WHEN TRYING TO BURN A COPY OF A DVD (ORIGINALLY RECORDED FROM MY DVD RECORDER ATTACHED TO MY TV), I GET THIS ERROR MESSAGE AFTER IT HAS BEEN COPYING IT FOR SEVERAL MINUTES. DIFFERENT BRANDS: VERBATIM, SONY, MEMOREX ALL DO THE SAME. SOMETIMES I CAN GET A GOOD COPY, HOWEVER, BUT 8X OUT OF 10 IT IS MAKING COASTERS. I HAVE REPLACED BOTH DVD DRIVES AND IT STILL HAPPENS. px.dll: 4.0.36.500 pxafs.dll: 4.0.36.500 pxdrv.dll: 1.2.9.0 pxmas.dll: 4.0.36.500 pxsfs.dll: 4.0.36.500 pxwave.dll: 4.0.36.500 pxwma.dll: 1.0.0.3 FIRMWARE ARE UP TO DATE USING SONIC RECORD NOW WHICH WORKED FOR YEARS UNTIL RECENTLY THANKS JBC
  • 2 more comments
  • GRACIE5 Apr 18, 2008
    Thanks for the response. I downloaded DVD Decrypter. I just tried again to copy a disc I previously tried to copy. It copied up to 83% and then hung up. There are no apparentl scratches on the souce disc. These are the codes I got. I don;t know what all of this means. I have highlighted possible issues. Any suggestions?
    I 14:26:55 DVD Decrypter Version 3.5.4.0 started!
    I 14:26:55 Microsoft Windows XP Professional (5.1, Build 2600 : Service Pack 2)
    I 14:26:55 Initialising SPTI...
    I 14:26:55 Searching for SCSI / ATAPI devices...
    I 14:26:55 Found 1 DVD-ROM/CD-RW and 1 DVD-RAM/±RW!
    W 14:26:57 Possible Structure Protection Found!
    W 14:26:57 4 areas have been marked as 'suspect'.
    W 14:26:57 Dummy sectors will be inserted where necessary.
    I 14:29:45 Operation Started!
    I 14:29:45 Source Device: [0:0:0] SONY CD-RW CRX320EE RYK4 (D:) (ATA)
    I 14:29:45 Source Media Type: DVD-ROM
    I 14:29:45 Source Media Region Code: 1, 2, 3, 4, 5, 6, 7, 8
    I 14:29:45 Source Media Copyright Protection System Type: None
    I 14:29:45 Source Media Implementation Identifier: DVD Video
    I 14:29:45 Destination Folder: C:\Documents and Settings\Jeanne Cramer\My Documents\My DVDs\DVD BACKUP WORK--EMPTY EACH TIME\VIDEO_TS\
    I 14:29:45 File Splitting: By File
    I 14:29:45 Remove Structure Protection: Yes
    I 14:29:45 Bad Sector Removal Method: Aggressive
    I 14:29:45 Detect Mastering Errors: No [WHAT DOES THIS MEAN?]
    I 14:29:45 Multi Angle Processing: No
    I 14:29:45 Remove Macrovision Protection: Yes
    I 14:29:45 Stream Processing: No
    I 14:29:45 Copying VIDEO_TS.IFO... (LBA: 7168 - 7173) - KEY: N/A
    I 14:29:47 Copying VIDEO_TS.VOB... (LBA: 8192 - 8431) - KEY: N/A
    I 14:29:47 Copying VIDEO_TS.BUP... (LBA: 14848 - 14853) - KEY: N/A
    I 14:29:47 Copying VTS_01_0.IFO... (LBA: 15360 - 15401) - KEY: N/A
    I 14:29:48 Copying VTS_01_1.VOB... (LBA: 16384 - 462079) - KEY: N/A
    I 14:32:30 Copying VTS_01_2.VOB... (LBA: 462080 - 907775) - KEY: N/A
    I 14:34:33 Copying VTS_01_3.VOB... (LBA: 907776 - 1353471) - KEY: N/A
    W 14:34:55 Inserting Dummy Sectors... (LBA: 997064 - 999583)
    I 14:34:56 Extracting Sectors...
    W 14:34:56 Inserting Dummy Sectors... (LBA: 1001264 - 1002095)
    I 14:36:17 Copying VTS_01_4.VOB... (LBA: 1353472 - 1799167) - KEY: N/A
    I 14:37:50 Copying VTS_01_5.VOB... (LBA: 1799168 - 2244895) - KEY: N/A
    W 14:39:18 Failed to read Sector 1869901 - L-EC Uncorrectable Error
    W 14:40:28 Failed to read Sector 1869902 - L-EC Uncorrectable Error
    W 14:41:40 Failed to read Sector 1869903 - L-EC Uncorrectable Error
    W 14:42:51 Failed to read Sector 1869904 - L-EC Uncorrectable Error
    W 14:44:02 Failed to read Sector 1869905 - L-EC Uncorrectable Error
    W 14:45:14 Failed to read Sector 1869906 - L-EC Uncorrectable Error
    W 14:46:26 Failed to read Sector 1869907 - L-EC Uncorrectable Error
    W 14:47:40 Failed to read Sector 1869908 - L-EC Uncorrectable Error
    W 14:48:54 Failed to read Sector 1869909 - L-EC Uncorrectable Error
    W 14:50:05 Failed to read Sector 1869910 - L-EC Uncorrectable Error
    W 14:51:18 Failed to read Sector 1869911 - L-EC Uncorrectable Error
    W 14:52:34 Failed to read Sector 1869912 - L-EC Uncorrectable Error
    W 14:53:50 Failed to read Sector 1869913 - L-EC Uncorrectable Error
    W 14:55:05 Failed to read Sector 1869914 - L-EC Uncorrectable Error
    W 14:56:21 Failed to read Sector 1869915 - L-EC Uncorrectable Error
    W 14:57:35 Failed to read Sector 1869916 - L-EC Uncorrectable Error
    I 14:58:20 Abort Request Acknowledged
    E 14:58:22 Failed to read Sector 1869917 - L-EC Uncorrectable Error
    E 14:58:23 Failed to copy VTS_01_5.VOB!
    E 14:58:35 Operation Aborted! - Duration: 00:28:46
    E 14:58:35 Average Read Rate: 2,148 KB/s (1.6x) - Maximum Read Rate: 10,709 KB/s (7.7x)
  • GRACIE5 May 14, 2008
    Thanks for our response. I did try DivX, but not sure which other ones I can trust off of the Internet for free. At least this one I can save to hardrive to test it to find out what is wrong. I am getting "reading errors." Still don't know what is causing these glitches, unless they are from my DVD recorder (which may be wearing out)--or, someone suggested that the companies are putting in protections so you can't copy them. But I would think this would happen from the beginning of a disc. [the originals are DVD's recorded off satellitte dish onto DVD recorder; then I copy them on the computer (for back ups in case they get stratched or for travel].
    Can anyone tell me what .dll at the end of a file (error code) stands for? Thanks
  • GRACIE5 Mar 12, 2009
    BFMCCoy
    Thanks for the response. I will checkout this website an try some things when I have more time. I have done registry cleaners before, but I don't clean them all out because I don't know how to differenietiate what I need for other programs and what I do not. How do you tell which ones are safe to remove? It is hard to tell by the names. And, it says that if you remove somethign that is necessary that it might corrupt that file, even if you restore.
    Someone tolf me that maybe movie companies are putting protection even on RV or satelite. I dont know if this is true. I just want to record off of the TV and make a backup as they are sensitive for scratches. I was able to copy the Golden Globe Awards recently, but not the Inauguration. So, it must be something else.
    Somebody told me to try ANYDVD program to copy DVD's. I might try that also.
    thanks for the input
    Gracie
  • GRACIE5 Mar 14, 2009
    gIFF46
    Thanks for the input. I checked back and I had installed SP3 9-19-07. I don;t remember now when I got those codes (maybe when I was trying to copy a disk using DVD decrypter program. I will have to see if those codes are still recorded somewhere in that program and when it happened. I don;t know why it was pulling up SP2 at that time. It appears that I started having the issues about Dec 30, 2007 when I noticed that the CD Rom/CD/DVD player would not recognize discs. That is when I replaced that drive to a CDRom/CD-DVD burner. Later replaced the other drive to another CD/DVD Burner. I see on another thread that other people had this problem too after installing SP3. I am not sure if I did any copying between the time I installed SP3 and started having the problem.
    However that string becomes quite technical (beyond my expertise) and I don't want to get further into a hole that I can't get out of. It is many pages. Mayeb one day when I have more time I will try to get to the bottom of it.
    On another note--I did install a fix for Px Engine, (as the main errors are similar or the same as these, when trying to copy in Record Now (Roxio, formerly Sonic). So I thought maybe the "px" meant it had something to do with that:
    px.dll: 4.0.36.500
    pxdrv.dll: 1.2.9.0
    pxwma.dll: 1.0.0.3
    but it didn't make any difference.
    So, the mystery continues.
    gracie
    Problem Solver:
  • 9 Answers
Dll error = Dynamic-Link Library error
"A DLL is a component of an application or software program, which usually contains a part of the application's instructions or some data required by the application."
these things happen to me all the time when i am copying cd/dvd.
I FEEL YOUR PAIN>!!!! i cant tell you how many times ive had a dvd burning, and come back to find it messed up at 80% done.
I felt helpless and didnt wanna waste time with it anymore. its less of a headache to just but the damn movie!
my buddy sent me this link to help fix the prob. it made a huge diff and i havent been having these time and disc wasting problems
you should scan you drivers to make sure they are all in place. this should help
http://www.windowsfilehelp.com/solution.php?sc=Fy&kw=burningdll&key=dll+errors+when+burning
let me know if this does the trick, glad to help BMc
Posted on Mar 12, 2009
  • 20 Answers
Gracie5, What I would do is find another application program to run on your DVD drive. There are alot of freeware products on the net. Your may be out dated for the current disks you are trying to make.I don't think all those disk companies can be making that many bad disk. Remember to always update!
Posted on Apr 18, 2008
  • Allen Gifstad Mar 12, 2009
    GRACIE5, Ther errors that I see are a sp2 error. Load service pack 3 on your system and then look for updates to down load. Watch for any dvd burner applications to download. Make sure all the syntax codes are all checked and then restart your machine and then try again.
Samsung DVD Recorder "copy protected" error
I had a similar problem... went to samsung.com and downloaded firmware update for unit and instructions.... updated firmware and unit is now able to copy my own tapes from vhs to dvd.
Be sure to read and following firmware update instructions carefully...
Feb 24, 2010 | Samsung DVD-VR357
I am trying to save a DVD + R disc to my lap top so that I can make more copies of it for Family. I get an error message when I try and do it. ''Your recording device does not support writing to DVD media....
The error message implies that your DVD is not capable of writing DVD's, particularly DVD+R disks. Recheck the spec's on the drive; it might write to DVD-R disks, or perhaps it only burns CD's and not DVD's at all.
Nov 16, 2009 | Computers & Internet
Can NOT copy aN original DVD made from Sony Camcorder DCR-TRV27
Try Finalizing the DVD disc on the Camcorder or the DVD Recorder before trying to copy the DVD on the Computer.
Jun 16, 2009 | Sony Handycam DCR-TRV27 Mini DV Digital...
Dvd recorder has copy protected message
the tapes that you can,t copy are protected, manufacturers used to put a high pitched frequency on the tapes themselves, which would in theory cause a scrambled frequency. the only suggestion i have for you, is to play the tape onto a television, and use a camcorder to record the image from tv to camcorder, then camcorder to pc, and use some good editing software to create the dvd.
alternatively, you could try using a second dvd player, and use your recorder as the second device.
The final but more expensive option, is to look for a way to input the recorder, direct to PC. which you would use picture out, to graphics card input, and the red and white ( Audio ) for the stereo Sound output. does your player or tv have An spdif connection or similar, you may be able to output to camera, rather than to dvd.
Where theres a will, theres a way, but these are a few options.
****Please note:- this information is supplied only as you have the original Movies***
Bear in mind, it is illegal to copy protected content. However as you own the originals, this information is provided to enable you, to backup your Purchased Content.
Thankyou for using fixya.
Mike @ compurepair.
Jun 15, 2009 | JVC DR-MV100B DVD Recorder/VCR
Want to copy vhs to dvd
just play your movies from vhs iput your audio/video to computer with TV CARD and video input. then record it and burn to DVD format after recording.
May 26, 2009 | Panasonic DMR-ES25 DVD Recorder
Cannot record copy protected message
Hello billwade1216,
I'm sorry to inform you but we are unable to disclose those types of details as it is Illegal, and against Fixya's policy.
Sorry for any misunderstandings, thank you for trying Fixya!
Apr 03, 2009 | Samsung DVD-VR375 DVD Recorder/VCR
I have an error 25 on my dvd recorder
Technically, E25 is a copy-protection error, but I have some additional background on this issue. On the one hand, it could be a legitimate copy-protection error - you are trying to record from a copy-once or copy-protected source - this is especially true if you are trying to record from a Cable/Satellite Box that has a DVR box - since copying to the DVR is considered the first "copy," the Magnavox will not allow you to make a "second" copy.
On the other hand, Magnavox/Funai players see all programs recorded in V mode (as opposed to VR mode) as "copy-prohibited". It records all +R discs in VR mode automatically, so the solution in this case would be to record on a compatible -R disc (or vice versa).
There are two simple fixes for this issue in either case:
1) If you are using a +R disc, switch to a -R disc. If you are using a -R disc, switch to a +R disc. Simply switching the disc type will "fix" Magnavox recorders (long story).
2) If your TV has a "Video Out" or "Monitor Out" (most TV's don't), you can connect a yellow video cable from the OUT of the TV to the Video IN on the back of the Magnavox. This will permanently resolve your problem by fooling the recorder.
Here is additional info about the type of disc to get:
IDiscs that have been tested and are proven to be compatible with this recorder:
VERBATIM DVD+R 8x, VERBATIM DVD+RW 4x
VERBATIM DVD-R 8x, VERBATIM DVD-RW 2x, MAXELL DVD-R 16x, JVC DVD-RW 4x
IWe strongly recommend for good recording quality:
TDK DVD+R 4x/8x/16x, SONY DVD+R 4x/8x/16x, MAXELL DVD+R 4x/8x/16x, SONY DVD+RW 4x,
MAXELL DVD-R 8x/16x, MAXELL DVD-RW 4x
Good Luck!
-Tha Mp3 Doctor
Feb 01, 2009 | Philips Magnavox MWR10D6 DVD Recorder
Operating unit
This unit will not record certain types of TV and no copy-protected VHS and it doesn't tell you when you have those situations--and it doesn't come up with an error message that tells you what you are doing wrong. First step is to be sure that your source material is not copy-protected.
Jan 04, 2008 | Panasonic DMR-EZ47V DVD Recorder/VCR
Disc error with some DVDs
If the DVD recorder is an early model, it may be having trouble understanding some of the newer copy-protection schemes that are in use.
There's not too much you can do for this kind of problem, but you can try looking on the manufacturer's website to see if there's a firmware update for the DVD recorder. It would be something you would download and burn to a CD or DVD and then load into the recorder. That would update the DVD player's software so it can work with newer discs.
Dec 10, 2007 | Televison & Video
Copy Protection Signal
"Copy Protected Signal." Means that the data you are trying to Ahem... "Copy" probably has copy protection inbuilt into the disk & data. This is done to stop copying of pirate DVD's etc. Part of the DRM put out by the TV/Music/Film industry. There are programs that can strip protection and enable one to copy said DVD's.. AnyDVD is one that springs to mind, as does Dameon Tools, and many others simply Google for them.
Jul 11, 2007 | Panasonic DMRES15 DVD Recorder
Computers & Internet Logo
453 people viewed this question
David Payne
David Payne
