Question about Dryers
LD605e Idle Pulley tension spring. Attached to motor casting. But does the other end just hook into the hole in the lower part of the assembly housing and then held in place by the tension in the belt system.
  • wcpcolin Jul 07, 2010
    Specific issue with Westinghouse Dryer LD605e. THe tension spring on the idler pully is attached to the motor casting but has come away from whatever it attaches to to creat the tension on the belt. Does it just hook into the round hole towards the base of the metal engine mount frame?
    Top Expert:
  • Dryers Master
  • 77,202 Answers
Make and model number please so i can look up a diagram, but remember this is a pulley tension spring so it attaches where ever it applies tension to the idler pulley for the belt
Posted on Jul 07, 2010
  • 4 more comments
    I agree with your comment, but it does appear, on first look, not to tension correctly. I may just be wrong about that. So if you have a picture that shows the spring hooked into that round hole in the motor frame assembly, I will go with that.
    And thank you.
  • yadayada
    yadayada Jul 07, 2010
    the model number u provided is not valid, please look in the places shown in the picture.
    HI Wiz,
    I am in Australia, so depending where you are, the models may have different ID's. The tag inside the front door identifies it as an Electrolux Home Products appliance. In Australia it is branded as a Westinghouse. The model number is LD605E. Serial Number 733 32120. App No S91.
    Good luck.
  • yadayada
    please go to the web link below, at the that site click on "Westinghouse", it shows diagrams of the many different belt tension spring attachment points, diagram "J" may be what u have, have a look.
    http://www.repairclinic.com/0079.asp#Dia...
  • yadayada
    the web page opens to the correct set of diagrams, just checked.
  • wcpcolin Jul 09, 2010
    The Idler is fixed off axis to the centre of the casting of the motor frame. The motor rotates about its axis within the frame. The tension spring is attached to the motor and back to the body of the machine. There is no tension arm, as in all the diagrams in the illustrations. The tension spring rotates the motor frame against the tension in the belt and forces the pully off axis.
    The problem is that I cannot work out where the spring attaches to the body of the machine.
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. It seems that you areinstalling a new belt; please check this video on how to replace the belt whichalso provides you info. on the idler pulley tension. Please do accept thesolution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
How do I loosen belt to replace Altenator
The tension pulley is the one that is not driving anything, and has a large spring assemble attached. At the centre on the (cllosed) side there should be a 1/2" square hole that will receive your torsion bar. Pull the pulley assembly so that the belt is released,and remove the bely.
Aug 16, 2015 | 2005 Dodge Stratus Sedan
Simpson Maxidry 362. Tips on putting back together....? Roller tensioner spring attached to...?
Here are the steps to get the belt and tension pulley and spring attached properly.
1. Remove the drum from the dryer housing
2. Fit the belt around the drum, secure the belt to the drum (grooved side towards the drum, flat side away from the drum) with small strips of masking tape. Leave a loop of about 10-15 cm's free to fit around the motor. (This was Hurdle #1, it was next to impossible to hold the belt on with one hand and attempt to work out the tension pulley thing at the same time)
3. Place the drum back in to the dryer housing and rotate it so that your belt loop is facing the motor.
4. (Hurdle #2) Attach the tension pulley to the motor assembly bracket. (There should be slots in the bracket for the pulley bracket to insert into. The pulley faces away from the motor, about a 45 degree angle.
5. (Hurdle #3) Feed the belt through (under) the pulley and then over the motor's drive wheel or nub, whatever it's called.
6. (Finaly Hurdle) Attach the spring to the pulley assembly. In the centre of the dryer housing floor, there should be a seam, in the centre of this seam there is a small hole where the other end of the spring attaches too. Stretch and insert the other end of the spring into this hole.
7. Remove the masking tape that's holding the belt down.
8. Re-assemble dryer and your done.
Jun 20, 2008 | Dryers
Changing serpentine belt on 2004 dodge ram 1500
Should be a diagram on hood.or at radiator .
May 30, 2014 | Cars & Trucks
HOW TO OPEN HARRIS GARAGE DOOR WHEN SPRING SNAPS
In such a situation replace the spring assembly and shaft that it is attached to. Then determine how many winds you need to add to the windlass for spring tension to get the door to lift. Depending how the door track it is set up the outer wheels that take up the lift cable spool about 16 to 18 inches of cable per revolution. The spring gets tensioned by sticking a length of half inch/13 mm rod into 1 of the 4 tensioning holes of the windlass that are cast into the clamping end of the spring and turning tension onto the spring by way of that windlass to lift the door once the cables are attached to the door and then clamped into the wheels, once the approximately correct lift height has been cranked into the spring.One rod would need to be left in place to hold windlass firm until the set screw is tightened. Then you can put on a hard hat, unlock the door and lift slightly- the rod will fall out if you wound the spring the correct direction.and the door should rise again with ease.
Dec 31, 2011 | Home Security
How to Change the serpentine belt?
the belt is routed around various pulleys depending and the engine you have. The tensioner pulley is a spring-loaded assembly which keeps the belt tight on the pulleys. On the 3.0 L Duratech engine, it located on the pass. side toward the back- near and lower to the power steering pump and reservoir. It has a pulley about 3 inches diameter with a metric bolt in the center (very tight spaces to work with). A long wrench or socket on ratchet can move the pulley and assembly away from belt, taking tension off belt while you hold it in place. Alternately, the assembly arm itself may have a square 3/8" hole to insert a ratchet drive in order rotate the pulley against spring pressure to relieve tension on belt. Then slip belt off and route it out. Again, VERY TIGHT space.
Feb 22, 2011 | 1999 Ford Taurus
Where is the belt tightening adjustment located. I have tried turning the nut under the alternator but nothing is moving. The belts and idler were recently replaced, but they are getting looser and looser.
Richard, please exercise caution when working on belts on your engine. If you haven't already I would suggest disconnecting the negative battery terminal to ensure nothing will move when your hands are in the belt area. Your question did not indicate what type of Toyota or year it is. I have a two type of belt answer:
On my 87 Toyota truck, the "V" belt idler for my AC pump was adjusted by loosening the nut in the center of the pulley wheel, then adjusting a bolt behind the idle pulley in or out as needed. Turing the bolt moves the pulley in or out depending on what way you turn it. When the belt is tight, you then lock the pulley in place by tightening the bolt in the center of the pulley. My alternator was the belt tensioner for the second belt. The top nut would allow the alternator to move, but you also had to loosen the lower bolt and nut under the alternator to allow it to pivot on that bolt. The top nut was tightened when the desire belt tension was achieved. The lower bolt is tightened back as well. Over tightening the belt can put extra wear on the alternator and water pump bearings, so use caution.
If your vehicle is newer, the belt might be flat or a serpentine belt type. These types of belts are kept tight by a spring load from the idler pulley. The spring is inside the round housing part of the idler arm. That end is usually attached to the engine. The pulley is on the swing part of the arm and is used to apply tension to the belt to keep in on all the other pulleys. In the casting, you will see a square hole for your 3/8" socket wrench to fit into. This allows you use your wrench to release the tension from the belt. The spring and movement of the arm applies the required tension to the belt and does not need to be adjusted, but just inspected every so often to make sure they still move. In your vehicle engine area, you might have a small diagram showing the route the belt takes through your accessories on the engine. When the pulley arms get old, they can stick and not apply the proper tension to the belt. The belt does stretch when it first is used and when it gets older. Your new belt circumference might also be too big now and the pulley arm might be at its limit of travel. I would suggest taking it back to who did the work to have them correct this. You can check the tension by pressing down on the belt between two pulleys and note the movement of the idler pulley arm. The pulley arm should move back when your release hand pressure to the belt.
I hope this helps. Please leave feed back if this was useful to you. Thank you.
Jan 01, 2011 | Toyota Land Cruiser Cars & Trucks
99 cavalier 2.2 - how do you remove the serpentine belt?
While standing by the passenger side tire, look at the belt assembly. On the left side halfway down the motor is a tensioning pulley. It is below the power stearing pump. It is basically a pulley on a lever that is spring loaded. The lever part has a 3/8" square hole on it that accepts a 3/8" ratchet (or breaker bar). Push the square ratchet end into the square hole on the tensioning lever and pry like heck. I can't remember if it is clockwise or counter clockwise. It helps if someone else can slip the pulley off of the alternator. A long handled ratchet works better. My Cavalier just turned 260,000 miles. I've replaced the belt twice and tensioner pulley once (bearings went out on it).
Doug
Apr 18, 2010 | 1996 Chevrolet Cavalier
I have a broken pull cord and cannot figure out how to fix it.
Easiest way is to remove the complete blower housing assembly, remove the old rope, then twist the rope pulley around and around until the spring is tight, ease it back until the hole in the pulley for the rope lines up with the hole in the recoil housing and stick a small screwdriver through the pulley and the housing to hold tension on the spring. Next, take your new rope and feed it first through the recoil housing, then through the hole in the pulley, tie a good solid knot right at the end of the rope and pull it back out until you feel it pulling on the pulley. Now holding tension on the rope, remove the screwdriver and let the spring tension slowly pull the rope back into the the pulley until it is full, pull it back out about a half turn on the pulley and tie a slip knot against the outside of the housing to hold it in place and reassemble everything. Hook the end of your rope through the rope guide on your handle if it has one, slip the handle on and tie a knot to hold it. Cut off the excess, pop out the slip knot and it will pull up tight and you are ready to go
Sep 16, 2009 | Toro Lawn Mower With Toro Power Tools
Starter cord will not rewind after being replaced. The string will rewind in the housing before it is attached to the motor but not after being attached. How do you pre wind the springs?
What I do is the following:
Remove the old rope ( what is left of it)
Wind the starter rope pulley about 8 or 9 complete revolutions after I am confident that the spring has engaged the starter pulley
Hold the pulley in place ( align the rope hole in the pulley with hole in the starter housing
Insert the rope and tie a knot, pull the rope back tight against the pulley
Pull the rope all the way out and hold slight tension on the rope and release the tension on the pulley but still holding the starter housing
Starter spring should pull rope into housing... good luck
Sep 08, 2009 | Garden
Cord doesn't retract, so I took it apart ...
Pardon the long winded answer. I have had a similar same issue on this trimmer TWICE in the first 3 months. What I found on my trimmer is that there is a spring buffer/assist built into the starter assy between the rope pulley and the plastic part that engages the cogs on the motor. The plastic part that engages the motor has a hole in it to retain one end of the spring and the other end of the spring fits in a slot in the rope pulley. The plastic part with the hole appears to be poorly designed and allows the spring assist spring to fall out of the hole and jam the entire assembly preventing the rope from returning. Pulling it apart allows the recoil spring to escape from under it's cover and prevents it from engaging. Yes, removing the spring can be a little exciting -- take your time and cover the housing opening with a towel before removng the spring to keep it from flying across the room. I rewound the spring by driving a nail into my workbench and using it to retain the center hole and wound the spring until it would fit inside the metal spring cover. There's a bump in the outer winding that fits in a hole in the spring cover and then it slides over a peg in the plastic housing. The cover will retain the spring as you put it back into the housing as long as you take your time. The circled inner end of the spring should show in the center hole and it engages the other part of the recoil assembly that engages the cogs on the motor. Check to see if the assist spring is engaged on both ends before tightening the 3 retainers. All-in-all a pretty poor design that has me looking for another trimmer and this one's going in the trash.
Aug 07, 2009 | Homelite Mighty Lite Lawn Trimmer
Dryers Logo
471 people viewed this question
Top Dryers Experts
