Question about Toys
The throttle trigger on the traxxas tq 2.4g moves toward the brakeeverse when switching to the 70/30. Now there is no reverse. How do i get reverse
    Problem Solver:
  • 9 Answers
You need to reprogram your tq 2.4 if you set it to 70/30. Also make sure you haven't set your ESC to race mode (2nd setting) as this has no reverse only forward and brakes.
Hope this helps
Posted on Nov 29, 2010
The throttle trigger will not work on my 235e husqvarna
I'm guessing from the statement that it "will not work to increase speed" that you have been able to successfully start the chainsaw.
I have to look at this with the assumption that you haven't run a chain saw before, so bear with me if some of this is excessively simple.
If the throttle trigger does not move, something is jammed. The handle for the choke should automatically move to the retracted position when you pull on the throttle. If it doesn't, see if the trigger will move after you push the choke handle back in.
If the trigger moves in when you squeeze it but you don't hear any change in the engine sound then it's probable that the throttle wire has disconnected at the carburetor or at the handle.
Is the chain brake off? You need to pull it firmly back toward the upper handle for it to be disengaged. If the handle is forward it will lock the outer portion of the clutch. If you try to accelerate with it locked the engine will bog and not allow the chain to move.
Any of these conditions other than the chain brake will probably require some disassembly. Make sure you're confident that you've correctly reassembled everything if you're going to do it yourself.
Nov 22, 2013 | Husqvarna 16" Chainsaw Chain Saw Bar...
How to reverse throttle servo
switch the button on the bottom of controller it will say reverse throttle
Sep 18, 2011 | Traxxas Toys
How do i reset my rc traxxas stampede?
I don't believe the reset (or syncing) is necessary on this model. However, on similar models you pull the batteries from the vehicle and the remote. Wait 30 seconds. Replace with fresh (or tested as good) batteries.
Best regards
Mike
Nov 20, 2010 | Traxxas Stampede Monster Truck Rtrw/Xl 5
Traxxas tq controller has steering reversed. Left goes righ and vice versa
Towards the bottom of the controller there should be two small switches. One switch will be for the steering servo and one for the esc. Channel 1 should be for the steering servo, move that switch and that should correct your problem.
Aug 14, 2010 | Traxxas E-maxx Evx-2 Monster Truck
Traxxas nitro stampede
you starter coil spring is in backwards because it backwards when u try to start ur car it is backwards when it starts the car motor will spinn backwards
Apr 04, 2010 | Traxxas Stampede Monster Truck Rtrw/Xl 5
Hello! I just installed a Traxxas Link 2.4ghz
did you check your servos
Mar 08, 2010 | Toys
Traxxas Revo 3.3 shifting problem
you might need to reset the opti drive. turn the power on with the engine still off and hold down the optidrive button for 5 sec. see it that works.
Jun 24, 2009 | Traxxas Rc Revo Nitro Monster Truck
I just purchased a traxxas tq3 controller and would like to know what the red switch on the handle is used for?
The red switch is the reverse and foward switch, if you have reverse. When you do change it wait about a second to change fully. :) Reply if helped
Apr 11, 2009 | Electric Traxxas Stampede Xl-5 Rtr ...
Toys Logo
163 people viewed this question
Top Toys Experts
Tom Chichester
Andrew Taylor
Andrew Taylor
Are you a Toy Expert? Answer questions, earn points and help others
