Question about Nokia 5630 XpressMusic Smartphone
Nokia 5610 Light is not working
Actually earlier it was havinh loose connection and screen light was sometimes getting off .... But Just few days back it get wet, due to rain and there was some water drops in screen, Since Screen light is not working. I opened the phone and clean everything thinking moisture problem, but still the problem persists. Need advice
5610 on but no light
Posted on Nov 30, 2010
Hi, my nokia 5610 lcd module back light not working properly... but i press somee were on screen it is glowing. pls send me solution...........................
Feb 11, 2011 | Cell Phones
Lcd lights
i have nokia 5610 but there's a problem. there's no lcd backlight only the light.. screen also not working.. help me pls..
Mar 16, 2010 | Nokia 5610 Blue Quadband 3.15MP A2DP +...
Sir,my display light can't working?m handset no is nokia 1650
Sometimes the backlit gets loose.If there is no light and no image on screen, then you may need to take phone to an electronics store for LCD screen replacement. If there is image, but no light, then:
  1. Power off phone
  2. Remove back cover
  3. Remove battery
  4. Remove SIM
  5. Using a little flat head screwdriver, unlock and remove the frontal cover of the phone.
  6. There are six Torx screwdrivers inside. It's head looks like this:
  1. f85360e.jpgThen use a Torx screwdriver for removing them. If you haven't one, a small triangular file, or a swiss knife will do the job.
  2. After so, remove the back plate of your phone.
  3. Remove the 4 Torx screwdrivers wich hold the screen in place.
  4. Remove the screen.
  5. Clean the contactoes between screen and phone.
  6. Reinstall screen in place.
  7. Repeat steps in inverse order to reassembly the phone.
  8. Power on phone. If light stills refusing to work, then take your phone to an electronics store.
Dec 02, 2009 | Nokia 1650 Cell Phone
Nokia E66 screen sometimes goes off when the slide is open...
sounds like the cable is loose and just not getting a good enough connection just because you said after taking it apart it works for a few day then sarts acting up again
Aug 08, 2009 | Nokia E66 Smartphone
Nokia 5610, security code problem
hi,the code was typed too many times. take out battery for 30-40 minutes. and then try 12345. if no joy then reflash the phone (do a back up before reflashing as you'll loose all your data).
rate me if helped,thanx.
Apr 14, 2009 | Nokia 5610 Blue Quadband 3.15MP A2DP +...
Nokia 3230 disply problm
I suggest to change with an other UI boards it's more easy.Actualy the problem come from flexyble cable specially in camera line.It's often happen.If you an expert track the line between camera connector to flexyble connector.Usuall one or two line are not connected well. I hope it help.
Mar 22, 2009 | Nokia 3230
Black Screen with horizontal lines
are u sure that ur not able to see the fone's stand by screen now?its totally black?are u sure that there's no problem with the screen itself,the care guys might have left the screen connection loose. other wise try one thing,Format ur fone. by pressing *#7370# u have press keys once wait for 5 seconds and press the left selectin key [where u get the YES option normally. the fone would restart and lets see are u able to go back on the screen. IF YES then u can set the Sleep mode to off cuz the sleep mode gets inititated after 20 minutes when u keep ur fone idle means u dont operate ur fone for atleast 20 minutes. BUT IN THIS CASE ULL LOSE ALL UR DATA INCLUDING CONTACTS AND MESSAGES ETC.IF U HAVENT TAKEN THE BACK UP EARLIER.so its totally upto u that u want to proceed with this step or u can again show ur fone to the nokia care guys. but they'll charge u cuz obviously after 2 years ur fone is out of warranty
Oct 05, 2008 | Nokia N73 Cellular Phone
My acer aspire4310 notebook suddenly displays a white screen
If you have blue strip running down vertically from top to bottom then normally there is a problem with LCD or a loose LCD cable.But what I recommend you to test more is tha,t if you tab at the back of your screen ...does this problem occur ???
Incase it does,then its a loose LCD cable problem.You still need
a qualified person who knows how to open the monitor to repair inside.
And again for the White screen it can also be both cases I mentioned above
ByeBye,takecarfe
Apr 22, 2008 | Acer Aspire 5610-4648 Notebook
Nokia 5630 XpressMusic Smartphone Logo
443 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
