Dear sir my pc 4 beep not display. i am other ram check not display
  • 149 Answers
Try reconnecting your hard drive . check whether your rams are working.
Posted on Jul 07, 2010
Dead
Hi
THe most common beeps that you will encounter 95% of the time in repairing PC's are:
1 beep - computer ok
continous beeps / long beeps - memory error
continous short beeps - bios boot block/corrupted bios
1 long beep followed by 3 short beeps - video card error
or this might help
you can check out this list
AMI BIOS
1 short - Computer ok
2 short - RAM failure
3 short - Parity RAM failure
4 short - System timer failure
5 short - Motherboard failure
6 short - Keyboard controller error
7 short - CPU failure
8 short - Video RAM failure
9 short - ROM BIOS error
10 short - CMOS read/write error
11 short - Cache RAM error
1 short, 3 long - Memory failure
1 short, 8 long - Video adapter failure
Check board/chipset makers website for more infomation.
AWARD BIOS
1 long - Memory error
1 long, 2 short - Video error
1 long, 3 short - Video failure
Continuous beeps - Memory or video failure
note that AWARD relies on motherboard manufacturers to develop their own beep codes - the above are only their own internal codes. You will need to refer to your own manual for an explanation of precise codes.
Standard IBM beep codes.
No beep - Power supply or motherboard failure
1 short - System is ok
2 short - POST error (code displayed on screen)
Repeating short - Motherboard failure
1 long, 1 short - Motherboard failure
1 long, 2 short - Video display adapter failure
1 long, 3 short - Video display adapter error
3 long - Keyboard error
Pheonix beep codes
1-1-3 CMOS memory failure
1-1-4 BIOS failure
1-2-1 System timer error
1-2-2 Motherboard error
1-2-3 Motherboard error
1-3-1 Motherboard error
1-4-1 Motherboard error
1-4-2 Memory error
2-x-x Memory failure (any number of other beeps)
3-1-x Chipset error (any number of other beeps)
3-2-4 Keyboard controller error
3-3-4 Video adapter failure
4-2-4 Expansion card failure
4-3-4 Time of day clock failure
4-4-1 Serial port error
4-4-2 Parallel port error
4-4-3 Math co-processor error
pls rate as fixya if it helps. thanks
Jul 04, 2008 | Acer Aspire 5100 Notebook
The PC does not start.Only it beeps and a red light blinks,also fen is not working.
here are some of the basic codes, depending on which BIOS you have...
Also you do not indicate which fan? I would guess you mean the main Power Supply (PS)? In which case it could just be you need to replace the PS.
Here is a link to some other codes as well...
http://www.computerhope.com/beep.htm
AMI BIOS ERROR BEEP CODES
  • 1 Beep - Memory Refresh Failure (check memory)
  • 2 Beeps - Memory Parity Error in first 64KB block (check memory)
  • 3 Beeps - Memory Read/Write Error in first 64KB block (check memory)
  • 4 Beeps - Motherboard timer not functioning (possible motherboard replacement)
  • 5 Beeps - Processor Error (may need replacement Processor)
  • 6 Beeps - Gate A20/keyboard controller failure (possible motherboard replacement)
  • 7 Beeps - Processor Exception Interrupt Error (may need replacement Processor)
  • 8 Beeps - Display Memory Read/Write Failure (reseat or replace video card)
  • 9 Beeps - ROM checksum Error (replace BIOS chip or motherboard)
  • 10 Beeps - CMOS shutdown Read/Write error (possible motherboard replacement)
  • 11 Beeps - Bad Cache Memory - test failed (replace cache memory)
Phoenix BIOS ERROR BEEP CODES
Phoenix BIOS beep codes are a series of beeps separated by a pause, for example:
beep --- beep beep --- beep --- beep beep would be 1-2-1-2
  • 1-1-4-1 - Cache Error (level 2)
  • 1-2-2-3 - BIOS ROM Checksum
  • 1-3-1-1 - DRAM Refresh Test
  • 1-3-1-3 - Keyboard controller test
  • 1-3-4-1 - RAM Failure on address line xxxx (check memory)
  • 1-3-4-3 - RAM Failure on data bits xxxx of low byte of memory bus
  • 1-4-1-1 - RAM Failure on data bits xxxx of high byte of memory bus
  • 2-1-2-3 - ROM copyright notice
  • 2-2-3-1 - Test for unexpected interrupts
I hope this helps.
Mar 29, 2011 | HP Computers & Internet
I dont't get display in my moniter my board is intel dg43nb ram 4 gb, core 2 quad processor fan move green led light but n display
check the ram to know if it is actually working or sitting properly.......check the VGA port...........try another monitor on your board........lastly try the monitor on another board and if it works you board is bad
Jan 31, 2010 | Intel DG43NB Motherboard
Continuous beeping sound
Do you get video? If so then it could be a stuck key on the keyboard.
Do you get no video? If so then reseat the RAM.
Feb 10, 2009 | Sony VAIO PCV-RX370DS PC Desktop
Only three beep
1) try cleaning the ram.
2) if it the long beep there is problem with the ram try changing the ram.
3) if you face the same problem there is a chance of *********** board to be faulty
Jan 07, 2009 | Intel D845GVSR Motherboard
Intel 845gvsr motherbord nos display.
with no ram you will get beeps that confirms your processor is working (as it cant detect ram) you could be using the wrong speed or type, also as Ghoaliass stated, if your using a couple of modules try one at a time, if it fails on the first, remove the stick and try anther one and so on until you at lease get a bios screen :)
Hop-e this helps,
XBM
Nov 26, 2008 | Computers & Internet
Problem with display
try with remove the cmos battery if u using add on display card just remove it and use onboard one if u still not getting display then it is motherboard problem.
Oct 20, 2008 | Gateway 510H Pentium 2.4 GHz, 256MB RAM,...
Model.no NetVista 6742-32J seral no:97-2322D
Beeping sound is generally associated with RAM or your Display card. See that the Memory is not loose and it is working properly. Ditto for the graphics card. Re-check. If it still does not work, replace the RAM / Graphics card whichever is faulty.
Dec 25, 2007 | IBM NetVista X40 PC Desktop
Computers & Internet Logo
48 people viewed this question
David Payne
David Payne
