Question about Ovens
Power lose what button to press to restart - Ovens
  • jenijamie Jul 07, 2010
    i have a simpson evolution 912 oven ... after lose iof power .. i need to know sequence of button to restart oven
  • 677 Answers
A microwave can be dead for many reasons.
You can find a wiring diagram for model R1471 at our site:
http://207.234.249.73/mwd/r1470_wiring.jpg
If it goes dead for a while during or after cooking then comes back on, the magnetron is probably overheating and causing the magnetron thermostat to open. Then when it cools, it closes the circuit and allows power through again.
If it's intermittent or random, it may be a bad connection, usually on the control board or a loose fuse holder, or even an intermittent fuse.
You should do a continuity test the fuse while it's in the holder (with the microwave unplugged, of course) then turn the fuse by hand or take it out and put it back in, then test it again. If you remove the fuse, then press the meter leads against the ends, it can allow internal contact to be made and make a bad fuse appear to be good.
If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor.
If it went dead a few seconds after pressing the Start pad, that's usually a failing high-voltage transformer.
If it goes dead or blows the breaker when you plug it in or open or close the door, then there's a problem with a door switch or door switch mount.
If the fuse is good, it may be an open thermostat or thermal cutout on or near the magnetron or on top of the cavity / body of the oven.
If you or someone you know decide to look into it, we have critical safety information and disassembly information at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Jul 07, 2010
  • 2,069 Answers
Could you please inform us of the brand and model of your often. we will assist you.
regards
    my oven is a simpson elolution 912
    with the lose of powere i need the sequence of buttons to press to restart
I need an instruction manual for a red centre outdoor gas oven
Instructions Things You'll Need:
  • Power supply
  1. Press the "Clock" button, then the correct number buttons to set the desired time. Press "Clock" again to confirm.
  2. Press "Timer" to set the timer function. Choose the desired countdown time by pressing the number pads, then the "Start/Stop" button. Press "Timer," then "Reset" to cancel the timer.
  3. Press the number pads to select a cooking time. Press "Power" to use a power less than 100 percent using the number "9" for 90 percent of full power, "8" for 80 percent, "7" for 70 percent, and so forth. Press "Start" to begin cooking.
  4. Press "Defrost by Weight" to defrost a food item by the weight of the item. Enter the weight of the item, then touch "Start" to begin. Enter the food weight by pounds and ounces, using a "0" for a decimal. For instance, if the food weighs 1 pound, 2 ounces, enter "1," "0," "2," then "Start".
  5. Select "Speed Defrost" to defrost food quickly. Enter the desired cooking time and press "Start."
Dec 21, 2010 | Ovens
The display shows F 7 E 6, the oven buttons do not work but the broiler acts like its coming on but does not message. The maual asked to cut the power for 30 secs and restart. Tried that did not work...
http://appliancejunk.com/ge/cookingproduct/31-20105.pdf
Please find above your service and repair manual, use this to troubleshoot and resolve your issue
This website below will also assist in locating an reolving your problem.
http://www.acmehowto.com/howto/appliance/range/erange.php
E6 - Drain pump error Water level does not decrease to reset point within 15 minutes from draining water from the washer. Press POWER button. No other buttons work:
· Check wiring harness
· Check pump motor
· Check circuit board
0 or F7 Shorted Clear/Off Key due to membrane switch, control or connector Shorted key panel membrane switch; Check Electronic Range Control (ERC)
Aug 20, 2010 | GE Ovens
I had an ignis build in, single, fan oven, model AKL907/IX installed in January, worked fine now, switches off when the oven is on, beeps and then can be restarted if pressing the ok button, however the...
Hi i have the same oven, Ignis AKL907/IX. Worked ok for 12 months but now cuts the power in the whole house out when the cooling fan is engaged. Just out of warranty and call out fee is
Aug 15, 2010 | Ovens
In trying to update to daylight savings time, I forgot how to set the clock.
Hi- Press and hold clock button until clock flashes. Set the time up or down. We already lost an hour and have to wait till fall to get it back,- don't lose any more time on this! Let me know if this helps- Thanks- Ed
Mar 15, 2010 | Whirlpool RBD245PRS Stainless Steel Oven
I have a chef finesse systeme oven. The LCD is displaying HELP me
If there is a Mode button, press and hold for a while. When the light on Time blinks press Set button. Next press the up on down arrow button to adjust the time. After that the oven should operate as normal.
Sep 01, 2009 | Ovens
Westinghouse 745 wall oven
First thing, remove the plug from the wall power for at least 10 minutes, maybe even thirty minutes and allow it to reset........ if that does not work write me at wbwill@sbcglobal.net and give more model info so I can investigate for you or check out a volunteer site, allexperts.com and you will find me there also.
Nov 10, 2008 | Ovens
To restart double oven ... b4 tea if possible lol
sounds like you have the timer on, you will need the manual to turn it off.
Dec 19, 2007 | Ovens
Ovens Logo
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
