Question about Konica Minolta Cameras
I would like to know if Minolta CS Pro EP1052 still exists and can l be repaired? Do you have a service center located somewhere in San Juan, Philippines
  • 11 Answers
SOURCE: minolta service centers
try KONIKA MINOLTA web
Posted on May 07, 2008
  • 3 Answers
SOURCE: paper jams minolta 1080 cspro copier
Can you explain where exactly the paper jams, just check any obstruction in the paper path, or clean all the clutches/ sensors for registration and transport
Posted on Jun 16, 2008
  • 7 Answers
SOURCE: problem with my QV-R40
try here
http://www.casio.com/home
Posted on Aug 25, 2008
  • 126 Answers
SOURCE: Copies shows: Call Maintenance M2
Hello, the error code M2 means that the machine needs to have maintenance done ( like tune up to a car).. The only way to clear it would be to reset the counters and the service tech mode.
Posted on Jan 07, 2009
Cogz
  • 1326 Answers
SOURCE: code c 0200 minolta cs pro ep 2050
A c0200 deal with the scanner. You may have a blown scanning lamp. Dose the scanner find HP & does the scanning lamp turn "ON" it could also be the Lens HP. Was this code before or after you were there? If it was showing upafter you.. it could be that the Black Box is installed wrong.... Good Luck
Posted on Feb 07, 2009
Minolta EP1052 error code C 0500
Remove the rear upper cover will see a circuit board. with the machine on press the small black button reset! if the code comes back get a tech out to replace parts in the fuser (Hot part) continue reset can cause a fire (Would ruin a perfectly good Day) try the web site below for parts if required Precision Roller Printer Toner Cartridges Parts and Supplies Office...
Jun 21, 2012 | Minolta EP1030/1030F CS/PRO Copier
Error code c0520 in minolta ep1052 ....resolution?
Remove the rear upper cover then find small black push button on the circuit board lower right press the button with the machine on .if the code comes back replace the fuser unit HOT PART do not continue reset can catch on fire! That would ruin a perfectly good day. Try web site below for parts if required
Jun 05, 2012 | Minolta EP4000/5000 CS/PRO Copier
EP1052 cs/pro copier hang but the light color is still green , I switch off the power and on it again , but nothing is change !!! can you tell me in instruction what to do please ... thank you
Minolta EP1052 - Operates but nothing prints on the paper. Toner seems OK. Can't get to print in any of the exposures.
Any ideas - or has it finally died??
Nov 30, 2010 | Minolta EP1031/1031F CS/PRO Copier
Pm reset n pm settings
Please describe your problem.PM reset not exist to Minolta CS pro 1030.
Aug 13, 2010 | Minolta EP1031/1031F CS/PRO Copier
I have a EP1052 and is showing an error like spanner I know is power problem but i don't know where the sensor to press is please can you help me?
Is the the spanned wrench located on the screen in the lower left? if so touch it the screen will change then open and close the front door the code should go away, if the code comes back need to know what it is,
Jul 10, 2010 | Minolta EP1031/1031F CS/PRO Copier
My toshiba satellite_m305d_s4829 doesn't power up, i thin the problem is mobo, i've just buy it in u.s. but i'm in the Philippines right now...any help please.
May I suggest that you bring your unit to Level 2 of Greenhills Shopping Center in San Juan. Most laptop experts have their service center located in that area. There is also group of experts in Gilmore, Quezon City
Jul 07, 2010 | Toshiba Satellite M305D-S4829 Notebook
1/3 OF RIGHT SIDE OF PAGE DARK OR LINED TOP TO BOTTOM
Drum Cleaning Blade failure. Open up the top half of the machine as if you were removing a paper jam. Now look under the top half and about in the center from left to right. You should see a burgundy colored cylinder running from the front of the machine to the back. If you can see the toner streaks on the surface....expecially on the 1/3rd like on the copy then this will be proof that the drum cleaning blade is the cause. Simple repair for a tech that knows copier basics. A good estimated cost would be about $25.00 for the blade and whatever the going rate is for a service call in your area.
Jan 28, 2010 | Minolta EP1083 CS/PRO Copier
Casio service centers in Texas
Dear Deanice, from the CASIO website: Primary Warranty Authorized Service Centers (U.S.A.) Casio Owned Service Center for All Products Casio, Inc. (Factory Service Center) 570 Mt. Pleasant Ave. Dover, NJ 07801 1-800-706-2534 Authorized Independent Service Centers that perform warranty work---Except for Audio warranty products. The Time Machine 2335 Honolulu Avenue Suite B Montrose, CA 91020 Phone: 818-249-6007 Fax: 818-249-9412 Second Chance Service Ctr. 228 Barbosa Avenue San Juan, PR 00917 Ph: 787-758-8200 Fax: 787-758-8272 secondchance@quintanapr.com I urge you to post your question again on the site along with a description of your problem. One of our experts community might have had experience with the same problem, and can give you some usefull tips. Good luck!
Feb 07, 2006 | Casio Exilim EX-Z750 Digital Camera
Cameras Logo
341 people viewed this question
Top Konica Minolta Cameras Experts
Greg Cann
Greg Cann
Willem.
Willem.
Are you a Konica Minolta Camera Expert? Answer questions, earn points and help others
