Grubhead
