Question about Sony FD Trinitron WEGA KV-36FV27 36" TV
I have a sony wega 55'. i noticed that the picture is to dark. i had repairman come the by. he said that the lamp cost $200.00 and the labor was $140. what do you think
  • 518 Answers
What lamp? theres a cathode ray tube which could cost 2oo, how old is the set ,might be cheaper and get new
Posted on Jul 07, 2010
Testimonial: "thank you"
  • Sony Master
  • 467 Answers
A dark picture would not necessarily be a symptom of a failing CRT, although it is possible. It is more likely an EEPROM issue since this IC stores settings including brightness, contrast etc. or a suspect jungle IC, but it wouldn't be the tube unless the colour was washed out, dull contrast, weak brightness and poor greyscale tracking (e.g. a pink dull picture with very little green - is a case of a bad tube).
Lamp? if your TV uses a picture tube, the lamp would apply to some rear projection TVs, not your set, so your repairman must either be a junior/amateur or a complete fool - that's what I think.
Posted on Feb 15, 2011
SONY WEGA KDF-50WE655 PICTURE IS DARK MY LAMP IS ONLY 2 MONTHS OLD
Where did you buy your lamp? sounds like its not a real philips or osram. Discount merchants sells some junk lamps. If you got it there, thats your problem
Jun 13, 2016 | Sony Grand WEGA KDF-50WE655 50" Rear...
55 inch Sony Wega rear projection tv...only stays powered on for a few minutes then goes blank, green light steadily burns and the picture is dark. Is it overheating? What do I need to do to fix this?
If its the model indicated here or one similar(kdf-55xs955) you may be seeing a lamp that is about to fail.
A lot of these just before lamp failure will get very dark and if bad enough the set will even shut off.
Mar 17, 2012 | Sony Grand WEGA KDF-55XS955 55" Rear...
Picture goes out /sound is always on
Sounds like a bad lamp. That is a common symptom when the lamp is about shot in a sony dlp's. i would definately start by changing the lamp. You can type your model number and the word lamp into ebay and find one there. They cost around a hundred dollars.
Jul 30, 2010 | Sony Grand WEGA KDF55E2000 55" Projection...
Sony KDF-E50A10/4 dark picture
Dark picture is indication that tv needs new lamp.
Replace lamp in tv get bright picture, please buy Sony original lamp for good picture in tv.
Jun 17, 2010 | Sony Grand WEGA KF50WE610 50" Rear...
Sony wega kdf55 has blue spot in lower right corner - how do I fix
That is a symptom of the light engine failing. that is the projector part of your TV where the lamp plugs in. Go to Sony's website to contact them and see if your model is still under extended warranty, if so they will help set up repair. If not it could cost several hundred dollars just for the engine plus labor. Good luck
Feb 06, 2010 | Sony Grand WEGA KDF-55XS955 55" Rear...
Pink line across top of sony wega 46" tv
after changing the lamp, I still had the same problem as you. I contacted sony and they offered me a brand new 40 inch bravia flat screen tv replacement...at no cost! If I chose a 46" or 55" there would be a charge between $325
Dec 24, 2009 | Sony Grand WEGA KDF-55XS955 55" Rear...
Picture is dark
Adjust video settings:
  1. Press Wega Gate
  2. Select Settings
  3. Highlight Video
  4. Press + to select
  5. Adjust/increase the brightness.
  6. Press Wega gate to exit.
If picture is still dark, you need to replace the lamp again. Sony recommends that you replace the lamp:
  1. After approximately 8,000 hours of use.
  2. When the screen becomes dark or the color becomes unusual.
  3. When the lamp indicator on the front of the TV flashes.
Aug 22, 2009 | Sony Grand WEGA KF60XBR800 60" Rear...
Faded screen from top to bottom in middle,I replaced the lamp
I had an authorized Sony repairman come to my home. I'm sorry that I cannot remember the part that needs replacing but I can tell you that it cost $700+ and $200+ for labor. We would be stupid to replace it instead of buying a new TV. I doubt I will invest in another Sony as this is a known and common problem with these TV.
Apr 17, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
No Picture but sound
Your lamp has probably failed. It is a Sony XL2200 lamp
Oct 06, 2008 | Sony Grand WEGA KDF-42WE655 42" Rear...
Sony FD Trinitron WEGA KV-36FV27 36" TV Logo
99 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
